slydog 7,873 Posted September 22, 2013 OK guys as the title suggests what tub liner paint have people used? I may use some or convince myself to paint the tub out side colour and LOOK AFTER IT but I like the tub liner idea with a top coat of car colour if possible? So help out if you can please. Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted September 22, 2013 Used that ripple finish shit applied with a schultz gun. Used the 3m water based stuff from supercrap, goes on okay and cleans up easy. I'd use the non water based stuff next time, the water based stuff is more sensitive to surface prep. Where you get dings and scratches can of black paint and bingo, looks schmicko again. Its cheap too about 25 bucks a bottle, and you'd need 2 to do the tray. Some back satin rattle cans to finish the gaps. Mind you with the work you have done back there, I'd just paint it satin black. The welds and general finish you got there is tops Rob. David Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted September 22, 2013 Personally i would just use a matt black killrust epoxy enamel, cheap, spreads well so you could do the whole tray with 2 coats for about $50-$60 and its hardy, will take a knock if its primed right and easily patched if it does scratch. Share this post Link to post Share on other sites
revhead 1,392 Posted September 22, 2013 is it a -plastic tub liner if so youl need plastic primer ,it is clear ,so one good coat will do,when applying top colour youl need to get elastic additive to put in the colour,so the paint can expand and shrink without flaking or peeling off the plastic,,if its steel clean up with thinners etch prime and blast may coats of colour on, with the plastic liner when 1st cleaning use truck wash gerni,etc let it dry then get a really soaked rag of thinners an wash with this to remove grease oil,etc Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted September 22, 2013 I think he wants to paint his new ute tray. Share this post Link to post Share on other sites
revhead 1,392 Posted September 22, 2013 Tub liner ,is the title, Share this post Link to post Share on other sites
hendrixhc 10,923 Posted September 22, 2013 You can use K&H Cguard which can be top coated. The solvent based product doesnt need pre-priming but the water based one does. Share this post Link to post Share on other sites
adrianphu123 73 Posted September 22, 2013 I used transtar rubberised undercoating on the bottom of my car, leaves a rough finish and is similar to Cguard i believehttps://www.tat-co.com/products/specialty-coatings/quick-dry-rubberized-undercoating-50-state-4363-f/ Share this post Link to post Share on other sites
noddy 451 Posted September 22, 2013 Re coat Albury give them a ring ill swear by there work after they did the old xh ute of mine was mint and I never damaged what they used Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted September 22, 2013 Hey sly. Just make sure what ever it is you use will slow down rust. Ive stuck my head under two tub liners, one in a falcon and one in a early hilux and the rust holes were as the water from washing and condensation just never really dried out. The tub liners look awesome but can be scary underneath. 1 revhead reacted to this Share this post Link to post Share on other sites
blackxt 699 Posted September 22, 2013 You can tint some tub liner paints in a few different colours . I used some on a mates ute . It was tinted red. Looked good. Needed 4 cans for good coverage. Can't remember the brand but I'm sure any helpfull paint shop should steer you in the right direction. I found it best to crank the reg on the compressor right up and spray it with really hi pressure. The stuff covers imperfections really well. I filled 4mm rust holes with it. <br /><br />Sent from my XT925 using Tapatalk 2<br /><br /> Share this post Link to post Share on other sites
Ants 6,370 Posted September 22, 2013 Just 2pac it, sif this ute will ever carry anything. 3 clevocortina, n00bus m@x1mus and slydog reacted to this Share this post Link to post Share on other sites
n00bus m@x1mus 465 Posted September 23, 2013 Why not get a sheet of 6mm conveyor belt rubber and trim it to fit neat in the rear section, then when u need to sit something in the rear just drop that mat in and your away. Share this post Link to post Share on other sites
clevocortina 1,109 Posted September 23, 2013 Gotta say im with Ants on that one just paint it bro Share this post Link to post Share on other sites
slydog 7,873 Posted September 23, 2013 Fuck him bro he doesn't have to prep or clean it...he's prob right though Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted September 23, 2013 Just 2pac it, sif this ute will ever carry anything. It will fall out the tray under acceleration. Why not get a sheet of 6mm conveyor belt rubber and trim it to fit neat in the rear section, then when u need to sit something in the rear just drop that mat in and your away. But don't leave it in. My brother xg had some rubber mat in the back and the tray is just a fucking mess. Held condensation under the mat against the tray floor. Its got more scale and flake than a drag queens makeup. I cut some of it out last weekend ahead of the fuel tank and it was horrible. Reckon I've got a new iron ore mine in the making in Adelaide. Share this post Link to post Share on other sites
Hatchy 23 Posted October 17, 2013 rapta spray liner is the shit goes hard as a rock and seals the paint underneath its textures to so hides alot of dents Share this post Link to post Share on other sites
