Grimmy 312 Posted August 16, 2016 El is probably the better option . I don't understand why they went to coil pack on ef then changed back to dizzy for el and then back to coil pack for au . Stupid ford 1 SirkWhyXF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted August 17, 2016 They had lots of reliability issues with the first run of coilpacks, didn't want any more of that so waited till the issue was sorted and went back to the good old dizzy for the next model. Even then, AUs had their fair share of coilpack failures but not until they got over say 150k. I noticed my mum's EL wags drinks way more than my EF did, possibly due to the dizzy setup on the later one not being able to dial in more timing at cruise. 1 Thom reacted to this Share this post Link to post Share on other sites
Grimmy 312 Posted August 17, 2016 Can the timing be tuned in the ecu or is pre mapped ? Might be better to run msd and locked timing Share this post Link to post Share on other sites
gerg 10,871 Posted August 17, 2016 It's purely by limitations in the design. A distributor can only have a certain amount of range available for advancing/retarding timing before cross firing occurs between plug terminals. The more cylinders, the less range of timing adjustment you have because the cap terminals are closer.<br /><br />Theoretically, a coilpack or coil-on-plug setup has an unlimited range because each coil is a separately triggered circuit (although the falcon's is shared between two cylinders with waste spark) so huge amounts of timing can be dialled in on cruise and over-run, up to 60 deg I have heard. 1 Thom reacted to this Share this post Link to post Share on other sites
perthstocky 0 Posted September 20, 2016 Hi Thom im new to 4.0l engines.i have bought an xg xr6 with an au xr6 engine fitted. I have a 94dt head which has been recoed with new valves and springs and skimmed 40 thou. 94dt has no rocker gear. Can i use au rocker gear on 94dt and do you recomend a cam to suit. Will i need any other parts to swap to 94dt. It also has log manifold but i will look for a bbm manifold. Any other upgrade parts you can recomend would be appreciated too. Cheers in advance mate. Blair Share this post Link to post Share on other sites
JoshXH 42 Posted September 20, 2016 You'll need EA-EL rocker gear and cam. AU is different somehow, can't quite recall how though. I do remember that AU cams/rockers won't work in an E-series head and vice versa. Still got the XG XR motor? Use the cam and rockers out of that, I think I read somewhere in this thread that the XG XR6 cam was the hottest factory cam used in the E-series/XG/XH 4.0, with the EA 3.9 cam second. Have a read of this thread, it should tell you everything you need to know 4 robbie, Thom, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
perthstocky 0 Posted September 20, 2016 I dont have the xg motor bought it with au xr6 fitted. Ill try and source new rocker gear and go for an aftermarket cam to suit e series. Cheers Josh Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 21, 2016 You'll need EA-EL rocker gear and cam. AU is different somehow, can't quite recall how though. The difference is in the rocker arm ratio. EA-EL are 2:1, where as AU rockers are 1.8:1. ie, a 244thou cam lobe, will result in 488thou valve lift in EA-EL, and 439.2thou valve lift in AU. EA and early EB rocker gear used 14mm diameter Hydraulic lash adjusters, EB-AU, used smaller 11mm lash adjusters. Share this post Link to post Share on other sites
Thom 6,651 Posted September 21, 2016 Ideally you want eb to El series 1 rocker gear as the lash adjusters are more readily available that the ea type, and late El had an early version of an au engine they use the 1.8:1 rockers and beehive valve Springs e series rocker gear in an au head will result in extreme amounts of lash and may not even open the valves au rocker gear on an e series rocker gear on an au head will result in broken rockers and bent valves 1 Outback Jack reacted to this Share this post Link to post Share on other sites
perthstocky 0 Posted September 28, 2016 Are you able to buy new rocker gear or do i need to just source second hand Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted June 21, 2017 1 Bigflop reacted to this Share this post Link to post Share on other sites
Bigflop 288 Posted June 27, 2017 Very helpful as im just about to do timing chain haha thank you!Sent from my SM-G935F using Tapatalk 2 Valvebouncer and Outback Jack reacted to this Share this post Link to post Share on other sites
Grimmy 312 Posted July 2, 2017 Can anyone tell me journal sizes and stroke of an au crank compared to earlier cranks ?? I did a google search but I'm retarded and didn't find anything , Pulled apart a late model xh ute engine hoping to find a full counterweight ef crank , but appears to be an au crank ... Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 2, 2017 Stroke is the same but the conrods are longer, kind of like fitting 200ci rods in a 250ci scenario.Can't help with the journal size sorry. Share this post Link to post Share on other sites
Thom 6,651 Posted July 2, 2017 Au uses larger main journals but still the same stroke, you would have to get the crank ground down to use it in and vb is correct au uses a longer Rod 1 Outback Jack reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted February 28, 2018 On 04/07/2013 at 6:44 AM, Thom said: Looks good, personally I would use a broad band intake over the log manifold Can you use the bbm with an xg engine loom to run injectors. Dizzy and shit. Sorry if this is a dumb question. Share this post Link to post Share on other sites
Thom 6,651 Posted February 28, 2018 Can you use the bbm with an xg engine loom to run injectors. Dizzy and shit. Sorry if this is a dumb question.Yes you can if you un pick the loom off the xg intake there is enough room in the harness to lay it out on the BBM, the one problem you do have with putting a BBM into an xg is clearance with the header tank but if you move it it will clear the intake Share this post Link to post Share on other sites
hendrixhc 10,921 Posted February 28, 2018 Is that unpicking the loom to make wiring reach? Share this post Link to post Share on other sites
hendrixhc 10,921 Posted February 28, 2018 Also will the bbm clear the shock towers ok and the dizzy and the A/C compressor? Lots of questions! Share this post Link to post Share on other sites
SLO247 1,713 Posted February 28, 2018 The BBM will clear fine. Dizzy goes in the same spot, same cap and everything still. Share this post Link to post Share on other sites
hendrixhc 10,921 Posted February 28, 2018 Cheers. Look like ill have to start tidying up the BBM instead of the log. It will be easier to run intake piping to as well for the snail. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted February 28, 2018 Log manifold works better with Turbo's though, afaik... Share this post Link to post Share on other sites
Thom 6,651 Posted February 28, 2018 Is that unpicking the loom to make wiring reach?You only have to untape a couple of little bit and it will reach Also will the bbm clear the shock towers ok and the dizzy and the A/C compressor? Lots of questions!Yes yes and yes Log manifold works better with Turbo's though, afaik...Only for outright power, for street drivability a BBM works better 2 hendrixhc and Valvebouncer reacted to this Share this post Link to post Share on other sites
XPT 673 Posted March 1, 2018 20 hours ago, hendrixhc said: Cheers. Look like ill have to start tidying up the BBM instead of the log. It will be easier to run intake piping to as well for the snail. Only if you're going with no intercooler (far from ideal) or a water to air over the top of the engine. The old pre bbm log makes it easier to plumb intercooler pipework and makes for a far shorter inlet tract to run an air to air front mount, which is the cheapest option. 1 hendrixhc reacted to this Share this post Link to post Share on other sites
hendrixhc 10,921 Posted March 1, 2018 Whats the best type of replacement distributor to stick in the AU block. Would like to go with something new. Share this post Link to post Share on other sites
