vanJack 43 Posted December 9, 2014 As the pictures show cracked pillar, water runs down inside rubber seal and ends up on the floor. It's a panel van, anyone else had this problem. If you fixed it what cost was involved? Share this post Link to post Share on other sites
hendrixhc 10,922 Posted December 9, 2014 XM221 might be able to throw you a bone here. Hes a champ with this kind of stuff! 3 XTREME KARTS XF, xm-221 and Outback Jack reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted December 9, 2014 Breaker one breaker one, Glenn do you copy over? 1 xm-221 reacted to this Share this post Link to post Share on other sites
xm-221 1,803 Posted December 9, 2014 Why are my ears fucking burning again, I'm a pastry chef, what the fuck would I know about shit like this? lol Pain in the arse spot because there's so much factory sealer in that corner. You're going to need to wire wheel it all out and see what is happening there. If you find a crack in the steel, weld it up, if it's just the sealer whack some more in. Painting will be happening. Mark, it's spelt "furry" not fury, change your sig fella. And it's breaker one nine, did you never watch Convoy in your earlier years. 4 steve mcqueen, Ants, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted December 9, 2014 Steel doesn't normally crack in a straight line. It's a bit hard to tell from the small pick but as glen said it make only be the sealer. If you clean it out with a wire wheel or wire brush you should be able to see it better. To identify a crack in steel you are going to need to take it all the way back to shiny metal which can be done with a bit of sand paper. 1 Ants reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,921 Posted December 9, 2014 The Panno's are known for cracking at the A-pillars. I reckon 1 in 2, have cracking there at some level or another. XH's don't seem to do it anything like the XG's do. Most commonly seems to be the L/H A pillar. Share this post Link to post Share on other sites
vanJack 43 Posted December 9, 2014 Definitely metal. It's an old problem I thought was fixed by a guy I knew who said he could fix it.. NOT.. You can feel the movement at that break with your fingertip as you drive slowly over uneven ground, like a driveway onto the road.. actually pinches the skin of your finger. The plenum's good, no issues there. Apparently x falcon vans flex at the A pillar.. especially with hard springs.. and lots of weight.. and lots of kays.. like half a million..( but I can't prove it cause it's on it's 2nd odo.) Soooo back to my question, has anyone had this problem.. and fixed it.. or is it terminal.. as in EXPENSIVE! There's buggar all rust in the rest of the van, just the crap going on round the A pillars and down onto the sills. Thanks. Share this post Link to post Share on other sites
xm-221 1,803 Posted December 9, 2014 Welding it up again is your only choice. Share this post Link to post Share on other sites
vanJack 43 Posted December 9, 2014 I notice later vans have some extra gusseting at the top of the A pillar.. Share this post Link to post Share on other sites
gerg 10,871 Posted December 9, 2014 Had a mate's XE ute do exactly this, could pinch your finger in it if you held onto it while driving, it used to open up that much. Share this post Link to post Share on other sites
vanJack 43 Posted December 9, 2014 Did he get it fixed? Very disconcerting.. (the big word for the day). What I'm driving at is, has anyone here actually had this problem and fixed it..? If so how? Is just welding it enough, or does it need bracing? Or what...? Again, thanks.. Share this post Link to post Share on other sites
gerg 10,871 Posted December 9, 2014 Nah he started turning it into a speedway car then left it in my yard for the next 5 years. Went to the tip after that. Could have fixed it if he could be bothered. Rust in the area was the main cause. Simple weld and paint would have done the trick. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted December 10, 2014 If the car is known for moving in the A pillar and you fix that area and add extra stiffening then all you will do if move the weak point somewhere else that may actually make things worse. If you weld up that area, generally speaking mig wire is stronger than mild steel when using an argosheild type gas. So if you weld it up it will be stronger anyway but not stiff enough to transfer the load point else where. It may well happen again as the steel will work harden and become brittle and break due to the movement in that area Share this post Link to post Share on other sites
vanJack 43 Posted December 10, 2014 Ok thanks for the replies everyone. Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted December 10, 2014 Yeah my XF panel van has had this repaired on the LH side before I brought it. I'd say brace it to stop it from happening again. Share this post Link to post Share on other sites
vanJack 43 Posted December 10, 2014 So brace it like in the picture above of later van..? (I forget what model that picture is.. XH I think..) or some other way..? Share this post Link to post Share on other sites
wagoon 2,429 Posted December 10, 2014 Mate Im 20 minutes south of Ipswich and happen to have an XH ute that Im stripping. You are more that welcome to come out and have a look over it and grab anything you need to fix yours. Share this post Link to post Share on other sites
vanJack 43 Posted December 10, 2014 Yes I noticed your location wagoon, "South of Ipswich". Be good to meet a fellow falconer. Was that you offering a ute on ebay.. I think it was? Very much appreciate your offer.. maybe pm me an address.. thanks. Share this post Link to post Share on other sites
SLO247 1,713 Posted December 10, 2014 Must have been why the extra bracing was added. Chop it out and weld it in? Will need to use the later pillar trims too. I think the change was during the XF run. Share this post Link to post Share on other sites
vanJack 43 Posted December 10, 2014 So the movement that does the damage is torsional twisting.. yes? which I think is the front twisting one way and the back end the opposite way.. ? And the top of the A pillar is where it obviously gives.. and Ford's answere was to triangulate a small area at that point. So maybe try and replicate what Ford did.. what the hey, give it a go I suppose.. Share this post Link to post Share on other sites
SPArKy_Dave 8,921 Posted December 10, 2014 was to triangulate There's another big word for the day......... 2 Outback Jack and xm-221 reacted to this Share this post Link to post Share on other sites
vanJack 43 Posted December 10, 2014 Oops, my mistake... should be just one big word per day. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
