PRO250 1,506 Posted June 2, 2014 Hi guysare they all the same? im about to reco one but i dont know if its the same as say a GL? Share this post Link to post Share on other sites
hendrixhc 10,921 Posted June 2, 2014 I was told they are all the same. Share this post Link to post Share on other sites
BigCav 464 Posted June 2, 2014 yes, there were slight changes in xe to the steering box internally but they are the same shit, once rebuilt they will have xg upper bearings etc anyway, the xe boxs are a bit nicer box standard though but they just made running improvements to them, they arnt any different cause its a ghia though note that the hose outlets on the top of the box vary, there are 3 (could be 2, i forget) different types so if your not using the exact box out of the car then double check if your looking for someone to do it then the club has an affiliation with prestige power steering, paul over there gives us a discount 1 Outback Jack reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted June 2, 2014 Cheers for the input guys i was just unsuremine works fine but it leaks hoping to pull down fit seals and put back together Share this post Link to post Share on other sites
Gaz 1,085 Posted June 2, 2014 They're all exactly the same internally except XAGT which had a different worm and XG had the roller cap. The only difference externally is that all XD/ZJ/FC had the longer return tube. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted June 2, 2014 I was told they are all the same. Except yours would be chrome 1 hendrixhc reacted to this Share this post Link to post Share on other sites
BigCav 464 Posted June 2, 2014 i know they rebuild the same etc gaz but they have different part numbers on the worm drive, plus i remember reading threw ford documents saying they changed it to offer a better steering feeling etc ill happily bow to your experiance, your probably touched more boxs (power steering lol) then i touched myself as a 13 year old but ill show you this just incase 2 Outback Jack and hendrixhc reacted to this Share this post Link to post Share on other sites
Gaz 1,085 Posted June 2, 2014 Don't believe everything you read Cav. If anyone anywhwere can tell me there was an actuall difference in XA3524A and XD3524A apart from the material that the spool is made out of, then I'd hang my head in shame. Even the fact that I mentioned XAGT is only because it's well documented, even though I could never "feel" any difference on the test rig. Orange stripe boxes were right angle outlet. 2 BigCav and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted June 3, 2014 is it easy to fit seals garry? Share this post Link to post Share on other sites
hendrixhc 10,921 Posted June 3, 2014 Easier to pay someone to do it! (Cant believe i said that.) I just got a change over box for $260. Share this post Link to post Share on other sites
PRO250 1,506 Posted June 3, 2014 Id be keen to give it a try if its to hard i can pay then Share this post Link to post Share on other sites
Gaz 1,085 Posted June 3, 2014 Nah they're a cunt. They have teflon seals on the worm and on the piston which need streching to fit, and then they have to be compressed before they will fit in their respective bores. If they're not compressed properly you'll nick the seal and it's game over. And the worm seal is loaded from the inside Special tools all the way. And the preloads are critical, and the sector gear wears which make correct lash near impossible unless they're reground. Easier and less of a headfuck to buy a changeover. But give it a crack if your confident. 3 gerg, XTREME KARTS XF and BigCav reacted to this Share this post Link to post Share on other sites
BigCav 464 Posted June 3, 2014 trade price available from prestige power steering in thomastown if you drop the club name to paul 2 Ando81 and PH351 reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted June 4, 2014 Nah they're a cunt. They have teflon seals on the worm and on the piston which need streching to fit, and then they have to be compressed before they will fit in their respective bores. If they're not compressed properly you'll nick the seal and it's game over. And the worm seal is loaded from the inside Special tools all the way. And the preloads are critical, and the sector gear wears which make correct lash near impossible unless they're reground. Easier and less of a headfuck to buy a changeover. But give it a crack if your confident. arr shit now i dot want to do it LOL Share this post Link to post Share on other sites
Thom 6,654 Posted June 4, 2014 Ok heres one for you gaz, can the guts off an xy 16:1 box be fitted into an xe manual housing? Share this post Link to post Share on other sites
Gaz 1,085 Posted June 4, 2014 Yes Thom. The only difference in the housing is the lower mounting hole being half a hole out. If you ever see or know anyone wrecking an early Fairlane or Falcon/Fairmont with ram steer, (XR/T/W/Y or ZA/B/C/D) grab the box out of it. It's exactly the same as every other 16:1 with a different pitman arm. And in fact they usually rebuild better because there's been less load on the worm bearings. Share this post Link to post Share on other sites
Thom 6,654 Posted June 4, 2014 That's exactly what I've got, I modified the customline to takd an xe manual box, but it could seriously do with a quicker steering ratio Share this post Link to post Share on other sites
Gaz 1,085 Posted June 4, 2014 Perfect. But why don't you just re-modify it to take the XY box? It's only half a hole. Share this post Link to post Share on other sites
78xcgxl 241 Posted June 4, 2014 XA-XE boxes are the same and have a 2.6 turns lock to lock ratio. XF and XG boxes have a slightly quicker turn lock to lock ratio at 2.4 turns. XG boxes are the only boxes to have factory fitted roller-bearing top but runs two metric hard lines and not a crappy hose and clap on the return line like earlier models (far better and far less prone to leaks). XG boxes are the best and XF boxes can easily be converted to XG specs by fitting a roller bearing top but you will retain the standard imperial fitting and hose can clap. The steering ratio of these boxes are sensational and much better than later model e series rack and pinion with ratios at over 3 turns lock to lock. Even a RRS rack for a X series falcon is at 3 turns lock to lock so more of a downgrade if anything. If setup right these P/S boxes are better than a rack and pinion kits. Share this post Link to post Share on other sites
Gaz 1,085 Posted June 4, 2014 XA-XE boxes are the same and have a 2.6 turns lock to lock ratio. XF and XG boxes have a slightly quicker turn lock to lock ratio at 2.4 turns. (cough cough bullshit) Share this post Link to post Share on other sites
78xcgxl 241 Posted June 4, 2014 Cough all you like, i thought the same but i recently changed the box in my XC to a XG one as i'm doing a 4.0l conversion. I calculated the lock to lock ratio of the XC box prior to installing the XG box and the difference in lock to lock ratio was noticeable. Share this post Link to post Share on other sites
Gaz 1,085 Posted June 4, 2014 Lock to lock has nothing to do with ratio. Any number of factors can affect lock. I thought a lot of things too, but having rebuilt aproximately 2000 or more of these boxes by hand, and then probably another 1500 using the original machinery from the Kirby Bishop factory, and in the early years also fitting at least 500 of them in cars, I can state categorically that there is absolutely no difference in ratio whatsoever. But I will also say that your vast experience of changing 1 steering box far outweighs my small amount of knowledge and I humbly defer to your ownership of this non-existant argument. 2 BigCav and Mr Polson reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted June 4, 2014 Perfect. But why don't you just re-modify it to take the XY box? It's only half a hole. That half a hole means notching the rail, personally I'd rather rebuild a steering box Share this post Link to post Share on other sites
PRO250 1,506 Posted June 4, 2014 Good thing i asked if there the same, could have been me getting owned by garyI was going to put a 4litre vs crossy joke here, but well um you know 1 BigCav reacted to this Share this post Link to post Share on other sites
