deankxf 20,320 Posted September 26, 2014 keep a spare wire that will reach from the solenoid trigger in case it leaves you stranded one day(due to the neutral switch) can crank it on the positive post of the battery or put a switch on it. needle and seat seems likely in this case for running rough... turn the petrol lock off into the middle and crank it over for a bit, if it comes good will mean its stuck needle and seat. you should have fancy gross jet needle and seat for it in that shed? that might fix it. PS... take the holley with you when you go to Deni... at least you have a backup if the themoquad packs up. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
deankxf 20,320 Posted September 26, 2014 i thought the neutral switch had adjustment in it, rotates on slotted mounts slightly 2 XTREME KARTS XF and bear351c reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 26, 2014 keep a spare wire that will reach from the solenoid trigger in case it leaves you stranded one day(due to the neutral switch) can crank it on the positive post of the battery or put a switch on it. needle and seat seems likely in this case for running rough... turn the petrol lock off into the middle and crank it over for a bit, if it comes good will mean its stuck needle and seat. you should have fancy gross jet needle and seat for it in that shed? that might fix it. PS... take the holley with you when you go to Deni... at least you have a backup if the themoquad packs up. Cheers for the advice Dean!! Yeah dad sold a heap of Holley Grose Jets to Johnny Dyno back in the 90's and sold 2 to family friends of ours who raced V8 Commodore Cup. Yep definitely going to take the Holley as a spare carby to Deni!! i thought the neutral switch had adjustment in it, rotates on slotted mounts slightly Which way to rotate it? Left our right? It has elongated mount holes. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 26, 2014 Well i've adjusted the safety switch acording to my gregerys repair manual using a no. 43 drill shank (0.89" or 2.26mm) Share this post Link to post Share on other sites
deankxf 20,320 Posted September 26, 2014 Cheers for the advice Dean!! Yeah dad sold a heap of Holley Grose Jets to Johnny Dyno back in the 90's and sold 2 to family friends of ours who raced V8 Commodore Cup. Yep definitely going to take the Holley as a spare carby to Deni!! Which way to rotate it? Left our right? It has elongated mount holes. Well i've adjusted the safety switch acording to my gregerys repair manual using a no. 43 drill shank (0.89" or 2.26mm) did you add an extra few poofteenths to cater for the wear/slop in the 30year old linkages? i would do it with a multi meter normally. lock it into Park with the column shift, make sure the linkage is adjusted on the trans and IS in Park properly. then adjust the neutral switch till the meter reads continuity in park/neutral (and reverse) 3 hendrixhc, Trev Vaa and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 26, 2014 No i didnt think of that Dean, i'll concider it for next time. Theres a bloke on Ebay who makes the column linkage bushes. How do you adjust it with a multimeter? Share this post Link to post Share on other sites
deankxf 20,320 Posted September 26, 2014 No i didnt think of that Dean, i'll concider it for next time. Theres a bloke on Ebay who makes the column linkage bushes. How do you adjust it with a multimeter? put the wires into the neutral switch plug. then again, if you were quick(not to burn out the coil with motor off), you could leave the ign on and adjust it in Reverse till the lights light up.. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
BGDAV 1,873 Posted September 26, 2014 i had issues with my netural switch, i had to pull it off and spray with degreezes (a shit load) then blow it out with air, was full of 20 years of road gunk 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 26, 2014 Well after about 100 km's of driving last night it seems to be good now 4 NZXD, deankxf, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,892 Posted September 28, 2014 If you ever have the dissy out, suss out the advance bob weights. Cals XD wagon wasn't starting reliably when hot, so I helped to rebuild the dissy - replaced the pickup induction coil and greased everything else. The advance weights were seized up rock solid as the original grease had solidified. Seemed to start and run so much easier after the minor refurb. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 28, 2014 If you ever have the dissy out, suss out the advance bob weights. Cals XD wagon wasn't starting reliably when hot, so I helped to rebuild the dissy - replaced the pickup induction coil and greased everything else. The advance weights were seized up rock solid as the original grease had solidified. Seemed to start and run so much easier after the minor refurb. How easy is it rebuild the distributor? Might pickup another one and give it a go myself Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted October 7, 2014 Well i replaced the neutrel safety switch and it wont start in Neutrel or Park, wtf is going on? The reverse lights work when its in reverse and the column selector is right hard to move when i do up the bolts for the safety switch. It kicks over when you jump it from the starter..... Share this post Link to post Share on other sites
deankxf 20,320 Posted October 7, 2014 Well i replaced the neutrel safety switch and it wont start in Neutrel or Park, wtf is going on? The reverse lights work when its in reverse and the column selector is right hard to move when i do up the bolts for the safety switch. It kicks over when you jump it from the starter..... has it got a relay like the XF? if not, add one. Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted October 7, 2014 has it got a relay like the XF? if not, add one. Yes its got one, using the 6 cylinder starter motor Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted October 14, 2014 Well the problem was traced to a broken wire in the loom that leads down to the gearbox, starts on the key now But i'll still add a 4 pin relay like Dean said to do. 3 bear351c, xe1984 and gerg reacted to this Share this post Link to post Share on other sites
