TF_250 398 Posted January 11, 2014 Continuing on from my thread on the other forum. I Have recently sold off my crossflow and have decided to try a different route. I'm going to try and get some reasonable times out of my car now being powered by a DOHC FG falcon motor. The plan is to 1st get it in the car then get is running (not that hard when you say it like that) I'll be using my throttle body setup of my old motor and try and use my custom pipes as well. Also looking at my options at the moment as the ecu to control the cams. the rest of the car will be the same as before with the xflow, well thats the plan any way's!!! 1st picture to start off while I'm waiting for the bellhousing, engine came fully complete i have striped it down ready for install. 3 P100_Ute, slydog and XES reacted to this Share this post Link to post Share on other sites
Campo 869 Posted January 11, 2014 Subscribed! Keen to see how you do it all Share this post Link to post Share on other sites
P100_Ute 460 Posted January 11, 2014 You'll be at this point in no time at all shortly. 2 TF_250 and slydog reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted January 11, 2014 This is going to be fun. subscribed. 1 slydog reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted January 11, 2014 You going to clean that rusty old block up? Share this post Link to post Share on other sites
TF_250 398 Posted January 12, 2014 You'll be at this point in no time at all shortly. yep thats the plan, Without the pics you sent me I might have been hesitant to do this so thanks for that. You going to clean that rusty old block up? If you ever saw my old engine bay thats a yes....for sure!!! Share this post Link to post Share on other sites
hendrixhc 10,921 Posted January 12, 2014 If you ever saw my old engine bay thats a yes....for sure!!! Good man! They looks so shitty all rusty. Cheap fuckers at Ford couldnt even give them a lick of paint. Share this post Link to post Share on other sites
PRO250 1,506 Posted January 12, 2014 Looking for faster N/A? ever going a windmill?A few people going this way of late Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted January 12, 2014 Subscribe! Going N/A or turbo? I'd love to see a DOHC with 6 throttle bodies hanging off it, imagine the sound that would make!!! Share this post Link to post Share on other sites
TF_250 398 Posted January 12, 2014 N/A all the way guys, not really looking for or expecting anything faster just different. It will have 6 throttle bodies I'm using my old setup i have to make a transition plate from the existing round runner to the dohc oval port. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted January 18, 2014 N/A all the way guys, not really looking for or expecting anything faster just different. It will have 6 throttle bodies I'm using my old setup i have to make a transition plate from the existing round runner to the dohc oval port. I6 Porn right there! what power/quarter mile time did it make ? Share this post Link to post Share on other sites
Mixalis 266 Posted January 18, 2014 Geez i love logging back into the forum after a while! Farout Jase this is going to be insane mate keep the progress pics coming Tim, that looks crazy mate will be expecting a full Timspec write up on that hahaha 1 RAWDEAL reacted to this Share this post Link to post Share on other sites
TF_250 398 Posted January 18, 2014 Update on this, I got a EA falcon bell and it was going to end up to deep and way to many mods to fit. I found a Quicktime bell form the states made for a BA-BF-FG to c4 and it was advertised as the same depth as the bell i have but when it came it is about 3mm deeper then the c4 6cyl bell but it fits good Now I'll use the windsor flexplate with some arp insert washers on the holes to be able to use the M10 bolts, use me original xflow/windsor torque convertor and it all doesn't push the engine to far forward at all I'm actually using the std cortina engine mounts bolted to the FG block and i have to fill and redrill one hole. And to top it off it was $700 delivered to my door form the us with .85 exchange rate!! ( a local dellow is $800 and 20mm deeper then the old crossflow bellhousing) I ended up just cutting out the firewall around where the starter motor mounts because it mounts on the left side of the engine now the cortina firewall wont fit at all ill bow it all in after the engine is finial fitted. Next step is to finish the engine mounts off and start on the sump then it will be all fitted. 5 nos2, Mixalis, 'Nova and 2 others reacted to this Share this post Link to post Share on other sites
TF_250 398 Posted January 18, 2014 I6 Porn right there! what power/quarter mile time did it make ? 345hp @ fly 11.58@114.4mph 98fuel 1210kg cortina Share this post Link to post Share on other sites
P100_Ute 460 Posted January 18, 2014 Looks good Jason, just need to get radiator modified to suit the hoses need be swapped to the other side. passenger top with short hose straight into the thermostat.. and on drivers side needs to be bottom hose 1 Mixalis reacted to this Share this post Link to post Share on other sites
TF_250 398 Posted January 18, 2014 I was looking at that today, I'm running an electric water pump and all -16an hoses. I'm going to run the top out of the front of the thermostat housing under the rockercover to radiator and once i mount the pump the bottom will com around into a gutted waterpump. Well that's the plan atm!! . Not much room there once the fan is in but all ill have is the ati balancer and the alternator with a short belt like on my crossflow. 1 Mixalis reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted January 18, 2014 a good tig welder bloke could cut n shut the top/bottom hoses. Mines a Standard corty radiator with the hoses cut out and moved to suit the engine 1 Mixalis reacted to this Share this post Link to post Share on other sites
RAWDEAL 222 Posted January 19, 2014 a good tig welder bloke could cut n shut the top/bottom hoses. Mines a Standard corty radiator with the hoses cut out and moved to suit the engine There does not look like much room for thermo fan/fans are you going to mount them at the front and push the air maybe? surely these engines are the same length as an xflow ? or maybe because of the vvti they are a bit longer? Share this post Link to post Share on other sites
TF_250 398 Posted January 19, 2014 yeah mate its a bit if an illusion. the block is the same length, the timing cover is larger bit the rockercover does come forward alot i have a thermo in my pics no worries it would fit but its tight. Share this post Link to post Share on other sites
dizzy616 183 Posted January 20, 2014 i have 1 word. SICK!!!. no wait another 2 Fuckin Awesome! Share this post Link to post Share on other sites
ando76 4,354 Posted January 27, 2014 Jason have you got the part no. for those ARP insert washers?? ARP-200-8568??? Share this post Link to post Share on other sites
TF_250 398 Posted January 27, 2014 I used the 200-8572 .443 OD 3/8 ID the ID needs about 30 seconds with a dremal and a small stone for the 10mm bolt to go through and the need a little off the length as well. Im using the ring as well so I'm going to also get some 203-2082 flywheel bolts just for piece of mind they are 1.000" long , by the time i use the washers and the ring the bolts are getting a little short for me. Share this post Link to post Share on other sites
ando76 4,354 Posted January 27, 2014 thanks mate- will have a look at both them as I might run them on the burnout engine this time around so I can run the original c4 flexplate. Share this post Link to post Share on other sites
TF_250 398 Posted February 4, 2014 Got the sump sorted out finally, fit in the car sung but Im happy there is at least 4mm clearance all round so that will do me, also had to relocate the drain. Searched around for balancer options but ended up going the same as i had before. The alternator that came with the engine was stuffed and i couldn't be farked sorting out serpentine belts and tensioners so balancer, pulley vbelt done. 2 Mixalis and dougie77 reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted February 4, 2014 Coming along nicely. Bring on the DOHC power! Share this post Link to post Share on other sites
