deankxf 20,294 Posted October 31, 2017 black paint is cheap 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 The quickfool six fifty d/p came lets have a look at it. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 also fuel rail and connections and holley pump. Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 this is a CQ model cast throttle body and plate,entry level performance carb from here they just go up in price big time,good looking carby has plenty of features including 2 nice stickers 1 matt_lamb_160 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 i also noticed it has a 4.five powervalve fitted already,that will be very close to what size i will need for the crossy as it has quite a lumpy cam,most other holleys will have a six .five as std then measure with vaccum guage to suit,i plan to set this thing up east/west,and might pull the engine out soon for dummy fit just for a look. Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 yep its looking hardcore east west. 3 Outback Jack, gerg and matt_lamb_160 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 must be only about 1cm or so b4 hitting the rocker. 3 Valvebouncer, Outback Jack and XPT reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 and while at it just a dummy fit of pacemakers,is that gasket around the right way ? seems plug access is fouled,should the flat side of the gasket face outwards or inwards like the way it is atm ? or just trim it to suit ? seems it fits many crossy combo's ,bronco,cortina ,iron head ? Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 2 1/2 outlet with flange Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted November 2, 2017 That carby looks like a nice compact unit, seems much smaller physically than my Holley, could be the camera angles though 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 only thing im worried about is one of those long throttle return brackets when fitting east west,inline is not a problem. Share this post Link to post Share on other sites
gerg 10,871 Posted November 2, 2017 and while at it just a dummy fit of pacemakers,is that gasket around the right way ? seems plug access is fouled,should the flat side of the gasket face outwards or inwards like the way it is atm ? or just trim it to suit ? seems it fits many crossy combo's ,bronco,cortina ,iron head ?Could be one of those multifit ones that suit a variety of engines. If the holes line up and the ports are sealed, you could trim the rest no probs. Could also be upside down? Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
slydog 7,873 Posted November 2, 2017 Take the pipes off and line the gasket up and take a photo Front 3 face backward's or towards the rear rear 3 face forwards or towards front of car...from memory. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 its a 1 piece gasket Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted November 2, 2017 That gasket looks back to front. Back should be at the front etc.. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted November 2, 2017 Every extractor gasket set I get/use is 2 piece and front 3 and rear 3 are opposite. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 yes the std ones are 3 and 3 i have that set here as well,the manufacturer supplied this gasket with the headers and bolts too.i will flip it tomozza and have another look . Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 because the r/cover is taller than usual,im worried the throttle cable mounting east/west will be a problem maybe,unless using a 2 inch or 3 inch spacer to prop the carby up higher,has anybody run into this problem before ? Share this post Link to post Share on other sites
Mustardxf2 310 Posted November 2, 2017 Buy a bracket and find out, I will have to trim mine about half an inch to not stall on the rocker cover, the with 2" apacer.Sent from my Pixel XL using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 ok thanks what throttle cable are you using ? the std or v8 longer one ? Share this post Link to post Share on other sites
Mustardxf2 310 Posted November 2, 2017 Xg one, but running it east west I believe a standard crossflow one would be long enough since it's the same throttle configuration as the Weber Sent from my Pixel XL using Tapatalk 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 2, 2017 yeah its gunna be close ,lokar do a nice short bracket with springs ect. Share this post Link to post Share on other sites
CHESTNUTXE 7,318 Posted November 5, 2017 can someone give some input about wiring the positive red wire on the holley fuel pump to the oil pressure sender << as it states in the wiring diagram,how can the pressure sender operate the electric pump ? see picture or is it a saftey cut out Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted November 5, 2017 It’s looking fucking tough 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,294 Posted November 5, 2017 isn't it an oil pressure safety switch? (separate switch added with a T piece on BGDAV's XE) the instructions above show "optional" oil pressure switch, built in power cut when no oil pressure.. you should have a fuel cut in case of crash, either with the above oil pressure one, or even used a LPG safety cut (you had one in that car, i remember a pic) to cut the fuel pump if the motor stalls(in a crash etc) the gemini i have, gets it's signal from the alternator but the lpg cut gets it from negative coil, (tacho signal) 2 gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
