deankxf 20,294 Posted July 20, 2017 non air con is very basic and pressed steel. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 20, 2017 hmmm i wonder why i dont have 1 as pulled apart a non air engine that was complete with alt,this anchor is off the wagon Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 20, 2017 nope i dont have 1,i no the clevo has a small stamped steel bracket,i need to find a picture off one for a crossy. Share this post Link to post Share on other sites
ando76 4,354 Posted July 20, 2017 This is the brackets I make for the alternator. Stops the belt whip and flinging that occurs on x flows that cop a decent revSent from my iPad using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,294 Posted July 20, 2017 i would say if that one above stops the risk of chucking a belt, just get one.. BGDAVs V8 car chucked a belt at 6500 until he got a overpriced overengineerd awesome bracket that was one of the best parts bought for it in the end.. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 i cleaned and painted the bigger bracket. Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 and im ditching the idea of the clutch fan after deans video ,i have been struggling with this thing for weeks trying to get it apart without breaking it,if you look close some m/f has welded it to the nut so no way of coming off Share this post Link to post Share on other sites
dex 2,065 Posted July 21, 2017 All this top notch gear going in and on it ,, and your reusing the water pump,? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 nah i wanted the plastic fan Share this post Link to post Share on other sites
deankxf 20,294 Posted July 21, 2017 1 hour ago, CHESTNUTXE said: and im ditching the idea of the clutch fan after deans video ,i have been struggling with this thing for weeks trying to get it apart without breaking it,if you look close some m/f has welded it to the nut so no way of coming off being welded on, should be easy to remove anyway.. jam up the impeller blades and rotate the fan in clockwise direction(same direction engine turns it) but yeah, you wouldn't use one of those fans without the clutch hub working, they suck unbeleivable power when locked up(as welded) my ute wouldnt go over 60kmh and the temp guage was cold as.. (when my hub locked up once ) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 another bin job lol Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 i suppose some sought of electric fan will have to go on,i will sought that out later on . Share this post Link to post Share on other sites
dex 2,065 Posted July 21, 2017 6 hours ago, CHESTNUTXE said: nah i wanted the plastic fan Righto' carry on with the good work 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 seems many are using a el fan set up Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 21, 2017 yeah its a piece of piss. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 21, 2017 The crossy is finished i will be picking it up on monday afo,then onto the stand to start the final assembly,the single rail is also done,ol.m8 did the pushrod length and it turned out at 9.800 which i thought was weird cause the std length was 9.6,i asked him how is that possible after skimming the head and block its a longer pushrod,he said the adj top end will come out much different to the stamped steel bolt on rockers,i would never have thought of that so im glad he did it,anyway plenty to do next week 2 dex and deankxf reacted to this Share this post Link to post Share on other sites
Banno 479 Posted July 22, 2017 Thoughts or plans on headers and exhaust pipe work. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 22, 2017 yeah with the amount of cash i have already spent on it i may as well just go all out and get the aussie speed headers,and some sort of 3 inch single or dual like sly's ute,as i probly wont have it registed maybe a shortend exhaust allthou i did have a mad max intercepter style zoomies out the right hand sill just b4 the wheel arch but with a six cyl maybe only 3 pipes out one side or the aussie speed headers are actualy semi finished and 2 piece out let i think so that opens the door for 3 pipes out each side,ive been dreaming of this for a while and would look really crazy Share this post Link to post Share on other sites
Mustardxf2 310 Posted July 22, 2017 2.5" single muffler sounds good and not overkill, and be plenty for the crossflow Sent from my Pixel XL using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 22, 2017 this bitch is born to run Share this post Link to post Share on other sites
Banno 479 Posted July 22, 2017 54 minutes ago, CHESTNUTXE said: yeah with the amount of cash i have already spent on it i may as well just go all out and get the aussie speed headers,and some sort of 3 inch single or dual like sly's ute,as i probly wont have it registed maybe a shortend exhaust allthou i did have a mad max intercepter style zoomies out the right hand sill just b4 the wheel arch but with a six cyl maybe only 3 pipes out one side or the aussie speed headers are actualy semi finished and 2 piece out let i think so that opens the door for 3 pipes out each side,ive been dreaming of this for a while and would look really crazy Interesting plan. Personally I think header design is important with the effort and money put into a motor to get more out of it. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted July 22, 2017 I'm actually going back to a big single for street and mainly to remove weight and make it eaiser to do pipe drop on race day. Went for a 3.5" Hooker Aero Chamber and I'll add a Gonzo style race muffler and flange for a turn down so if @ PCM or events that require mufflers I'll still be legit but I can remove the the rear of the exhaust for weight saving and no real loss of power. 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 23, 2017 i found the stamped steel alt bracket was in another box yee haa. Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted July 23, 2017 A good second hand factory Ford crossflow water pumps may actually be better - having a cast iron impeller, vs pressed tin impeller on most or all, of the after market pumps. 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,321 Posted July 23, 2017 yeah i jumped in quickly when ordering stuff some time ago and got this one Share this post Link to post Share on other sites
