SLO247 1,713 Posted August 4, 2016 What type of ball joint seperators are you using on your X Series? I've always used a fork type and it worked perfectly until today. I can't get the upper joint out of the upright. Is it worth trying the claw type with the threaded bolt? This one is bloody stuck. It's already had a good belting which hasn't helped. Share this post Link to post Share on other sites
winton 399 Posted August 4, 2016 I've always just give cast metal a good wacking with a hammer. Could be time to apply heat. 1 deankxf reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted August 4, 2016 hmmm. i usually try to remove with hammer and dolly. If that dont work i go fork separator. if that don't work i get a bigger hammer. if it still don't come off i get my biggest hammer and belt it till something brakes... The joint, the fork, the hammer, or me. Something always gives 100% of the time Guaranteed something will separate. I've never had to go as far as using heat but that might be what you gotta do if it really is that stuck? You have taken the nut off right? =P 1 steve mcqueen reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted August 4, 2016 Yeah I checked the nut was off like 5 times haha. Fucking thing. I don't have heat, I'll try more belting tommorow. I even put another bar over the fork handle and stood on it. Still didn't move! Share this post Link to post Share on other sites
hendrixhc 10,920 Posted August 4, 2016 Go for a light tap all around the cast part to break the taper and then focus all your energy on one sharp blow to the thread and it will pop. You need to focus though. Share this post Link to post Share on other sites
FOMOCOHO 882 Posted August 4, 2016 There's an old fitter's trick with tapers. It works on tie-rod ends every time I find. Don't need a bigger hammer, just need two hammers (engineer's 2 pound is fine). I'm not sure if you can get to opposite sides on the upper ball joint from memory but if you can shock it at the same time with a blow from each side... this should expand the cast housing momentarily and break the seal. Then use your usual tools/method & it should come out. 1 hendrixhc reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 4, 2016 Put a pipe through the lower arm and into the castor rod, get your fattest friend to stand on it. Now belt the living f&@k out of that top joint, it'll pop. It's easier with the caliper and disc removed too- less things to hit with a stray hammer Share this post Link to post Share on other sites
gerg 10,871 Posted August 4, 2016 +1 hammer & dolly. You can't just whack it from one side though. I like to get a decent thump-o-meter on the opposite side to where you're hitting so there's some inertia to hit against, otherwise the whole lot just bounces. If you must apply heat, don't go any more than a couple of hundred degrees otherwise you'll weaken the high strength metals.<br /><br /><br />Sent from my iPhone using Tapatalk 2 stockesp and FOMOCOHO reacted to this Share this post Link to post Share on other sites
FOMOCOHO 882 Posted August 4, 2016 +1 hammer & dolly. You can't just whack it from one side though. I like to get a decent thump-o-meter on the opposite side to where you're hitting so there's some inertia to hit against, otherwise the whole lot just bounces. If you must apply heat, don't go any more than a couple of hundred degrees otherwise you'll weaken the high strength metals.<br /><br /><br />Sent from my iPhone using Tapatalk That's what i was trying to say gerg... 2 hammers be better than one, you 'ol fitter you! 1 gerg reacted to this Share this post Link to post Share on other sites
Panko 2,480 Posted August 5, 2016 My grand father made a good one up. its a piece of running tube thread, with a bolt out each end. sit it between the two ball joints, and load it up by turning it, works as a spreader, then whack the ball joint housing your trying to crack with 2 hammers, 1 each side of the ball joint. it doesn't often crack the first time, so once you've got it to move a bit, load the spreader up again, and hit it again. usually cracks after 3 hits. i got all my original balls joints in the xf to crack in 1 or 2 hits. if it was in my garage id go grab a photo of the tool, but i think its in my grandfather's garage. 1 gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted August 5, 2016 Bears motto Long hammer - Short temper Dan, I have a butane torch here, and a fork, if you need it. 1 SLO247 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 Torch may be the go, I'll try two hammers and or a dolly today. Need to grab that door handle off you anyway. 1 bear351c reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 I'll try again today, thanks for the all the tips. Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 Well the two hammer trick worked, after a few good knocks I belted it out from underneath. Thanks Now what do I use to knock the hub seals into the new discs? I can't remember how I used to do it, been many years and even then I think I used to damage the rubber a bit fitting them. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
FOMOCOHO 882 Posted August 5, 2016 Empty tomato/soup/whateva tin... upside down (ie open side against seal). Whichever you can find that sits in the middle of the seal. I think the 'champignon mushroom' tins are good (with or without butter sauce, doesn't matter! ) as they're only half height (so stronger). You'll need a new tin for each seal though as they will crush some. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted August 5, 2016 Or a large socket that "just" fits into the hub without the seal there. Or a piece of water pipe, or a stick...... Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 Turns out the seals had a flat rubber lip that fits over the outside of the hub. Just knocked them on with the dead blow, done perfectly. Don't look anything like the e series ones I've done in the past. Share this post Link to post Share on other sites
hendrixhc 10,920 Posted August 5, 2016 Well the two hammer trick worked, after a few good knocks I belted it out from underneath. Thanks Now what do I use to knock the hub seals into the new discs? I can't remember how I used to do it, been many years and even then I think I used to damage the rubber a bit fitting them. What discs are you using? Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 Just standard RDA. Share this post Link to post Share on other sites
hendrixhc 10,920 Posted August 5, 2016 I gotta get some new brakes on the ute. I been looking at brand called Tora. They seem to be reasonably priced and get good reviews. Share this post Link to post Share on other sites
SLO247 1,713 Posted August 5, 2016 I've just always used RDA as they are cheap on eBay. Never had a problem and have bearing cups already fitted. Usually fit slotted ones but the ute is light and has no power so I didn't bother. 1 hendrixhc reacted to this Share this post Link to post Share on other sites
adrianphu123 73 Posted August 5, 2016 I used a pitman arm puller, broke it, sent it back under warranty and got a new. Used it again and it worked second time around 2 gerg and SLO247 reacted to this Share this post Link to post Share on other sites
