XFGHIA747 76 Posted November 7, 2014 Hey guys I have leaking centre in one of my simmons 3 piece does any one know the best way to stop it ? Without opening the rim up, if so please share. As I dont think running a solid bead of silicone around the join would last ? I may be wrong. Also if I need to separate the rim the re seal what id the torque spec on the bolts ? I may have read somewhere it was 20-25 ft pounds? Cheers Share this post Link to post Share on other sites
Campo 869 Posted November 7, 2014 Dont they seal them with polyurethane? 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
xm-221 1,803 Posted November 7, 2014 As you've said,take the tyre off and run a bead of polyurethane around the inside join of the rim. 2 slydog and Trev Vaa reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted November 7, 2014 Clean all the old sealant off 100% and then apply a nice neat continuous bead of sikaflex or similar in the join. Remember more does not equal better. 3 XTREME KARTS XF, Ants and Stevemack reacted to this Share this post Link to post Share on other sites
Ants 6,370 Posted November 7, 2014 I've siliconed mine and they never leak. But as clint said make sure you clean all the old stuff off. 3 PRO250, n00bus m@x1mus and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted November 7, 2014 ^^^^^^^^that or as clint has said Share this post Link to post Share on other sites
bear351c 10,271 Posted November 7, 2014 Buy an inner tube........... Share this post Link to post Share on other sites
Stevemack 122 Posted November 7, 2014 I split them. cleaned them, then used silicone to join them, then ran a bead of urethane over the join once the silicone had dried. Bobs your uncle. Share this post Link to post Share on other sites
XFGHIA747 76 Posted November 7, 2014 Thanks guys will get onto it tomorrow then hopefully it will be right, ill just clean real well and wax grease remover the join and run a nice bead around there with a iceypole stick if id doesn't fix it ill split the rim later on.. Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted November 8, 2014 A tip if your worried u wont get a neat finish, inject your nice wide bead of sika or silicone into the groove making sure u get it evenly over the join. Dony care too much for a finish as this stage just make sure u get the sealant thats touching the rim in an even fashion. Then grab the missus's ironing spray bottle or something similar, mix up some dishwashing liquid and water into a nice sudsy mixture and fill the bottle up. Then grab ur old pair of thongs or something else with a flat bendable edge (credit card works or proper bog trowel) and spray thr sealant generously and simply wipe the thong over itto flatten it out. Wipe the excess off on a rag and repeat. The soap will stop the sealant from bonding to where the soap is so u cant smear it all over the rim. Once ur done leave to cure. Share this post Link to post Share on other sites
XFGHIA747 76 Posted November 14, 2014 Well re sealed the rim with a nice bead of silicone and bobs ta uncle holding up nicely so far so good thanks for the advice lads.. 2 Ants and Trev Vaa reacted to this Share this post Link to post Share on other sites
Ants 6,370 Posted November 14, 2014 Good to hear mate. Share this post Link to post Share on other sites
PRO250 1,506 Posted November 14, 2014 Yay for no more leaking tyres Share this post Link to post Share on other sites
Thom 6,651 Posted November 14, 2014 It's good when wheels and tires are capable of retaining wind 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
