CHESTNUTXE 7,311 Posted December 23, 2018 There’ll be a roll pin in a hole that goes through both half’s of the selector shaft, knock it out with a pin punch. go buy a casket kit for a single rail and change all the gaskets while your at it.Since i had my single rail fully rebuilt its unreal and new alloy shifter screw in thing best gearbox in a single rail i have ever hafSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted December 23, 2018 The shift spool being the ‘round thing’ around the shifter shaft and the guide being the slot on the top cover. Using words I can understand () you have to get the round thing on the shifter shaft to sit in the guide on the top cover yes? Sent from my iPhone using TapatalkCorrect, and that slot is only stamped steel that can bend and distort very easily if not lined up with the spool properly as you bolt the top cover on. If any end clearance in that slot allows the spool to move back and forth excessively, you could end up being jammed in gear. If you miss that slot altogether with the spool, you can get 2 gears at once, which is the perfect recipe for carnage.The proper terminology for that part is "shift interlock spool", which means exactly what it says. It prevents one shift fork from engaging while the other is actuated, or more accurately, keeps one in neutral while the shift pin is pushing or pulling on the other. Very simple and clever setup.Another thing is that the top cover cork gasket cannot be substituted with silastic or similar because the cork provides a set shim distance between the casing and the cover. If you try installing with just sealant, the spool will touch the cover plate and prevent the bolts tightening all the way down. It will piss oil out the top of the box or bend the top cover. Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
SteveHobart 57 Posted December 23, 2018 BrilliantI did take the top cover off but it’s relatively easy to line it all up again and bolt it down. Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted January 9, 2019 Little bit late to the party but good luck with the build mate! I’m running a 14892 (have been for a while) and was great at the time because it standard converter (now a manual), standard rockers and standard balancer so the shows all over by 5,000rpm. But yeh can’t wait to go abit bigger eventually. So a couple of you have mentioned aftermarket lightened flywheels, had no idea this was an option. So the Windsor one with the correct tooth count bolts straight in? Would you still be able to use the pressure plate and clutch from the standard flywheel or do new holes need to be tapped into the flywheel? Excuse my ignorance with this one Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 9, 2019 I believe a zero balance Windsor 157 tooth is the same as a Ford 6. Drillings for clutch bolts however I don't know about. Yella Terra list this flywheel for both, but doesn't say anything about clutch compatibility. Maybe give them a ring? Sent from my CPH1607 using Tapatalk 1 Mixalis reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted January 9, 2019 I believe a zero balance Windsor 157 tooth is the same as a Ford 6. Drillings for clutch bolts however I don't know about. Yella Terra list this flywheel for both, but doesn't say anything about clutch compatibility. Maybe give them a ring? Sent from my CPH1607 using TapatalkVery good questionSent from my SM-G570Y using Tapatalk 1 Mixalis reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted January 9, 2019 Cheers boys might be worth a call, would be nice to know for the future. Thanks again Greg Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
Thom 6,651 Posted January 9, 2019 I used a zero balance 5.0 billet flywheel from yella terra on my 4.0 in my xh, it took a 4.0 style pressure plate and clutch without any mods 2 Mixalis and gerg reacted to this Share this post Link to post Share on other sites
Mixalis 266 Posted January 9, 2019 I used a zero balance 5.0 billet flywheel from yella terra on my 4.0 in my xh, it took a 4.0 style pressure plate and clutch without any modsThanks Thom there you go can’t imagine it being any different then. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Mixalis 266 Posted January 9, 2019 For a light flywheel i am impressed with mine. 6.5kg with ring gear on.Www.ironforce.co.nzBe cheap as with aussie money hahaSent from my SM-J330G using TapatalkLooks awesome mate is this also a Windsor one as well that fit? Did you ever drive the car with the standard flywheel to compare? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
slydog 7,873 Posted January 10, 2019 I use a billit Mezire flex plate on my xflow too. 1 Mixalis reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted March 6, 2019 On 1/10/2019 at 12:43 AM, Mixalis said: Looks awesome mate is this also a Windsor one as well that fit? Did you ever drive the car with the standard flywheel to compare? Sent from my iPhone using Tapatalk Sorry for late response, not a windsor one. Made for e series speedway motors by a crowd here in NZ. Was dirty bw35 before so no comparison. 1 Mixalis reacted to this Share this post Link to post Share on other sites
SteveHobart 57 Posted May 12, 2019 It’s been a while so I thought I would update a bit! So have found that the Heater Core was absolutely rotten, which is why it was leaking water. So whole dash out time to replace that. While it was out I replaced the fan solinoid (as it was only working on one setting) and fixed up a few cracks in the climate control unit. I think I have finished wiring in the Megasquirt with all the factory ECU now disconnected. The only cables which were left were those which controlled the emissions controls which is right (according to the wiring diagram), just need to put in a vacuum line to the MAP sensor built into the Megasquirt. Have found some massively dodgy stuff in the wiring loom too.Have also started removing the black stripes on the side and am going to be painting the bumpers. Sent from my iPhone using Tapatalk 4 Slow250XC, CHESTNUTXE, deankxf and 1 other reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted May 12, 2019 woo! updates did you get any pics of the cracks in the climate thing and how you fixed it? seen these for the first time last year and wondered if i'd kept any spares(didn't) Share this post Link to post Share on other sites
SteveHobart 57 Posted May 19, 2019 No sorry Dean I didn’t. So progress is slowing a little due to Auto Electrical issues. Unfortunately the issues aren’t of my making, they relate to a prior owner who, well let’s just say, was maybe a little ambitious with joining wires! Sent from my iPhone using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted May 19, 2019 must be the same dude that wired My gemini, there's also a pic in there with the earth wire with 3 joins in it.. twist and tape.. on the CD player(didn't work) i wired it into My sedan, it's been perfect for 2yrs now Share this post Link to post Share on other sites
SPArKy_Dave 8,873 Posted May 19, 2019 Kinda looks like all the 1980's alarm wiring, I found in the 260z... what a mess that was! Share this post Link to post Share on other sites
deankxf 20,288 Posted May 19, 2019 1 hour ago, SPArKy_Dave said: Kinda looks like all the 1980's alarm wiring, I found in the 260z... what a mess that was! like the gemini one? Share this post Link to post Share on other sites
SteveHobart 57 Posted June 17, 2019 Hey all! Just a bit of an update the engine is finished!!! Just waiting on the gearbox to be finished so I can put it all in as an assembly. In the mean time I have:- Ordered a Bolt In 1/2 roll cage- fitted some racing seats- ordered 2 x racing harnesses - finished wiring the Megasquirt unit - Fitted the O2 sensor to the extractors- Fitted the Air Temp Sensor to the Plenum chamber This weekend I spent a bit of time reducing weight in the old XF. Basically cutting away the tow bar and some of the surplus steel under the rear bar in particular! So progress is being made!!!Sent from my iPhone using Tapatalk 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
SteveHobart 57 Posted August 4, 2019 It’s back together! Nearly! Ha ha Sent from my iPhone using Tapatalk 5 Mixalis, gerg, 351XD_Fairmont and 2 others reacted to this Share this post Link to post Share on other sites
SteveHobart 57 Posted September 1, 2019 Hey guys! Well I’ve been a little busy with my other hobby (growing food) as winter is the time to get out in the garden and set everything up for spring.However I have been able to spend a few hours each weekend on the XF and here’s where we are at. Yup! Back where she belongs!Am going to hook her all up and double check the wiring/sensors to make sure everything is sweet.Can’t wait to fire it up. It’s getting closer!Sent from my iPhone using Tapatalk 2 motoSycho and deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted September 1, 2019 definitely an achievement in this weather.. gardening or car play. l am finding myself getting slightly more done lately also Share this post Link to post Share on other sites
Steve 0 Posted September 9, 2019 Hey guys! Well I’ve been a little busy with my other hobby (growing food) as winter is the time to get out in the garden and set everything up for spring.However I have been able to spend a few hours each weekend on the XF and here’s where we are at. Yup! Back where she belongs!Am going to hook her all up and double check the wiring/sensors to make sure everything is sweet.Can’t wait to fire it up. It’s getting closer!Sent from my iPhone using TapatalkHey there . I've just being messaging a bloke with a injected crossy who's having vacuum plumbing line probs. U got any more pics of plumbing ?Sent from my SM-T590 using Tapatalk Share this post Link to post Share on other sites
SteveHobart 57 Posted September 9, 2019 Got a few more if they done help! Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
SteveHobart 57 Posted September 30, 2019 So have given the mechanical a miss for something more body workish (not a word). Am colour coding the Bumpers and repainting the boot and adding a retro wing! Sent from my iPhone using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
