bear351c 10,270 Posted March 30, 2015 Hey all, the ZL is a bit too light in the steering department, (power steer), and was wondering if anyone had found a fix for this issue? Larger pulley on the pump? More Castor? XD p/s box? Share this post Link to post Share on other sites
Nath 1,975 Posted March 30, 2015 Put a screwdriver through the power steering pump Could always use an XD setup... Even the manual ones are pretty decent. Share this post Link to post Share on other sites
gerg 10,871 Posted March 30, 2015 There's a common mod that is a piece of piss once you know how. Google Saginaw power steer pump mod. Involves taking the pressure fitting out, removing the spool valve in that port and pulling apart the valve and taking a shim out or putting one in (I can't remember). The shims are just small washers. Fords have exceptionally high assist pressure at around 1400 psi, but dropping below say 1000 can give much better feel. 2 XTREME KARTS XF and bear351c reacted to this Share this post Link to post Share on other sites
Jiminy Kriket 133 Posted March 30, 2015 I've been thinking about how to fix this for years. thanks for the guide on what to look for gerg Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 30, 2015 Add shims. Where the hose bolts into the pump there is a plug behind which is the spool valve. Tap and it should come out and it has a big spring too. Check my old school ute thread for the mod. I added another couple of shims, steering is heavier now. Although looking to do a ts astra pump soon . 3 gerg, bear351c and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted March 30, 2015 Yeah thanks for that Far Quad, had a feeling it was add shims, not subtract. Makes sense as you're lessening the preload on the spring inside the spool valve as you add shims. A fucking Astra? You poor soul... Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 30, 2015 It's just fr the electric power steer pump... Share this post Link to post Share on other sites
bear351c 10,270 Posted March 30, 2015 Cheers for the info, fella's. Share this post Link to post Share on other sites
bear351c 10,270 Posted March 30, 2015 Add shims. Where the hose bolts into the pump there is a plug behind which is the spool valve. Tap and it should come out and it has a big spring too. Check my old school ute thread for the mod. I added another couple of shims, steering is heavier now. Although looking to do a ts astra pump soon . Hey Lord Far quad, cant seem to find your "old school ute" thread.....Is it on OzFalc.? Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted March 30, 2015 Actually xfalc. Eek! Share this post Link to post Share on other sites
bear351c 10,270 Posted March 31, 2015 Thanks matey. Will go look it up......... Same as this, I'm guessing. More washers, less pressure. Just need to know which size washers. Yanks just say #4 machine washer. http://www.ih8mud.com/tech/woody/ps-pump.html Share this post Link to post Share on other sites
tpak addict 1,909 Posted March 31, 2015 Do some pics if you do it bear..... I dont mind mine but just a tad heavier would be nice.... When I had the XE wagon years ago that was horrid. Could turn corners with 1 finger.... 1 bear351c reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted April 1, 2015 Letting the tyres down to 15-20psi has the same effect as adding 2 shims. 2 XTREME KARTS XF and Nath reacted to this Share this post Link to post Share on other sites
78xcgxl 241 Posted April 1, 2015 Leave the pump alone and get the wheel alignment sorted. Run maxmium postive caster through the cast rods and space the front upper control arms bolt 3mm for further positive caster gain. Power steering is no where light/ floating in my XC and ZH with awesome steering feel and about the same steering effort as my BA to about roughly slightly heavier. Handling also greatly improves my doing this. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted April 3, 2015 Will do Jim. If I get the kit/washers/urge..... Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted April 3, 2015 Yeah with five degrees pos caster it will get heavier Share this post Link to post Share on other sites
bear351c 10,270 Posted April 4, 2015 Don't remember the XC being too light on the steering from factory. Every XF I have driven has floated like a boat, steering with one finger. This is my daily, as well, so I don't go round corners at high speed, or anything harsh like that. That was why I was leaning toward the pump pressure fix, not the wheel alignment. Share this post Link to post Share on other sites
hendrixhc 10,920 Posted April 4, 2015 Cant believe you didnt go for letting the tyres down! Share this post Link to post Share on other sites
78xcgxl 241 Posted April 4, 2015 Don't remember the XC being too light on the steering from factory. Every XF I have driven has floated like a boat, steering with one finger. This is my daily, as well, so I don't go round corners at high speed, or anything harsh like that. That was why I was leaning toward the pump pressure fix, not the wheel alignment. Who ever did the wheel alignment on your XC must of done it correct, often joints who do wheel alignments use the wheel alignment specs for a manual steering car on a power steering car hence the floaty feel. Factory specs on power steering cars state they require more positive castor. This is not the case on manual steering cars as they will be to heavy to steer. Pump pressure is not the issue and would strongly advise to not mess with it, wheel alignments cost only around $60 so can't see why you wouldn't go down this route. Anyways just my 2 cents. 2 bear351c and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,875 Posted April 4, 2015 Actually xfalc. Eek! So copy it across...... slack bugger. Share this post Link to post Share on other sites
bear351c 10,270 Posted April 16, 2015 So, after doing lots of research and reading all the comments, (Cheers all), bought the kit from the 'States. Thanks Gerg. Comes with 5 washers and a few instructions, a collar to hold the spool valve in the vice and a new O-ring. Got a bloody "tennis elbow" from work last week, so wont be fitting it for a few weeks, but will upload pics and thoughts when done. This a common mod in the 'States to put a Saginaw (usually GM) power steering rack in Mustangs. Will try 3 shims to start, drop the pressure to around 1000 psi. Later dudes...... 4 tpak addict, SLO247, Crazy2287 and 1 other reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 16, 2015 Hope it didn't cost too much Bear, in my experience anything automotive usually has the value of its contents tripled merely by having the word "kit" on it. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
