mcfly94 169 Posted July 18, 2013 Im trying to soften up my suspension as its to harsh for bumps and everyday driving. I have full nolathane through the front, all new control bushes, sway bar, ball joints, radius rod. 20mm Shock tower spacers and bump stops shortened 25mm. Shortened shocks, which I plan on replacing with koni red adjustables. Will they give me a nice ride?I also have superlow kings in the front, so im actually thinkning about raising the car up a bit. I also run 205/65 15 tyres. What else can cause such a rough ride? Share this post Link to post Share on other sites
xeeclipse 37 Posted July 18, 2013 60+ tyres and some low springs will fix it. These cars don't like being lowered or jacked up excessively because the camber bolt has very little adjustment to compensate for the unequal arm length. Share this post Link to post Share on other sites
mcfly94 169 Posted July 18, 2013 60+ tyres and some low springs will fix it. These cars don't like being lowered or jacked up excessively because the camber bolt has very little adjustment to compensate for the unequal arm length. well ive already got 65's , reason I ditched the 222/50 ftrs. Im really thinking the poor quality no name shocks have something to do with it also Share this post Link to post Share on other sites
KRUPTOR 929 Posted July 18, 2013 little suspensions travel will make the ride rougher,also rough roads will too.If you want a smooth ride,then stock suspension will do.What your chasing is suspension travel. Share this post Link to post Share on other sites
mcfly94 169 Posted July 18, 2013 little suspensions travel will make the ride rougher,also rough roads will too.If you want a smooth ride,then stock suspension will do.What your chasing is suspension travel. I have 70mm travel on the rear and about 25/30mm front. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 18, 2013 Id get rid of half that nolathane to. Replace it with the standard Kelpro gear. 1 bear351c reacted to this Share this post Link to post Share on other sites
KRUPTOR 929 Posted July 18, 2013 Id get rid of half that nolathane to. Replace it with the standard Kelpro gear. Honestly i would go rubber/genuine bushes. Share this post Link to post Share on other sites
bear351c 10,273 Posted July 18, 2013 I have full nolathane through the front, all new control bushes, sway bar, ball joints, radius rod. Thats your problem..... Share this post Link to post Share on other sites
mcfly94 169 Posted July 18, 2013 Honestly i would go rubber/genuine bushes. do they really make that much of a difference over nolathane?, as they have tightened the feel and the car is more responsive and hardly sloppy and I haven't even changed my stuffed steering box yet. Do spring saddles make a difference, mine are the factory ones? Share this post Link to post Share on other sites
revhead 1,392 Posted July 18, 2013 no spring saddles only insulate the diff from the springs anf yes rubber is much better then nolathane ,and there is a marked difference between them with rubber you get give with nolathane you might as well be using brass bushes, Share this post Link to post Share on other sites
Mr Polson 10,214 Posted July 18, 2013 Kings springs wouldn't help, pretty sure they're stiffer. I have kings in my ute and Peddlers in my wagon, the pedders definitely provide a better- should say smoother- ride. Share this post Link to post Share on other sites
bear351c 10,273 Posted July 18, 2013 Yep, what Rev said. Nolathene will last 4 times longer, but, with that strength you get harshness. Use Nolathene on the hardest wearing parts, like sway bar links. As you've stated, your car is now firm and corners on rails, but, all the screws will fall out of your dash in 12 months. . . . . (King springs are 15% firmer than standard springs, no matter what height) 2 revhead and Thom reacted to this Share this post Link to post Share on other sites
mcfly94 169 Posted July 18, 2013 Yep, what Rev said. Nolathene will last 4 times longer, but, with that strength you get harshness. Use Nolathene on the hardest wearing parts, like sway bar links. As you've stated, your car is now firm and corners on rails, but, all the screws will fall out of your dash in 12 months. . . . . (King springs are 15% firmer than standard springs, no matter what height) haha I have actually needed to tighten things down a lot tighter! Share this post Link to post Share on other sites
revhead 1,392 Posted July 18, 2013 haha I have actually needed to tighten things down a lot tighter! go and buy some locktight this will help Share this post Link to post Share on other sites
slydog 7,873 Posted July 18, 2013 Spring are for ride height,shocks are for ride control in basic terms,so by getting softer but progressive rate springs for it and a firmer rate shock the ride will improve and it will handle better to boot. 1 revhead reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted July 18, 2013 do they really make that much of a difference over nolathane?, as they have tightened the feel and the car is more responsive and hardly sloppy and I haven't even changed my stuffed steering box yet. Do spring saddles make a difference, mine are the factory ones? Yes, having the nolathane will make the car feel tight, will turn into corners a bit better thus improving your steering but... the nolathane is hard as, not like rubber where it is softer so gives a more cushioning effect. The spring saddles are fine. Unless your's are flogged out no need to replace. Nolathane spring saddles are like $150 a pair give or take standard jobbies are half that price and some come with a grease nipple Sway bar mounts keep in nolathane, idler arm in nolathane, The radius rod bushes id change back, and id replace the shortend shocks you have for a standard pair in ultima, or pedders. I have 2 x falcons one has Kings and the other has Pedders. My falcon with pedders is far better than kings so perhaps a future spring change aswell for you? 1 bear351c reacted to this Share this post Link to post Share on other sites
ZL. 19 Posted July 18, 2013 you cant have good cornering/steering and a good ride over bumps, theyre polar opposites. just pick one and live with the pro's an con's. and superpro is better than nolothane IMO. 1 thunderbolt reacted to this Share this post Link to post Share on other sites
PSI_LTD 37 Posted July 19, 2013 you cant have good cornering/steering and a good ride over bumps, theyre polar opposites. just pick one and live with the pro's an con's. and superpro is better than nolothane IMO. not necessarily - only if you're referring to cheap suspension. 1. ensure the car is not hitting the bumpstops. raise on 'low' springs not superlows. superlows arent stiff enough to compensate for lowered ride height 2. shock absorber tuning. with good adjustable shocks, you can adjust the shock stiffness, depending on specific driving condition. bigger piston diameters can also get better control, without butchering the ride quality. name of the game is controlling high speed rebound / compression. 3. vibration + harshness from the bushing. blame nolathane. replace with std rubber. 4. wheel + tyre weight. heavier wheels have more momentum, therefore will work your suspension harder. Share this post Link to post Share on other sites
ZL. 19 Posted July 19, 2013 not necessarily - only if you're referring to cheap suspension. 1. ensure the car is not hitting the bumpstops. raise on 'low' springs not superlows. superlows arent stiff enough to compensate for lowered ride height 2. shock absorber tuning. with good adjustable shocks, you can adjust the shock stiffness, depending on specific driving condition. bigger piston diameters can also get better control, without butchering the ride quality. name of the game is controlling high speed rebound / compression. 3. vibration + harshness from the bushing. blame nolathane. replace with std rubber. 4. wheel + tyre weight. heavier wheels have more momentum, therefore will work your suspension harder. Yes i agree with that, although in my experience you either have lowered suspension which corners awesome and rides like shit over bumps/shit roads or standard height suspension which corners like a boat almost but floats over the potholes like a cloud. Share this post Link to post Share on other sites
Wes 214 Posted July 19, 2013 Everyone rushes to nolathane. There's the problem. I sit all my cars on lower than ultra lows, good shocks and rubber bushes and never have ride discomfort. Might be a different story when I get the 20's going but we'll see. Share this post Link to post Share on other sites
thunderbolt 150 Posted July 19, 2013 an xf has a smooth compliant ride as standard but even with HD springs and nolithane bushes they still aren't like a lowed VB-VKcommodore for hashness Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 29, 2013 Its all about matching your spring rate to shock rate. Bit of a black art, but look for a progressive rate coil if you can get it in a lower format, and fit shortened bump stops, as these things have fuck all travel when lowered. Share this post Link to post Share on other sites
