mattymc 30 Posted January 17, 2014 I'm looking at doing my upper and lower ball joints soon and wondered what brands people are having a good run out of?. Other than genuine ford items is there a good quality aftermarket brand?. Is there a certain brand to stay away from?. Hope all that makes sense. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 17, 2014 Aftermarket, genuine Ford ones are (I think) riveted in - unless that's only the originals. TRW is a good aftermarket brand, there's also one call WASP I think, or Protek, they're the ones I know of. Share this post Link to post Share on other sites
mattymc 30 Posted January 17, 2014 Cheers for the info Mr Polson. I did not realise that the factory ball joints were riveted in. I've heard of TRW and Protec before. Not so much Wasp. Will have a look into the different brands. Sent from my GT-I9505 using Tapatalk Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 17, 2014 I have used protec and trw before. My ute was kitted out with Protec, and my wagon had TRW. The utes ball joints and tie rods have lasted about 20,000kms, and showing signs of wear already. Wagon after 10/15,000kms has no signs of wear on ball joints or tie rod ends. Only advance of Protec is they came with grease nipples, the TRW ones didn't. TRW was also more expensive, but I'd pay that extra to have them last like they are. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted January 17, 2014 I used TRW in the XD, ford used TRW from factory TRW bits are pricey but i reckon that they are worth it. Share this post Link to post Share on other sites
SPArKy_Dave 8,925 Posted January 17, 2014 555 were good, till they stopped supplying them. Roadsafe distributed them. They still do 555 tierod ends. 1 ZL. reacted to this Share this post Link to post Share on other sites
dizzy616 183 Posted January 17, 2014 wasp are cheap but their allright haven't had a problem with them. stay away from suzukisupers shit on ebay too Share this post Link to post Share on other sites
SPArKy_Dave 8,925 Posted January 17, 2014 The TRW of today, are not what they were back then. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted January 17, 2014 555 were good, till they stopped supplying them. Roadsafe distributed them. They still do 555 tierod ends. 555 Japan if im correct? 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 17, 2014 Is road safe the brand that comes in orange and black boxes? If so I've used a couple of their bits too, lower ball joints in the wagon and a pitman arm in the ute, they both are holding up well. Share this post Link to post Share on other sites
gregaust 319 Posted January 17, 2014 I've used Wasp a few times have been good Share this post Link to post Share on other sites
Campo 869 Posted January 17, 2014 Mines got wasp in it (came with car when i got it ready to be installed) and havent had any dramas Share this post Link to post Share on other sites
mcfly94 169 Posted January 17, 2014 trw is probably the best on the market. hence there a bit dearer 1 revhead reacted to this Share this post Link to post Share on other sites
BigCav 464 Posted January 18, 2014 MOOG out of a Mercury is the BEST you can get, you just cant get them here trw/555/roadsafe paja are the best in aus at the moment, Wasp is a close 4th, for cheap stuff they have been good, trw and 555 are getting hard to find, roadsafe is available almost anywhere most of the time i use roadsafe Share this post Link to post Share on other sites
mattymc 30 Posted January 18, 2014 Some awesome advice guys thanks. Will have to see what I can get easily. Sent from my GT-I9505 using Tapatalk Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 18, 2014 I got all my TRW stuff from Repco. Share this post Link to post Share on other sites
BigCav 464 Posted January 18, 2014 was it the proper greaseable stuff or the newer sealed units? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 18, 2014 The newer sealed units, I've found it quite difficult to find anywhere that can get in the greaseable parts. Share this post Link to post Share on other sites
BigCav 464 Posted January 19, 2014 they are hit and miss with supply, i sell a few hundred a month and some all from the same suppliers, some come in sealed, the next week they come in greaseable, really annoying when a customer requests a certain type as you can never gaurantee supply wasp i found to be more oftern then not greaseable but who knows these days, i last looked into it probably 2 years ago Share this post Link to post Share on other sites
Ando81 2,950 Posted November 5, 2014 Has anyone used the red balljoint boots that you can buy on eBay? They say that they are better than standard rubber boots. I fitted some wasp balljoints 2 years ago and 3 out of 4 are fine but the bottom right has split and started to groan when I turn. I've just greased it and will replace it but might get a kit of red boots for $75 to replace the other 3 boots before they are shagged. Share this post Link to post Share on other sites
agentkiwi 110 Posted November 5, 2014 I've got a set but haven't fitted them yet because I replaced the ball joints less than 5000km ago. They look & feel the goods, doubt they'll split like the rubber ones do. I'd say go for it. 1 Ando81 reacted to this Share this post Link to post Share on other sites
Ando81 2,950 Posted November 5, 2014 Cheers mate, noticed this arvo that 2 are now split so I best order some. Share this post Link to post Share on other sites
Lott 35 Posted May 26, 2015 http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_05-2004_Falcon_Balljoints-Aug_2004.pdf Brand (Supplier) 4-bolt (early model) 3-bolt (late model)Ford OE (no longeravailable) OK OKQuinton Hazell QH (Ford) OK, has about 2mm shaftclearance when contactingbumpstopOK, has about 2mm shaftclearance when contactingbumpstopCTR (Titan Auto Parts) Similar or better than QH Similar or better than QHWJ Automotive (AutoStop) X Binds while 25mmsuspension travel remainsbefore bumpstop is reachedBinds while 25mmsuspension travel remainsbefore bumpstop is reachedSilverline (Repco) X Binds while 25mmsuspension travel remainsbefore bumpstop is reachedBinds while 25mmsuspension travel remainsbefore bumpstop is reached‘Camelot’ (George Stock &Co) marked ‘TRANS’X Binds while 25mmsuspension travel remainsbefore bumpstop is reachedBinds while 25mmsuspension travel remainsbefore bumpstop is reached555 (Titan Auto Parts) Example not found Example not foundThe three 2 XTREME KARTS XF and bear351c reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,925 Posted May 26, 2015 Excellent find good sir..... I've been wondering about this for years, but I think an Australian comparison test is in order. I might do just that in the near future, to see what brands are dangerous, and which brands work. http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_05-2004_Falcon_Balljoints-Aug_2004.pdf 555 - http://www.ebay.com.au/itm/Ford-Upper-and-Lower-Ball-Joints-OE-Style-/260756305446?pt=LH_DefaultDomain_15&hash=item3cb6497626 Share this post Link to post Share on other sites
bear351c 10,276 Posted May 26, 2015 Good luck finding anyone with original riveted ball joints. Looks like the 'new' ones have a raised cylinder bit around the ball.? Excuse my crude photoshopping, This might be something to look for when buying some. Share this post Link to post Share on other sites
