Emily91 10 Posted May 19, 2019 Hey guys n gals I'm Emily , ive got an 1986 XF Fairmont with 4.1L ....What's the pipe that goes from the exhaust to the air cleaner ...its got two plastic what look like valves ....is it necessary ? ...my crappy phone won't let me upload a picture due to " low memory " ... Share this post Link to post Share on other sites
deankxf 20,288 Posted May 19, 2019 Hi Emily, try the tapatalk app, it's free and you should be able to attach a photo easily with it. i vaguely remember something like you are describing, but has been ages since seeing one. what's wrong with it? they probably assist in warming up the engine or other pollution gizmo. @SPArKy_Dave may have an XF in his museum with that hose or @Jewing15 is about due to update us on Her XF wagon which is a similar model and quite orignal, may be able to show a photo for us Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 19, 2019 Sounds like the pulse air injection, puts fresh air into the exhaust to make it seem as though it runs cleaner, the plastic things are valves that prevent the exhaust gases entering the air cleaner if I remember correctly. Share this post Link to post Share on other sites
gerg 10,871 Posted May 20, 2019 Yeah sounds like that, it's to supply the cat converter enough oxygen to burn off all the nasties that a carby engine makes.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
Emily91 10 Posted May 20, 2019 Thanks guys , I'm rebuilding the motor and want to get rid of all unnecessary crap under the hood . got a set of triple webers, cam , lifters ,and extractors to go on it 2 gerg and FORD_MAN reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 20, 2019 Pics or it never happened Sent from my CPH1903 using Tapatalk 2 eattsie9 and steve mcqueen reacted to this Share this post Link to post Share on other sites
Emily91 10 Posted May 20, 2019 When she's done I'll put a few up for yous 2 deankxf and gerg reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted May 20, 2019 Not good enough!! Â Share this post Link to post Share on other sites
SPArKy_Dave 8,872 Posted May 20, 2019 Sounds like the hot air intake hose... you can buy aftermarket replacements, from memory. Â Crossflows with triple weber carby's, sound very close to the triple weber Hemi 6's. Here's a few youtube video's - Â Â Â Â 3 Emily91, eattsie9 and gerg reacted to this Share this post Link to post Share on other sites
Emily91 10 Posted June 9, 2019 A friend of mine has a hemi 245 with triple webers ...daaaam she sounds nice 1 1 deankxf and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Emily91 10 Posted July 15, 2019 Hi 3 1 motoSycho, SPArKy_Dave, deankxf and 1 other reacted to this Share this post Link to post Share on other sites
Emily91 10 Posted July 15, 2019 I've decided to go with a Holley 650 double pumper and extractors , 2,1/2" straight pipe w sports muffler ..... Share this post Link to post Share on other sites
deankxf 20,288 Posted July 15, 2019 2 hours ago, Emily91 said: I've decided to go with a Holley 650 double pumper and extractors , 2,1/2" straight pipe w sports muffler ..... @CHESTNUTXE might give you some tips, i wouldn't have thought that carby would be a good match without some decent engine work. unless you are doing a lot of engine work at least. 1 bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 15, 2019 465 is a perfect match for a warm 250, don't go off CFM rating for the 2-barrel carbs, they're not rated on the same scale as 4-barrels.A 350 2-barrel is really about 280 and the 500 is about 360. A 650 DP like Dean said is a bit big for that engine, might require a bit of work to get it running right.Sent from my CPH1903 using Tapatalk 2 351XD_Fairmont and bear351c reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted July 15, 2019 Good rule of thumb I like to use is take the target HP and double it for the required carb CFM. Realistically, a healthy crossy would be in the 200-220 HP range without major work and lots of know-how. With this in mind, a carby between 400 and 500 would suit best.There is a 4-barrel Edelbrock 500 that might fit the bill:https://www.edelbrock.com/performer-series-500-cfm-carburetor-with-electric-choke-in-satin-non-egr-1403.htmlSent from my CPH1903 using Tapatalk 1 motoSycho reacted to this Share this post Link to post Share on other sites
Fingers 463 Posted August 10, 2019 Using Gerg's rule of thumb, maybe Emily is going to build a 325 hp crossflow? Â 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted August 11, 2019 What no Webers now . I've a got a set of tripe Webers awaiting for me to build a engine worthy of them, 650dp might be alright, whats the planed engine specs Share this post Link to post Share on other sites
Emily91 10 Posted August 11, 2019 Oil pump failed , got a new x-flow engine to put in next weekend , going to rebuild the XFs old motor ... Gonna go nuts on it , new pistons , oil pump , wild cam ...the whole hog . gonna take a while but hopefully be ready by October for a memorial cruise Share this post Link to post Share on other sites
Emily91 10 Posted August 11, 2019 I'm aiming for as many horses as I can get ...might even look into a super charger Share this post Link to post Share on other sites
dex 2,065 Posted August 11, 2019 Wait for it 1 351XD_Fairmont reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted August 12, 2019 Oil pump failed , got a new x-flow engine to put in next weekend , going to rebuild the XFs old motor ... Gonna go nuts on it , new pistons , oil pump , wild cam ...the whole hog . gonna take a while but hopefully be ready by October for a memorial cruise Going to beat everyone in to it, make sure it’s a standard volume oil pump not high volume ! Sent from my iPhone using Tapatalk 3 2 deankxf, eattsie9, SPArKy_Dave and 2 others reacted to this Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted August 12, 2019 18 hours ago, dex said: Wait for it  3 hours ago, Mixalis said:  Going to beat everyone in to it, make sure it’s a standard volume oil pump not high volume ! Sent from my iPhone using Tapatalk   Ha ha, ando will be here soon boys don't worry, gotta love how we all instantly knew what the joke was 2 dex and Mixalis reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted August 12, 2019 High volume give Ando high blood pressureSent from my CPH1903 using Tapatalk 2 1 Mixalis, 351XD_Fairmont and dex reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted August 12, 2019  Ha ha, ando will be here soon boys don't worry, gotta love how we all instantly knew what the joke wasHahaha I think we’ve been hanging around the forums too long Sent from my iPhone using Tapatalk 3 deano551, dex and 351XD_Fairmont reacted to this Share this post Link to post Share on other sites
