dougie77 789 Posted January 13, 2015 http://www.gumtree.com.au/s-ad/mackay-4740/other-automotive/speedway-extractors/1067156388 These would be nice and quiet 2 Stumps and Clevo120Y reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted January 13, 2015 http://www.gumtree.com.au/s-ad/mackay-4740/other-automotive/speedway-extractors/1067156388 These would be nice and quiet Sweet jesus. Do want! Share this post Link to post Share on other sites
Clevo120Y 815 Posted January 13, 2015 Good explanation Stumper, I'm pretty stoked too! Just hoping this newfound efficiency shows at the petrol pump... It's been a shocker lately: about 20l/100kmGood to hear mate and great to see others have a go with positive results 2 tpak addict and gerg reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted January 13, 2015 Good explanation Stumper, I'm pretty stoked too! Just hoping this newfound efficiency shows at the petrol pump... It's been a shocker lately: about 20l/100km That's the only good thing about the cuzzo being off the road, not driving a car that gets 35l/100 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
Nath 1,975 Posted January 13, 2015 Bet it caused an oil crisis last time you drove it. 2 Outback Jack and Thom reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted January 13, 2015 That's why fuel is cheap at the moment. Thanks Thom. 6 gerg, Nath, Ando81 and 3 others reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted January 14, 2015 That's why fuel is cheap at the moment. Thanks Thom. I probably could afford to drive it if it was still on the road now Share this post Link to post Share on other sites
slydog 7,873 Posted January 14, 2015 That's the only good thing about the cuzzo being off the road, not driving a car that gets 35l/100 Thats pretty poor Thom...Im impressed 2 Outback Jack and Thom reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 14, 2015 We've got 8-tonne trucks at work that get better than that 1 Thom reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 16, 2015 Anyone who runs a Carter/Edelbrock AFB or an aluminium Holley will know all about vapour lock when it gets warm under the bonnet. You can make a carby insulator out of a bit of marine ply, then paint it with epoxy to protect it from fuel. You do need to be handy with the wood tools and have a router available with its various bits. Many speed shops actually sell them but they start at around 70 bucks. A lot of coin for a lump of wood i reckon. You could even make it extend out to shield the bowls from radiant heat, just might not look too flash. Share this post Link to post Share on other sites
wagoon 2,429 Posted January 16, 2015 You could also look into Synthetic Resin Bonded Fabric which is basically the same as bakelite and can be cut just like wood with routers etc. I bought a 600x150 off cut 12mm thick for $50 which I am going to use as an inlet manifold insulator on my crossflow. I am also using it to taper the manifold runners down to my cylinder head runners size for a smoother transition into the head 1 gerg reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted January 28, 2015 I dragged an XF ute out of a paddock the other weekend. Has an EFI motor fitted, unknown condition. Should I keep the E2 head it has? If I understand correctly it has bigger valves but also bigger chambers (lower comp). Having it shaved should give good compression, it would then be a good upgrade over the XD alloy head? It still has an 84da weber manifold too if anyone needs one. Share this post Link to post Share on other sites
tpak addict 1,909 Posted January 29, 2015 From what I have read E2 head have a lower cc chamber E1 is 57cc E2 is 52cc And if you use the EFI cam you will have to run an electric fuel pump.... The cams in the EFI are slightly milder than there carby breathren.... Share this post Link to post Share on other sites
SLO247 1,713 Posted January 29, 2015 I should word that better. Would having the E2 head shaved 30/40 thou and fitting it to my XD 250 provide a worthwhile gain? As in should I pull the head off the donor car before scrapping it. Not using the motor or cam. Did run an identical motor in my old ute though with the carby cam (for the pump) and intake and it seemed to go pretty well. Share this post Link to post Share on other sites
tpak addict 1,909 Posted January 29, 2015 Best upgrade would be a 2 barrel as the XD had a higher compression ratio 9:1 versus the XF's 8.8:1 The XD had 94kw and the XF 98kw.... Remember the XD only had a single carb,,,,, Share this post Link to post Share on other sites
ando76 4,354 Posted January 29, 2015 SLO247 - I like the E2 head and with a .040 shave you should be down around the 48cc mark but still a nice chamber shape and the bigger inlet valve is a help. Don't junk it - they are not making them anymore you know. keep the EFI rocker cover as well as I think they look ace on any x-flow. Share this post Link to post Share on other sites
SLO247 1,713 Posted January 29, 2015 Will an E2 at 48cc be an improvement over the XD Alloy head? Will definitely grab the rocker cover off it, I do have a Cain one I plan to use though. Share this post Link to post Share on other sites
wagoon 2,429 Posted January 29, 2015 shaving the head and having a combustion chamber that size will bump up your compression ratio. I tried to fit the efi rocker cover on my wagon with a stock webber on a stock manifold and it didn't fit as it hit the carby. A small spacer should take care of that though Share this post Link to post Share on other sites
ando76 4,354 Posted January 29, 2015 SLO 247 - yes and Yes. bigger inlet = more flow = better. Smaller chamber = more compression = better. Probably done a lot less K's than your alloy head XD = better. Share this post Link to post Share on other sites
SLO247 1,713 Posted January 29, 2015 I used to use a rubber spacer with that combo. No idea where it came from. As long as it gains compression I'm in, guessing it will necessitate 98? Not sure what octane rating leaded was anyway. What should I be paying to have it shaved? Share this post Link to post Share on other sites
wagoon 2,429 Posted January 29, 2015 I believe leaded fuel was about 96 ron. Compression ratio will determine if 98 is crucial or not, its never a bad thing to use 98 but if you need to use it as a daily and want to use 95 to keep cost down just dont shave it so much. You will need the dish of your piston to workout compression. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 29, 2015 I tried to fit the efi rocker cover on my wagon with a stock webber on a stock manifold and it didn't fit as it hit the carby. A small spacer should take care of that though A die grinder will easily take care of it as well, that's how I fitted my EFI cover to my Weber carbed XF. Share this post Link to post Share on other sites
tpak addict 1,909 Posted January 29, 2015 They use unleaded 91 on 10.3:1 its all in the timing..... E2 is the unleaded head by the way if you didn't know.... Share this post Link to post Share on other sites
SLO247 1,713 Posted January 29, 2015 Its just a weekender so don't really care about fuel costs, plan to run as much timing as I can! Yes Jim we all know. C1/E1 leaded, C2/E2 unleaded. D late XF commercial. Wrecked about 20 million of the god forsaken things in the last few years, every time I need parts I buy a car. Just like throwing my questions at the speedway fellas when it comes to go faster bits, I know fuck all. Share this post Link to post Share on other sites
tpak addict 1,909 Posted January 29, 2015 hey I just get excited when I know something..... lol 3 Nath, Thom and NZXD reacted to this Share this post Link to post Share on other sites
