Clevo120Y 815 Posted March 20, 2014 Some Trickflow 170 heads got delivered today for me to port for Wayne (Performance Carb Tune Perth) to run on a new 302w. Here are the specs of the engine that he sent me today. This is the list of bitsSTD 302w block 4.030" bore0 deck heightHead Gasket will be either .030 or .040 depending on final compEagle neutral balance CrankEagle I beam rodsProbe +8cc Dome top pistonsLunati solid rollerAdvertised Duration (Int/Exh): 273/279 Duration @ .050 (Int/Exh): 243/249 Gross Valve Lift (Int/Exh): .616/.624 ( but using 1.7 rockers so its 654/663) LSA/ICL: 110/106 Valve Lash (Int/Exh): .016/.016 RPM Range: 2500-7000 Victor jnr intakeWill be all motor no NOS or anything else and will be on E85Want about 13.5:1 compAnd will be in my XL falcon with 4200rpm stall and 4.11sUse will be street/strip So I put the head on the bench today to give me a base line to work with, I have to say the flow figures are a fair way from the advertised figures given by the manufacturer, I do have to take into account a bit of carbon buildup but not much, also I calibrate my bench to read a little low as to not give bullshit flow figures, I rather my bench read low than promise something that isn't there. intake exhaust 50 30.32 18.62 100 61.09 46.54 150 93.39 66 200 122.5 83.3 250 147.15 100.8 300 179.26 118.64 350 201.5 133 400 216.08 145.43 450 232.17 154.26 500 242.15 159.56 550 243.11 165.04 600 233.27 169.88 650 236.19 173.53 700 233.34 177.9 So my main aim is make the ports stable all the way to max lift and obviously gain some flow as well. I will be starting these heads mid next week as I'm just doing a set of L67 heads and manifold for a supercharged V6 engine at the moment then straight into these. I will keep you lot updated as I go 2 gerg and 93xf reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted March 20, 2014 Wicked, some Windsor gear, I'll be watching closely. Share this post Link to post Share on other sites
ando76 4,354 Posted March 20, 2014 how good are the low lift gains - flow doubles every .100 lift from 100 - 300. with a roller cam WOW off the bottom this thing will be wild. Head sort of slows from there and falls away quickly which is surprising. I wonder whether the heads are intended for the street/strip market??? I'm sure a bit of attention in the bowl and mid intact section will net some gain in the high lift. I'll be watching this one. Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted March 21, 2014 this thing is going to be a little power house..... head flow figures seem low, kind of surprised he didn't just sell the heads and buy some CHI 185s to suit a windsor.... what sort of hp/tq are you expecting from this combo? Share this post Link to post Share on other sites
ILIED 316 Posted March 21, 2014 I'm surprised people arent jumping for the P38s Share this post Link to post Share on other sites
Clevo120Y 815 Posted March 21, 2014 I agree that the heads are suited to the hot street market and would be brilliant on a 550 lift cam chasing great mid range power. I hope the engine goes around 520hp and 430ftlbs and the crank, this is if I can get the flow with the manifold on up to were I want it to be. 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted March 21, 2014 This is a bit of a budget build with stuff he already had, I'm not charging much to give them a tickle so outlaying more cash for new heads wasn't really needed. Wayne has blown combos for racing and stuff like that so this is just a "milder" combo for the street. 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted March 21, 2014 p-38s will suit the larger cube windors chaise, the intake runner is 240cc on them, thats bigger than a 4v intake runner. awesome head though. its almost worth building a windsor to use them Share this post Link to post Share on other sites
ILIED 316 Posted March 21, 2014 Fair enough, I didnt see their volume Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 1, 2014 I will put some pics up soon but the intakes now go 263cfm at just over 600 lift, with gains through out the lift range. I get the manifold this week which is the most important part to get to flow the numbers to crack that 500hp mark with this 302. Share this post Link to post Share on other sites
NZXD 2,328 Posted April 1, 2014 That's a good gain, considering it dropped off before 600 previously. Good work! Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 1, 2014 Yeah that was the main aim they start to drop off again at 650 now but still has 259cfm at 650. I would need to fill the floor to get the stability over 650. Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 3, 2014 Here are the final flow figures for these heads, next is the manifold. I will post pics when I sort my camera. IN EX50 33.22 21.4100 68.19 48.12150 103.64 72.75200 132.93 90.46250 160.94 107.67300 182.46 124.74350 202.1 140.6400 224.79 154.6450 244.04 160.21500 259.19 169.93550 267.07 174.89600 269.66 181.24630 271.11650 266.39 184.5700 250.61 190.2 2 gerg and Trev Vaa reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 16, 2014 Intake manifold pics, when I get the heads back I can port match them and finish the final taper in the runners. 1 Trev Vaa reacted to this Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted April 16, 2014 good improvement dude. still think it may hold it back a bit, but you have to work with what you have and you have made a MAJOR improvement over what it was before so good on you. have you measured the port volume post porting? would be curious to see the size difference pre n post. assuming they were 170cc to start with. Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 16, 2014 Cheers mate, they should crack 500hp which is Waynes target as long as I get the manifold right and flowing well with the heads. You know what, I didn't bloody measure the volume before I started and now I'm kicking myself but I will measure the volume when I get them back. Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted April 16, 2014 were they CNC ports? or just cast? if they're CNC id expect them to be within 1 cc either way of 170... Share this post Link to post Share on other sites
Clevo120Y 815 Posted April 16, 2014 Just cast mate, so probably smaller than 170 to start with. 2 Trev Vaa and Outback Jack reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted May 9, 2014 some pics of the ports. Intake exhaust 4 Trev Vaa, slydog, XPT and 1 other reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted May 9, 2014 Fuck your good at that bro...I don't have the restraint or control to do what you do. 1 clevocortina reacted to this Share this post Link to post Share on other sites
Clevo120Y 815 Posted May 9, 2014 Thanks mate, I'm getting better, the ports are slowly looking nicer the more heads I do. Still a beginner really but starting to get the touch 1 slydog reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 9, 2014 Interesting work on that intake, Do you find that knife edge up the back of the valve guide steadys it much? And im guessing its aiming 180 degs away from the direction of the runner? Act like a hydrofoil as such? Share this post Link to post Share on other sites
gerg 10,871 Posted May 9, 2014 Interesting work on that intake, Do you find that knife edge up the back of the valve guide steadys it much? And im guessing its aiming 180 degs away from the direction of the runner? Act like a hydrofoil as such? Not an expert by any stretch but that teardrop shape is the most aerodynamically efficient of all and is used on the wings and fins of aircraft as well as on various parts of racing cars... I would guess that the extended trailing edge stops turbulence behind the valve guide and stem and gives a cleaner stream into the cylinder. 2 Outback Jack and n00bus m@x1mus reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted May 9, 2014 Id imagine so too, How he gets it there is another question LOL long burr and come in thru the intake port? Share this post Link to post Share on other sites
Clevo120Y 815 Posted May 9, 2014 I can't take credit for the shape behind the valve stem, it is cast into the trickflow ports I just reshaped it because it's a pretty rough casting. Gerg is spot on with the reason it's there, it also acts a fuel shear. I use 6in long burrs. 1 thing I did discover with this head is the dramatic affect the valve shape has on the flow, a couple of valves were bent so we ordered a set of Manley race master valves, when I tested the heads again I lost flow everywhere, 10cfm in the lower lifts and 15cfm in the higher lifts. Comparing the shape of the stock valve with the manley I could see that the manley was a flatter tulip shape on the back of the valve. A bit of a search and the stock valve has a 12 degree tulip and the manley had a 10 degree. A change to the Manley flow master valves which have a 12 degree tulip bought all the flow back. So such a small difference can have a dramatic effect. 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
