Mr Polson 10,214 Posted October 6, 2013 So... I put a new door on the ute. Problem is, I can't get it to align at all. I've got the back of the door set up properly - it shuts properly and doesn't rub. But as you can see, the front is way out. Miles. So bad the door rubs on the sill and won't open all the way. Share this post Link to post Share on other sites
Jonathan Mark Davidson 169 Posted October 6, 2013 i usally use wedges till both are right lifting the gaurd on and off but other probably have a better way Share this post Link to post Share on other sites
Ants 6,370 Posted October 6, 2013 Is the gap even all the way along where the door meets the quarter panel? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted October 6, 2013 I think it might be a bit bigger on the upper half of the , but not a large amount. Share this post Link to post Share on other sites
revhead 1,392 Posted October 6, 2013 not to hard ,to align, loosen the 4x front bolts ,put a trolley jack under the front of the door to lift it a little nip up 1x bolt top n botton, then remove jack and close to check for alignment, this might need to be done a few times ,but easy as process. 1 Mr Polson reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted October 6, 2013 i use the jack method too, but beware of the paint (scratches never bothered me though) Share this post Link to post Share on other sites
Ants 6,370 Posted October 6, 2013 Take out the striker when lining up too,set the door up in the hole then make it close.The striker will throw it all over the place. If the gap is larger at the top it means the the top hinge needs to go backwards,which will lower the whole door,so then lift the whole door straight up to get it lined up. Make sense? 2 slydog and Mr Polson reacted to this Share this post Link to post Share on other sites
GspecZL 979 Posted October 6, 2013 for a trolley jack just throw a thick rag on it to avoid scratches. Just did the doors on my ZH with this method. Its all about spending some time i reckon. Door looks good Mr Polson! 2 revhead and Mr Polson reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted October 7, 2013 Yep makes sense Ants. So do I adjust it at hinge to body first, and then do final adjustments at hinge to door? Yeah figured if I use a jack that whacking some decent rag on it will stop the scratches. 1 Ants reacted to this Share this post Link to post Share on other sites
xr6tjet 98 Posted October 7, 2013 Most of the alignment comes from where the hinge bolts to the body, the 4 bolts that bolt to the door are only for fine adjustments. I just realigned my door on my very sagged XF ghia hinges on the drivers side (replaced with rare spares hinge repair kit). The best way I found was to use two standard car jacks, XE and XF jacks are great in particular because you can rotate them and still wind them up. To do my method: loosen hinge bolts where the door connects to body (be careful not to over tension them and break the thread on the plate it is quite weak) and use the jacks to put the door where you want it to sit. that includes sliding it forwards or backwards and up and down. Make sure that it sits good when you close it so don't have the door open really wide so you can't see whether its aligned or not prior to tightening bolts. Its a bit of trial and error to get it to sit 100%. Once done, tighten bolts and admire your well aligned X series (they look the coot when aligned right even with crap paint) Share this post Link to post Share on other sites
Ants 6,370 Posted October 7, 2013 Yep makes sense Ants. So do I adjust it at hinge to body first, and then do final adjustments at hinge to door? Yeah figured if I use a jack that whacking some decent rag on it will stop the scratches. Yep,adjust the hinges on the body then fine tune with the door to hinges. Share this post Link to post Share on other sites
revhead 1,392 Posted October 7, 2013 if you havent pulled the hindge off the body dont touch it,just adjust the door Share this post Link to post Share on other sites
Ants 6,370 Posted October 7, 2013 if you havent pulled the hindge off the body dont touch it,just adjust the door This is good advice if the doors are the original ones for the ute, if they were off something else all bets are off. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted October 7, 2013 Yeah these doors are off different cars, tried lining this one up leaving hinges on, door wouldn't shut at all, was too far back. Share this post Link to post Share on other sites
Ants 6,370 Posted October 7, 2013 That's why the hinges are adjustable, they wouldn't move if all the doors fitted exactly the same from car to car. Share this post Link to post Share on other sites
blu xe 825 Posted October 7, 2013 Agree with Ants. Piss the striker off. Pull the splash guard out of the guards to give better access to the hinge bolts and align it at the pillar. While the doors have a fair bit of alignment at the door itself I really only mainly use them to move the door in and out to get them flush. You have to be in the ball park at the pillar first then fine tune at the door itself from there. Make sure your hinge bushes aren't flogged cause this will give you more dramas. Concentrate on an even gap along the back to the quarter first. the sill should go close to being right from there. To get the front can be tricky on these. I've had some cars that sit perfectly with little fuss and others that regardless what I did they were never quite right. You may need to move the guard around also once you've got the door close. Gapping these cars is always a bit of a compromise as they were all over the place gap wise even from new. 4 Mr Polson, slydog, Ants and 1 other reacted to this Share this post Link to post Share on other sites
XDPSI 10 Posted November 7, 2013 I read this topic and laughed to myself. I just aligned all my doors on my xd after completely gutting them, body deadening them, dynamiting them and foaming sections. What a complete bitch to do. I agree the process is real simple but I'm fussy as and it took me and a mate ages to get it respectable and there's still room for improvement. Striker out definitely helps and front guards off of course. I had every part stripped out, regreased and adjusted the rods inside. Best mod ever was on the rear doors changing the angle and point of leverage that the handle needs to open the door. All the doors open perfect now with ease and the seals align and seal good. Windows open and shut like new too. Hated doing it but now it's done I'm wrapped. Also I started with the back doors as they were much easier to get right. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 7, 2013 This is on a ute so I don't have rear doors to worry about. I've been real slack with this, haven't bothered to look at it yet. 1 XDPSI reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted November 8, 2013 What was wrong with the original doors? If they fitted ok, I probably would've stayed with them. Realistically, you'll have to take the guard off, and then remove the pinchweld door opening seal and the striker plate. The door frame may even be slightly twisted, and need reshaping with a block of wood in the door opening, and some brute bending force. Essentially do what panel shops do, when gapping a resto project. (And maybe have Moog's 'Game On', playing in the background on a continuous loop for inspiration.) Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 8, 2013 Original doors had dents in awfully tricky to get to places to knock them out, and were povo pack doors, these are ZL doors so have all the wiring/electrics for elec windows, mirrors, locking, and were straighter than the old doors. Share this post Link to post Share on other sites
XDPSI 10 Posted November 11, 2013 haha fair call on the rear doors on a ute! My bad, typed before I had a read... Share this post Link to post Share on other sites
noddy 451 Posted November 12, 2013 This is probably the worse I've seen and it's on a mates car down here the door drops around a full inch and a half after opening it so much so his Qp is dented and squashed in so the door can open Never seen a xe like it all 4 doors have completely gone like this Share this post Link to post Share on other sites
Lott 35 Posted July 19, 2016 Is there anyone who specialises in panel gaps. Have got mine as good as I can get. But think there needs a bit of expert love to get it right. Share this post Link to post Share on other sites
Thom 6,651 Posted July 19, 2016 Is there anyone who specialises in panel gaps. Have got mine as good as I can get. But think there needs a bit of expert love to get it right. Which one is that for Mr lott? Share this post Link to post Share on other sites
