XTREME KARTS XF 1,212 Posted December 16, 2013 Hey fellas Sometime next year i want to convert my XD ute to 5 speed with a V8. Right now with funds the way they are im going to keep it auto (easier and more cost effective) when i do the V8 conversion over the xmas break (hopefully). My question to you guys is, What 5 speed box is best suited for a 351 cleveland? Share this post Link to post Share on other sites
ILIED 316 Posted December 16, 2013 TKO500 4 Trev Vaa, XTREME KARTS XF, Thom and 1 other reacted to this Share this post Link to post Share on other sites
blu xe 826 Posted December 16, 2013 Does the tko500 bolt straight up to a toploader bell housing and can you still retain the same hydraulic set up that the top loader was using? Would make for an easy bolt on upgrade if you've got a top loader fitted already. Share this post Link to post Share on other sites
BGDAV 1,892 Posted December 16, 2013 i ran a t5 out of a ef xr6 behind my 351 clevo for years and not one issue, if you respect the box it will be fine, if you thrash it like a idiot it will break, dellow for the bellhousing then sort out the hydralic clutch, the fuel bill went down massively with only changing that. well worth it 2 bear351c and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
ILIED 316 Posted December 16, 2013 I had a TKO500 bolt-in replacement for TopLoader.When I bought it, I checked and yes, it fitted directly to my existing bellhousing..The shifter was in the same position and the box was the same length. I ended up selling it on before using it as I wanted something rated more than 500lb/ft 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XF347 205 Posted December 16, 2013 I had a TKO500 and as above it uses a top loader bolt pattern and has a 10 spline input shaft so clutches are cheaper than if you go for a TKO600 which has a 31 spline input i think. I used it for about a year before going to an auto and it was a really good box. 2 XTREME KARTS XF and ILIED reacted to this Share this post Link to post Share on other sites
ILIED 316 Posted December 17, 2013 Did the rear crossmember need any mods, XF347? 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted December 17, 2013 Hey fellas Sometime next year i want to convert my XD ute to 5 speed with a V8. Right now with funds the way they are im going to keep it auto (easier and more cost effective) when i do the V8 conversion over the xmas break (hopefully). My question to you guys is, What 5 speed box is best suited for a 351 cleveland? Soo easy to go tr6060, i can show u how i got mine to work if u want Share this post Link to post Share on other sites
XF347 205 Posted December 18, 2013 Did the rear crossmember need any mods, XF347? Na mate a direct bolt in using the standard straight rear cross member. Share this post Link to post Share on other sites
blu xe 826 Posted December 18, 2013 So in saying that if your running a top loader already you only need the tko and its a straight change over. No other changes needed. Share this post Link to post Share on other sites
Ando81 2,953 Posted December 18, 2013 That sounds like a good Christmas project mate, 351 + 5 speed + 3.45 diff gears would = great fun I reckon 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XF347 205 Posted December 18, 2013 Not 100% sure but i believe so. I had a T5 in mine with a Dellow bellhousing. The TKO uses a top loader bolt pattern so I just had to redrill and tap my bellhousing with the correct bolt pattern. You also need a new tailshaft yoke as theyre are 31 spline output shaft. I didnt have to change tailshaft length and I already had a spare straight rear crossmember. Other than the retapping new holes in my bellhousing everything was complete bolt in. Share this post Link to post Share on other sites
ILIED 316 Posted December 18, 2013 Don't forget the shifter.If you don't buy a box with a shifter stalk, you'll need to get or make one.The T/L shifter is nothing like it Share this post Link to post Share on other sites
XF347 205 Posted December 18, 2013 Your right, but mine came with a shifter and the yoke as a deal. Share this post Link to post Share on other sites
78xcgxl 241 Posted December 21, 2013 Soo easy to go tr6060, i can show u how i got mine to work if u want I'm interested, Please post some pics and info on this. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted December 21, 2013 So it looks like the TKO 500 is the way to go, but what about the toyota boxes? like the steel case celica box (W50) and the supra boxes (W55-W59)??? Share this post Link to post Share on other sites
RAWDEAL 222 Posted December 21, 2013 So it looks like the TKO 500 is the way to go, but what about the toyota boxes? like the steel case celica box (W50) and the supra boxes (W55-W59)??? There a bit expensive for how old they are , but there pretty strong boxes. the money u save over buying one instead of a TKO, you would spend on buying a custom dellowect bellhousing IMO 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted December 21, 2013 toyota box = custom speedo, custom cross member, custon bell housing, custom clutch, custom tailshaft.. insert $500 for every "custom" word used. T5 = single rail V8 parts used= cheapest for a stock clevo. if a 2.92 or 2.77 diff is used, i'd stay with a single rail anyway = cheaper(or leave it auto) 3 PRO250, Stevemack and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted December 21, 2013 toyota box = custom speedo, custom cross member, custon bell housing, custom clutch, custom tailshaft.. insert $500 for every "custom" word used. T5 = single rail V8 parts used= cheapest for a stock clevo. if a 2.92 or 2.77 diff is used, i'd stay with a single rail anyway = cheaper(or leave it auto) Dellow make the bellhousing to suit, along with the spigot bearing and clutch disc (you just bolt your pressure plate to dellows conversion disc). It'll be auto for now as the donor car i picked up is auto, i was thinking the toyota box "just" to be different, i'll ask neil (rocket) about the toyota box conversion he did in his XF ute. Share this post Link to post Share on other sites
deankxf 21,128 Posted December 21, 2013 Dellow make the bellhousing to suit, along with the spigot bearing and clutch disc (you just bolt your pressure plate to dellows conversion disc). It'll be auto for now as the donor car i picked up is auto, i was thinking the toyota box "just" to be different, i'll ask neil (rocket) about the toyota box conversion he did in his XF ute. supra box W58 are ok, but the cost will be heaps more than a T5 Share this post Link to post Share on other sites
Ants 6,370 Posted December 22, 2013 Toyota boxes are hard to find, expensive,and relatively weak for the cost. go with a t5 if dollars are tight go with a tremec if you can afford to splash. Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted December 23, 2013 t5 will work, but if you abuse it, it WILL break. tko500/600 OR other option, go to the wreckers, get a 6speed T56 out of a GMH, way stronger than the t5 plus extra gear, just make sure its a holden one, the ford ones don't have a speedo pickup on the side of the box, except maybe a ute? i remember they used to, don't know about now. $$$ wise if you wanna do it on the cheap, T5, if you want to do it properly, i'd go a T56, if you have a lot of cash, T56 magnum. advantage of the t56 is you can run 3.9s in the ass and then cruise at 2000rpm at 110. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
ILIED 316 Posted December 23, 2013 Best mate had a BF11 XR6T ute.Used to melt the ABS sensor on the diff, as a result the speedo would fuckup and go erratic.I think they went to the T6060 for them, too, didn't they? For some reason I was under the impression the BA11 was the only Falcons to use the T56 Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted December 23, 2013 not too sure on that one chaise, i know my best mates BA MKII definitely has the T56, but i thought they only went the TR6060 on the FG? i could be wrong though, i've only worked on a few BF manuals. i'm pretty the early BA utes had the speedo sensor on the side of the box (maybe switched on BF??? dunno) i know all the sedans used the wheel speed sensor for speedo pickup. i know the holden t56 has the speedo input on the side of the box because i've used that before on other cars to do a t56 conversion, plus they have a stronger input shaft. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
