Mixalis 266 Posted February 6, 2014 Top Stuff Jason! really enjoying the thread Share this post Link to post Share on other sites
TF_250 398 Posted February 15, 2014 Update... Welded some new metal into the corners of the engine mounts and re drilled the holes, you wouldn't know there modded Then onto the exhaust, first the flange had to be changed to DOHC, then pipes 1 and 6 had to be modded because the nature of the port in the dohc head the exhaust ports are centre in the chamber where as the xflow is towards the rear., so my pipes had to come forward to meet the port, no bigggy except when that is done the pipes clash with the engine mount so they have been cut and re welded and # 6 looks a little strange because all the primary pipes are the same length as each other so 6 is now the same as well. I think after the dyno i'll get them coated black this time the silver really go's to shit IMO!! 2 Mixalis and Outback Jack reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted February 15, 2014 Nice work bro...very thorough as usual.I'll be sending mine to Tuffy Toned in Sydney to be coated and @ $280ish from memory and yes in Black. Share this post Link to post Share on other sites
ando76 4,354 Posted February 15, 2014 great work on the tubes and the mounts Jason. really coming along nicely. Share this post Link to post Share on other sites
TF_250 398 Posted February 23, 2014 Modded the firewall for starter clearance another item off the list. 2 dougie77 and Mixalis reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted February 23, 2014 Nice Jase...Didn't see that coming though. Share this post Link to post Share on other sites
P100_Ute 460 Posted February 24, 2014 Nice work mate. i havent touched mine since i had my kid. days been spent sleeping trying to catchup on sleep i miss at night hah. Waiting on my fabricator to finish off some work for me but he been on holidaze Share this post Link to post Share on other sites
TF_250 398 Posted March 2, 2014 Fitted the ATI balancer but it was to far foward for me so i had 9mm machind off the back nice and close now Back in the car coming together nicely, the wooden piece in between the manifold and head is to test the dimensions will be made in alloy. 2 Ants and Outback Jack reacted to this Share this post Link to post Share on other sites
PRO250 1,506 Posted March 2, 2014 gee thats looking okhow are you going with no dissy? your old setup ran coil packs and crank trigger you can just run that? Share this post Link to post Share on other sites
TF_250 398 Posted March 2, 2014 gee thats looking ok how are you going with no dissy? your old setup ran coil packs and crank trigger you can just run that? Yeah mate its getting there. The xflow ran a dizzy with 1 tooth and the crank trigger. the DOHC has what would be the dizzy sensor on the back of the camshaft and has the same 36-1 crank trigger behind the balancer in the engine. So will be run the same way. If i use the std ford coil that came with the motor i have to buy ignighters to fire them as the ecu cant do that, that's why i use the LS3 coils as they will do the job and have built in ignighters and i already had them just had to remake a couple of leads and i can still fit the p[plastic cover. Share this post Link to post Share on other sites
ando76 4,354 Posted March 2, 2014 so the crank trigger lives behind the timing cover in these engines? Nice work Jason. Did you weigh the old engine and the new? thinking that the later motor would be a tad heavier??? Share this post Link to post Share on other sites
TF_250 398 Posted March 3, 2014 Yep it's the bottom timing chain gear as well all one. I'd say it will be heavier it's basically a crossflow without push rods and with one more cam, 12 more lifters,valves and springs, alloy sump, main girdle, larger timing chain, cam gears etc so yeah it will be heavier Guess I'll have to make a bit more power then 2 slydog and Outback Jack reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted March 4, 2014 coming a long very nicely. You will be running in no time. Share this post Link to post Share on other sites
ando76 4,354 Posted March 5, 2014 thanks Jase - that is very cool - wonder if I could squeeze that in behind a crossflow timing case??? Mad scientist in my thinking out aloud again..... looks great. down in vegas atm but way too busy to drop in... keep up the good work Share this post Link to post Share on other sites
TF_250 398 Posted March 11, 2014 Got the ecu to drive this now, can't get over how small is is!! It will do every thing including full cam control And fly by wire and 120mb of logging. 1 Mixalis reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted March 11, 2014 Nice ECU Jason - Top shelf MOTEC and what a smart little package. Data logging will be very helpful. Share this post Link to post Share on other sites
Clevo120Y 815 Posted March 14, 2014 Awesome work mate, will be one sick unit when shes done. Share this post Link to post Share on other sites
TF_250 398 Posted April 5, 2014 Still chipping away at this painted up the engine black, getting a few things together to have a crack over Easter. Got the alternator bracket all sorted. Also as you can see i'm working on the water inlet and water pump mounting. 4 Clevo120Y, Mixalis, slydog and 1 other reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted April 5, 2014 Nice work Jason - alternator bracket is neat as a pin. Share this post Link to post Share on other sites
slydog 7,873 Posted April 5, 2014 This is interesting Jase...awesome work as usual. Share this post Link to post Share on other sites
TF_250 398 Posted April 10, 2014 Finally got the pipes all welded up made a jig to stop them from bending. I will be coating them Black after the engine is dynoed.Before After Starting to come together on this side. Gathering all the fittings for the main water hoses 5 Mixalis, scottly, XF347 and 2 others reacted to this Share this post Link to post Share on other sites
TF_250 398 Posted April 14, 2014 Billet goodness, got my manifold adapter back today. 7 XPT, matt_lamb_160, P100_Ute and 4 others reacted to this Share this post Link to post Share on other sites
Tyler06 266 Posted April 14, 2014 Looking good. Gonna be a one of a kind beast!! Share this post Link to post Share on other sites
slydog 7,873 Posted April 14, 2014 Holy fuck bro...thats some serious shit right there! Insane... 1 TF_250 reacted to this Share this post Link to post Share on other sites
Campo 869 Posted April 14, 2014 Yeah, that looks horn!!! Billet is always fuckin nice! Share this post Link to post Share on other sites
