gerg 10,871 Posted December 27, 2017 I don’t want to sound like a smart arse but I think dex might have been suggesting that the motor should be turned over so that when pulling the rockers down that it’s not fighting valve spring tension. That’s just the way I understood what he was saying as previous conversation was that the motor shouldn’t be turned over too much without oil being properly primed up I've never worried about tightening down rocker bolts when the valve happens to be open. I just put plenty of grease on the thread so it doesn't chew out, and go slowly with the rattle gun. The bolts are grade 8 so can take a beating. Best scenario would be to use 5/16" studs unc one end, unf the other (short of going 7/16" stud conversion) Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
dex 2,065 Posted December 27, 2017 3 hours ago, Ando81 said: I don’t want to sound like a smart arse but I think dex might have been suggesting that the motor should be turned over so that when pulling the rockers down that it’s not fighting valve spring tension. That’s just the way I understood what he was saying as previous conversation was that the motor shouldn’t be turned over too much without oil being properly primed up Thats exactly the direction i was going with the question , have heard of pushrods being bent trying to fight against valve spring tension . Ive always done rockers up by winding over to get the cam lobe away from the lifter on each available cylinder Share this post Link to post Share on other sites
dex 2,065 Posted December 27, 2017 3 hours ago, Ando81 said: I don’t want to sound like a smart arse but I think dex might have been suggesting that the motor should be turned over so that when pulling the rockers down that it’s not fighting valve spring tension. That’s just the way I understood what he was saying as previous conversation was that the motor shouldn’t be turned over too much without oil being properly primed up Thats exactly the direction i was going with the question , have heard of pushrods being bent trying to fight against valve spring tension . Ive always done rockers up by winding over to get the cam lobe away from the lifter on each available cylinder 2 Ando81 and PapouGhia reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 27, 2017 If pushing a valve down with the rocker is enough to bend a pushrod, wouldn't you just bend all of them the first time you cranked the engine?Sounds more like another problem like the cam timing being out and tightening a valve down on top of a piston.Sent from my CPH1607 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
PapouGhia 33 Posted December 27, 2017 Cheers all for the feedback, I’m going to let them sit in a container of oil overnight, hopefully by Saturday I’ll have some time to install them back in and get everything back together. And fingers crossed it works as I’m nearly at the stage of cracking it, also what do you all use as a sealant for the rocker? Some say use a gasket some say don’t? Use the gasket glue from the gun ect... anyone around the Melbourne,Mount Waverley area to assist with this process on Friday or Sat night? Cheers Emilio Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted December 27, 2017 Just use silicon and just a smear Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 27, 2017 I've never used a paper gasket on my EFI xflows and they don't leak. Up until recently I've just used a light smear of grey or black "Sika" gasket RTV.Earlier this year though I bought a Speco rubber rocker cover gasket and installed that. You will probably need longer bolts to be able to clamp it down if you went that way. Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
PapouGhia 33 Posted December 28, 2017 Are the lengths of the pushrods the same on carby and efi models? Heading to wreckers at the moment cheers Emilio Share this post Link to post Share on other sites
deankxf 20,288 Posted December 28, 2017 7 minutes ago, Emilio said: Are the lengths of the pushrods the same on carby and efi models? Heading to wreckers at the moment cheers Emilio yeah, would be. Share this post Link to post Share on other sites
PapouGhia 33 Posted December 28, 2017 Just got all the rockers and pushrods and lifters out, some where easy some where difficult, didn’t take more than 25 mins though, was very helpful I had an extendable magnet that could pick them up once pulled fully out,looked at all of the lifters all are same size and one is like slight slightly shorter, not sure if it’s just my eyes though, When reinstalling the lifters, they will have to go in on an angle as I can’t get them straight in on every second rocker if that makes sense. I have uploaded photos on imgr if you would like to see. And is there a way I can share them in comments so I don’t have to send link? https://imgur.com/user/dimaaa3125 Cheers Emilio Share this post Link to post Share on other sites
Mr Polson 10,214 Posted December 28, 2017 Put [ I M G ] before the link and [ / I M G ] after the link, but without the spacesSent from my Pixel using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted December 28, 2017 Did you keep them in order (ie: each one back in its original hole)? Very important!Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
PapouGhia 33 Posted December 28, 2017 Yes All in order mate,going tomorrow to get some assembly lube, the new lifters are in a bucket right now pruning up hopefully tomorrow I can go putting all together! Will keep you guys posted if you like, new to this forum but loving the experienced help. 2 Ando81 and gerg reacted to this Share this post Link to post Share on other sites
PapouGhia 33 Posted December 28, 2017 https://imgur.com/gallery/oMx6W Share this post Link to post Share on other sites
deankxf 20,288 Posted December 28, 2017 looking forward to hearing if its sorted hydraulic lifters bleeding in tub of oil Share this post Link to post Share on other sites
PapouGhia 33 Posted December 28, 2017 Cheers, hopefully I can get this sorted, one of the lifters was shorter though, the rest where all about the same,ahh it’s still being a pain trying to upload a photo not just the link! Tomorrow I’ll be installing the lifters, pushrods and rockers on Saturday. Hard to get time off work Share this post Link to post Share on other sites
deankxf 20,288 Posted December 28, 2017 if one of the lifters was shorter the cam is probably wiped in that spot, that one will probably be noisy still.. either way it will run a bit rough also probably. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted December 28, 2017 Definitely should be all the same height. If one is shorter, you need a cam swap, too. Look carefully at the base of the short one. Share this post Link to post Share on other sites
Thom 6,651 Posted December 28, 2017 If one lifter is shorter your cam is junk you will need a new one and a new set of lifters, you will find that the lobe the shorter lifter came from is worn down too and there is no way you could put it back together without a new cam and lifters without it being noisey and running rough Share this post Link to post Share on other sites
PapouGhia 33 Posted December 29, 2017 It’s more temperamental at the moment guys till I get the funds to do the whole rebuild.ill keep you guys posted how it goes, hopefully can get in all together tonight had a early finish!!! Share this post Link to post Share on other sites
Thom 6,651 Posted December 29, 2017 That's not a good Idea, the dead cam lobe will wipe out the brand new lifter immediately and you will end up with metal all throughout your engine potentially destroying the whole thing 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted December 30, 2017 I’m with Thom... youll be doing a rebuild shortly. Easier to fix it now properly. Saves labor too. and it costs nothing to put something nicer in there but being efi anything bigger than a bees dick and it will drive shit. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 31, 2017 "The bitterness of poor quality remains long after the sweet taste of low price is forgotten""the poor man pays twice"Never a truer word spoken, in each instance.Here's a good, well-priced, decent quality cam for you (it's the "stage 1")http://www.precisionintl.com/BrandSearch.aspx?Brand=Dynotec&Make=22&Model=&Engine=446Sent from my CPH1607 using Tapatalk 2 stockesp and Valvebouncer reacted to this Share this post Link to post Share on other sites
PapouGhia 33 Posted January 1, 2018 How am I meant to get the first and last lifter in!!? You don’t have enough space to get it in with the magnet or the puller through the top! Is there a specific way to get it in? Or just keep trying! Getting so close guys! Thanks for all the feedback as well hope I can come out for a cruise once it at least steady build Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 1, 2018 Head off for front and back lifter.Well that's the easiest way anyway. From memory you may be able to put them down the larger cavities and try and get them into the correct holes, but when I done mine years ago (XF wagon, EFI, wiped a cam lobe), I just gave up and took the head off.Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
