slydog 7,874 Posted July 31, 2013 OK thought seeing as I got a few questions about this tub job on my ute I may aswell put it out there for all to see In the hope that it may inspire some to do a similar job on there's with some tips from here there every where. Start with wheels not ideas.Wheels can be put on a car and measured,ideas can't so be prepared for bad news.In my case I wanted atleast 50mm inboard to fit safely and allow for a bit more tyre at a later date if needed.So fitted the wheels,cut the tubs out and took some measurements and found the diff was 15mm out of square to the right!No wonder it stuck out... Right side Left side Next step was cutting floor pan out This happened in 3 stages Got a feeling the cutting isn't done yet either.So onto the steel to make it work.I got some 100x50x3.2 wall RHS some 50x50x4mm RHS and some 5mm plate. Next is measurements... 3 Defective, Crazy2287 and Ants reacted to this Share this post Link to post Share on other sites
slydog 7,874 Posted July 31, 2013 So with the measurements done it was time to plan the rails and how to attach em so there safe and strong.So a long 45 degree notch is done on the out side and covered with 5mm plate twice the length of the material plug welded and seam welded then gussets are fitted to the inside.I'm ahead of the picture here but just to explain whats doing. Notch fitted Back rail prepped Rails level and square to within 1-2mm Next I fitted some 50x50 gussets for extra strengthening on the old shock mount area.It is thick enough to hold it but I will add a 50x25x4mm RHS box to the top so I can get my floor spacing correct.I'll cover that bit later but for now I've gone as far as I can so next up is diff mods. 1 XG PV BW diff now empty but still needing a clean and rinse before welding.So how scared doe's it look of my $99 909 cut off saw? Yes my old saw died and the switch fell apart into abotu 47 bits when I pulled it all down so in a rage I threw it out the shed door and it took a bit over a week to go out and buy one.Masters won with this cheapo as they didn't have a brand I liked in stock at most places ATM.Yes I was looking for a Metabo unit but none were in stock anywhere.Fuckers!!! Diff So Mr 909... Now where to cut and how to mark it out.This is done via your needed redcution size short =717- 50 = 667mm Long =805-50 = 755mm.So via cutting the shortest amount practical off the tube ends in this case marked at 30mm will be the first cut done on the pumpkin side of the line.How do you mark it out...with some paper wrapped around the tube of course. First mark We need a square line around the tube so on with the thick square edge paper held in place via nitto tape... Repeat the process both sides and your ready to start cutting but only after you measure the tube to pumpkin length.This will give you your blade/cut thickness which you deduct from the your reduction cut.As I'm going for 50mm shorter tubes each end I'm expecting around 4mm cut each time so I will have to measure out 44mm and cut the inside of the line to give me 50mm over all removed. The leaf hangers are to be left on till final welding as they allow me to set the diff up from the front and set the brackets straight for tacking and straightness checking. FYI pumpkin to flange end were 486 short and 559 long... Till tomorrow night... Share this post Link to post Share on other sites
mcfly94 169 Posted July 31, 2013 you make your own measuring tools to check square and level? also what are your plans for the plates that cover the join from original chassis to new rail? 4mm would be suffice, and why are you seam welding over stitch, also no sharp edges on the plates, all nice curves , ive picked a few things been working at a chassis repair place for past for months. Share this post Link to post Share on other sites
slydog 7,874 Posted July 31, 2013 Seem weld the plate in around the outside of the plate.To do so I have to drill holes in the plate to plug weld in place and then weld around the plate to make a sound joint.Nothing can be to chance and it will get a gusset/plate from underneath aswell. Share this post Link to post Share on other sites
mcfly94 169 Posted July 31, 2013 Seem weld the plate in around the outside of the plate.To do so I have to drill holes in the plate to plug weld in place and then weld around the plate to make a sound joint.Nothing can be to chance and it will get a gusset/plate from underneath aswell. Yeah sounds good, that's all we do when we reinforce 4x4 chassis after the turkeys have bent them. Can't wait to see it all come together, probably need some good bracing on them rails to make sure it stays square within 3mm Share this post Link to post Share on other sites
slydog 7,874 Posted July 31, 2013 So tubs will be fitted last as there still alot of measuring to do and having them out makes it 1 million easier TBH.I will have alot of inboard room due to the tubs going up to the rails so I can have wheels with either dish or backspace. Need another Jimmy can... 3 XES, 'Nova and mcfly94 reacted to this Share this post Link to post Share on other sites
slydog 7,874 Posted July 31, 2013 I had 295x50x15's on a 6" backspace wheel tyre combo and they don't fit in the real world.They sit proud of the guards,jacked up and rubb on the brake calipers.I like em to sit over the tyre and have room to spare and it will be future proof for a 335 tyre If I want later.And really stock tubbs look like ass,why build a car and leave ugly stock shit in there? I had 255's on the AU rims as stated and they rubbed on the insides and had fuck all too the guards? No football here bro.As this car is not a daily and I want it to look good so it's getting sugar and cream.Don't want to think later on "why didn't I fit a flat floor and nice new tubb's"...that not happening anymore I'm just doing it all.Even doing the inside of it with a sneaky cage And yes a triangle 4 link so It can be down...scared of heights still LOL 3 clevocortina, PH351 and 'Nova reacted to this Share this post Link to post Share on other sites
clevocortina 1,109 Posted July 31, 2013 nice write up Robdog rating your work bro! 1 slydog reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted July 31, 2013 Watching this one Rob, ive always wanted to hack into mine but as usual lack the balls to commit LOL 1 slydog reacted to this Share this post Link to post Share on other sites
'Nova 997 Posted July 31, 2013 Fuck yeah dude! So good to see all this happening! Heaps of love for it! 1 slydog reacted to this Share this post Link to post Share on other sites
slydog 7,874 Posted July 31, 2013 Thanks for the props boys...really so far it has been harder to explain how its happening then actually doing.I have some ideas for a diff jig of sorts but a interference sleeve and carefull welding should keep it useable...if not I get it straightened after all the work is done but only if needed. Share this post Link to post Share on other sites
Damo96 93 Posted July 31, 2013 Fuck you've done an awesome job so far. Making me jealous haha. Will be sik as when done. Are you just gonna make a floor out if some sheet metal? Share this post Link to post Share on other sites
slydog 7,874 Posted August 1, 2013 Yeah flat floor over some rhs frame work Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted August 1, 2013 Make it removable Rob, 4mm sheet alum with Dzus clips holding it in. 3 mcfly94, Defective and Thom reacted to this Share this post Link to post Share on other sites
slydog 7,874 Posted August 1, 2013 Thats not a silly idea bro 1 n00bus m@x1mus reacted to this Share this post Link to post Share on other sites
robbie 901 Posted August 1, 2013 Awesome stuff man, cant wait to see them welds tucked nicely. Share this post Link to post Share on other sites
slydog 7,874 Posted August 2, 2013 Got the tubes shortened and ends back on it to within .5-1mm both sides so Im pretty happy with that TBH.Tomorrow ill cut length off some old bent axles refit to the front hangers, mount the diff up and take some measurements to see where it is at. Pics when my daughter is off the computer.... 1 n00bus m@x1mus reacted to this Share this post Link to post Share on other sites
clevocortina 1,109 Posted August 2, 2013 Is she done yet? 1 Ants reacted to this Share this post Link to post Share on other sites
bear351c 10,433 Posted August 2, 2013 Make it removable Rob, 4mm sheet alum with Dzus clips holding it in. How about polished Redwood, with stainless strips to hold in place? Share this post Link to post Share on other sites
slydog 7,874 Posted August 2, 2013 Well here it is ready for a trial fitting in the AM... Should get to pop it back down and size it all up which will be fun for me.Not settled on the tray as yet and how to place everything but it will come in time.Thinking it will need ALOT of welding in there to help strengthen the show up so some sheet steel is prob gunna win in the end. Share this post Link to post Share on other sites
hendrixhc 10,955 Posted August 2, 2013 Silly question by the uneducated but how do you achieve shorter axles? Cut down and resplined? Share this post Link to post Share on other sites
slydog 7,874 Posted August 2, 2013 Correct,use the long one cut down in the short side and a custom or "found" longer axle turned down to size on the long.You need to remove atleast 3" of the spline/axle to get back to big enough material to work with so as I'm only going back 50mm each side and my axles have almost 80mm of tapper I'm fooked so to speak on the long side.Nothing but a custom will do I'm thinking. I could resize,respline and re drill F100 axles but cost would make a custom axle cheaper.With that in mind thinking about custom 31 spline axles ATM TBH as a just incase and set and forget type deal.Would like to get the car going first though and judge the set up first before deciding on anything like that as that would mean full spool and some Strange axles. 1 hendrixhc reacted to this Share this post Link to post Share on other sites
Campo 869 Posted August 2, 2013 You're not wasting any time mate, looking good! Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted August 2, 2013 Look into AU axles rob they are around 30mm longer than the earlier ones and are fat fat fat!! Share this post Link to post Share on other sites
slydog 7,874 Posted August 2, 2013 Cool good tip bud...it could almost work too judging on Carlo's 3" or 75mm cut back for re-splining. Share this post Link to post Share on other sites
