CHESTNUTXE 7,694 Posted March 17, 2018 Hey does anyone no any info on the good ol ford transit van and what crossflows did they come with and autos/man ect,im thinking of doing up a van for my next project,chime on in with any good info,or idea's,eg,dual rear wheels ect.ect,back in the day i no a lot of bedford vans were converted to 308,s,. Share this post Link to post Share on other sites
deankxf 21,128 Posted March 17, 2018 i had one forum here is a good one http://fordtransit.org/forum/viewforum.php?f=27 Share this post Link to post Share on other sites
deankxf 21,128 Posted March 17, 2018 the V4 ones are crap... the 250 log or crossflows had a 3 speed floor shift or C4 auto. th later ones could have disc brakes, diff ratio is stupid low, 4.6:1 ratio can be changed the diff is wide, wider than an AU diff, the AU diff with deep dish wheels is a cheap conversion.. CRS does/did a falcon disc, HQ caliper conversion .. finding one that's rust free will be near impossible, finding parts will be hard.. if this guy is still in business, he was pretty much the only guy who wrecked them (Joe) https://www.wordofmouth.com.au/reviews/jb-auto-ford-transit-and-bedford-cf-parts-and-service-dandenong what other questions do you have? My Dad had a flat nose Mk1 1970(originally ex Aus Post V4) he ended up with Leyland V8 in it with a C4 auto and ex USA LTD 9" diff I had a 1980 Mk2 with 250 crossflow, ended up with T5 and widened XF diff (used 2 long axels) i never finished mine, had to move and get rid of all my crap 4 2redrovers, Valvebouncer, matt_lamb_160 and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted March 17, 2018 what is next week lotto numbers dean 1 2redrovers reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted March 17, 2018 i like the mk2 ,cheech and chong van,or A team,those hurricane wheels really suit vans. Share this post Link to post Share on other sites
deankxf 21,128 Posted March 18, 2018 3 hours ago, CHESTNUTXE said: i like the mk2 ,cheech and chong van,or A team,those hurricane wheels really suit vans. if i wanted a rear wheel drive van that didn't chop your legs off in a crash(like my Mazda will) i'd get a Hyundai iLoad. i decided for what i wanted(potential Oz wide tourer) that it needed to blend in when i parked it... old Transits are so rare now they will stand out no matter what you are doing.. they are also fairly wide i'd consider a newer transit, but maybe with an engine conversion(seen them with V6 commodore engines, and at least one was getting a barra conversion. ) Share this post Link to post Share on other sites
gerg 10,875 Posted March 18, 2018 if i wanted a rear wheel drive van that didn't chop your legs off in a crash(like my Mazda will) i'd get a Hyundai iLoad. i decided for what i wanted(potential Oz wide tourer) that it needed to blend in when i parked it... old Transits are so rare now they will stand out no matter what you are doing.. they are also fairly wide i'd consider a newer transit, but maybe with an engine conversion(seen them with V6 commodore engines, and at least one was getting a barra conversion. )Our work leases them (I don't work on them) but they seem like a good thing. Fairly predictable Korean quality: cheap and dependable.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted March 18, 2018 if i wanted a rear wheel drive van that didn't chop your legs off in a crash(like my Mazda will) i'd get a Hyundai iLoad. i decided for what i wanted(potential Oz wide tourer) that it needed to blend in when i parked it... old Transits are so rare now they will stand out no matter what you are doing.. they are also fairly wide i'd consider a newer transit, but maybe with an engine conversion(seen them with V6 commodore engines, and at least one was getting a barra conversion. )Our work leases them (I don't work on them) but they seem like a good thing. Fairly predictable Korean quality: cheap and dependable.Sent from my CPH1607 using Tapatalk They are a ginormous hunk of shit. You are better off blowing your money on drugs and alcohol. At least you won’t suffer while wasting your money. 4 gerg, GspecZL, Slow250XC and 1 other reacted to this Share this post Link to post Share on other sites
gerg 10,875 Posted March 18, 2018 Hey does anyone no any info on the good ol ford transit van and what crossflows did they come with and autos/man ect,im thinking of doing up a van for my next project,chime on in with any good info,or idea's,eg,dual rear wheels ect.ect,back in the day i no a lot of bedford vans were converted to 308,s,.The models up till around 2002 (gen2) were total buckets of crap. No end of troubles with engines, turbos, clutches, gearboxes, diffs, random interior/body faults, just not a nice thing at all.2000-onwards (gen 3) were improved but not great. Clutches are a nightmare to do (subframe out) and dual-mass flywheels are a mandatory swap when doing the clutch. That's $1200 in parts right there.Door latches fail, front wheel bearings are a regular thing (needing a specially turned down, extended torx bit of course) and you also need to split the front hubs to change the discs.The diffs on the RWD versions are the same shitty design they've always been, even on the old ones (i think they have a C8 part number on them). They have a supposedly hardened section of axle at the flanged end that runs directly on roller bearings. The rollers wear out the axle, so when you do an axle bearing, you're doing an axle as well.They're a C-clip design that has the side load working on a clip and machined groove in the axle end inside the diff centre. If the clip wears out or the axle breaks off at the groove, your axle and wheel will walk themselves out of the diff housing as you're driving down the road.The backing plate adjustment window on the rear brakes doesn't line up with the adjustment wheel, meaning you can't de-adjust to remove the rear drums if there's a lip. A Ford dealer's answer (before we sorted it ourselves)? Cut the drum off with an oxy.As far as I know, any transit will have this diff design.Engines were pretty reliable on the later ones except the diesel pumps used to have an internal haemorrhage. These engines are still in use today in the Ranger in 2.2 and 3.2 (5-pot version).Even at that, there was a mob in Melbs doing E-series/AU conversions on the later models with gas power. That could have been a good business for Ford to get into: import bodies in CKD kit and assemble locally with a Falcon drivetrain.Sent from my CPH1607 using Tapatalk 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted March 23, 2018 wish i kept it sometimes.. pic when i got i.. pained in gloss house paint... wasn't solargaurd .. faded fast bought a parts one(orange) and didn't get the rest done.. Dad's old one with Leyland v8, and VN hub caps 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted March 23, 2018 few vids i took 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted March 23, 2018 Hyundai iloads like to spit the turbo, after about 100,000km - usually taking the engine with it. $10k min, for a used engine too. A work colleague had it happen to theirs... The internet is littered with similar stories. It's a pity, as they are comfortable vehicles, by all other reports. 2 Valvebouncer and Slow250XC reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted March 23, 2018 Hyundai iloads like to spit the turbo, after about 100,000km - usually taking the engine with it. $10k min, for a used engine too. A work colleague had it happen to theirs... The internet is littered with similar stories. It's a pity, as they are comfortable vehicles, by all other reports.Totally utterly agree. I can’t tell people strongly enough to avoid buying a icrap. The cost of parts are just astronomical and every time something goes wrong it requires major work. People use these to make their livelyhood, it won’t do that sitting there broken down. 3 bear351c, CHESTNUTXE and Slow250XC reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted April 11, 2018 @CHESTNUTXE check these outhttps://www.ebay.com.au/itm/1979-Ford-Transit-Van/263599454801?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3D099ed6ac329e41e39fe0a1ab66a3fe72%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D263597826564%26itm%3D263599454801&_trksid=p2047675.c100005.m1851 https://www.ebay.com.au/itm/1982-Ford-Transit/292517022497?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3D7ac2b99debac41d19eb73d2ad0992b2c%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D263599454801%26itm%3D292517022497&_trksid=p2047675.c100005.m1851 this windowless one is cool, because windowless(and old school hurricane wheels in dumb transit pattern must be either welded and redrilled or custom orderedhttps://www.ebay.com.au/itm/Car-ford-transit/142753380787?hash=item213cc3b9b3:g:5cAAAOSwve1azXtm Share this post Link to post Share on other sites
GspecZL 979 Posted April 13, 2018 if i wanted a rear wheel drive van that didn't chop your legs off in a crash(like my Mazda will) i'd get a Hyundai iLoad. i decided for what i wanted(potential Oz wide tourer) that it needed to blend in when i parked it... old Transits are so rare now they will stand out no matter what you are doing.. they are also fairly wide i'd consider a newer transit, but maybe with an engine conversion(seen them with V6 commodore engines, and at least one was getting a barra conversion. )Work has 2 I loads. I wouldn't buy one. Both have had engines under 100,000ks and parts like turbos have cost us a bomb. And frankly one of them has been babied and still the same crap.We run a fleet of mostly Sprinters and a good 315 or 316 is hard to been. Obviously size is an issue but our Vito's have been good to.Hiaces are still reliable but then they aren't for touring.I honestly love my Ex Ambo 315 I take it to Phillip island on weekends and its ridiculous how comfy the captains chairs are and how quick the 4cyl is.Sent from my 5046I using Tapatalk 2 deankxf and Slow250XC reacted to this Share this post Link to post Share on other sites
bear351c 10,433 Posted April 13, 2018 On 3/24/2018 at 1:06 AM, SPArKy_Dave said: Hyundai iloads like to spit the turbo, after about 100,000km - usually taking the engine with it. $10k min, for a used engine too. A work colleague had it happen to theirs... The internet is littered with similar stories. It's a pity, as they are comfortable vehicles, by all other reports. yep, heard similar, though never had one. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
GspecZL 979 Posted April 13, 2018 Hyundai iloads like to spit the turbo, after about 100,000km - usually taking the engine with it. $10k min, for a used engine too. A work colleague had it happen to theirs... The internet is littered with similar stories. It's a pity, as they are comfortable vehicles, by all other reports.Exactly what happened at work. Boy was that a smokie test drive. Sent from my 5046I using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted April 13, 2018 my work van is a deisel turbo auto toyota hi ace,its hard not to smoke it up after a bit of rain,not sure what diff ratio is in it but has massive torque 1 GspecZL reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted April 13, 2018 note to self.. keep slow but reliable 500,000km 1987 mazda e2200 van, (engine done 80,000kms only) 3 gerg, bear351c and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
GspecZL 979 Posted April 13, 2018 my work van is a deisel turbo auto toyota hi ace,its hard not to smoke it up after a bit of rain,not sure what diff ratio is in it but has massive torqueYeah we have had a few of those. We had a petrol on hit 700,000ks before getting side swiped. Great little vans.Sent from my 5046I using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted April 13, 2018 we also have a 5 speed petrol and a auto petrol the auto is a dog unless you hold it flat 1 Slow250XC reacted to this Share this post Link to post Share on other sites
deankxf 21,128 Posted April 13, 2018 On 4/11/2018 at 10:20 PM, deankdx said: @CHESTNUTXE check these outhttps://www.ebay.com.au/itm/1979-Ford-Transit-Van/263599454801?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3D099ed6ac329e41e39fe0a1ab66a3fe72%26pid%3D100005%26rk%3D4%26rkt%3D6%26sd%3D263597826564%26itm%3D263599454801&_trksid=p2047675.c100005.m1851 https://www.ebay.com.au/itm/1982-Ford-Transit/292517022497?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20140106155344%26meid%3D7ac2b99debac41d19eb73d2ad0992b2c%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D263599454801%26itm%3D292517022497&_trksid=p2047675.c100005.m1851 this windowless one is cool, because windowless(and old school hurricane wheels in dumb transit pattern must be either welded and redrilled or custom orderedhttps://www.ebay.com.au/itm/Car-ford-transit/142753380787?hash=item213cc3b9b3:g:5cAAAOSwve1azXtm which one of these are you buying @CHESTNUTXE Share this post Link to post Share on other sites
GspecZL 979 Posted April 13, 2018 My Daily. 315 ex ambo. Would make an awesome camperSent from my 5046I using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,875 Posted April 13, 2018 My Daily. 315 ex ambo. Would make an awesome camperSent from my 5046I using TapatalkI've ridden in the back of one of these and it was like riding in a billy-cart. Did they have stiffened suspension or something for ambo duties? Sent from my CPH1607 using Tapatalk 1 GspecZL reacted to this Share this post Link to post Share on other sites
GspecZL 979 Posted April 13, 2018 I've ridden in the back of one of these and it was like riding in a billy-cart. Did they have stiffened suspension or something for ambo duties? Sent from my CPH1607 using TapatalkYep lifted a lot. Our standard order vans are completely different (more comfy in the back I bet) but the captains chair makes you forget it all. These get all the extras though. Rear separate aircon compressor glove box fridge. And a sporty spoiler hiding the massive fans. The spotties side and rear a good on early morningsSent from my 5046I using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
