P100_Ute 460 Posted June 19, 2013 Thort i'd throw this up over here also. but fast track it a bit.Picked this up in Feb 2011. it was a 4cyl Auto.Got some new plates for it thanks to Sean.Swapped the 4cyl Auto out for a 6 Cyl T5 Manual (July 2011)6cyl inNeed to cut hole to Suit T5 Share this post Link to post Share on other sites
P100_Ute 460 Posted June 19, 2013 Engine went BANG on the freeway one morning. (September 2011)spare engine in shed all ready to go in. new oil pump and gaskets all round.Did a "Trash The Dress" shoot in October 2012 to get rid of the wifes dress as its sitting around collecting dust Professional pix Share this post Link to post Share on other sites
P100_Ute 460 Posted June 19, 2013 Time to upgrade the Diff to something a little stronger and Falcon 5 Stud pattern.I did some Measuring of Diffs and some googleing. I have seen others have used Hilux diffs but due to their width you either need to run deep dish or nothing as they are 100mm shorter than the standard Cortina diff.Today i pulled out a diff out of a 1992 Hiace. Its a G series like the Hilux so it has a 8" Crownwheel and 30 spline axles and its only 20mm shorter than a Cortina. Weighs in a 85 Kilo which felt roughly the same weight as the Corty diff so thats not bad.I also got some Disc Brakes to suit it off a 1998 Tarago which uses a 291mm Rotor and has internal handbrake which keeps it all neat.--- Share this post Link to post Share on other sites
Clevo120Y 815 Posted June 19, 2013 Great photos with the missus Tim. Very tidy car. Your welcome mate with the plates, I'm happy someone bought them that I knew and appreciated them. Share this post Link to post Share on other sites
Campo 869 Posted June 20, 2013 The hiace/hilux has falcon stud pattern and stuff doesn't it? How does everyone else do the 5 stud conversion, modify a falcon diff? Share this post Link to post Share on other sites
Tyler06 266 Posted June 20, 2013 The hiace/hilux has falcon stud pattern and stuff doesn't it? How does everyone else do the 5 stud conversion, modify a falcon diff? I got a diff built by Dave (pro250) with spool and falcon axles cut and resplined then he makes a backing plate and chucks on falcon discs and calipers. Just need to run AU on offset rims. Others just redrill the corty axles. 1 dougie77 reacted to this Share this post Link to post Share on other sites
Campo 869 Posted June 20, 2013 Ah right that makes sense Share this post Link to post Share on other sites
bear351c 10,273 Posted June 20, 2013 Cool photos of the wedding dress. Most chicks will hang onto them for years and years, never wear them again.......... Share this post Link to post Share on other sites
Tyler06 266 Posted June 20, 2013 Wats the plan for the front upgrade? Share this post Link to post Share on other sites
P100_Ute 460 Posted June 20, 2013 The hiace/hilux has falcon stud pattern and stuff doesn't it? How does everyone else do the 5 stud conversion, modify a falcon diff? Yes Hilux/Hiace runs Falcon Stud Pattern. i have both sitting here in shed and will get them both fabbed up to suit the car. so when i can afford a set of Convo Pro's i'll swap to the HiLux diff and bobs ya uncle. I have thort about the normal setup using cutdown falcon diff etc but i have descided to go this way as i think these diffs are stronger than the borg warners. they have 30 spline axles. i know people have broken them before but lots of people in the drag industry run them under rx3's running 9's etc. the axles are 33mm wide compared to the bw78 28 spline axles which are 30mm. And i like to try different things. and diffs are pretty cheap to source if things go wrong. for the diff + disc brakes to suit its $400.. and cost me bugger all to get my fabricator to swap over the mounting brackets from a corty diff to the hiace/hilux diff. got put onto a shop that can whip me up a tailshaft for about $300. so for under $1000. looking at almost bulletproof diff thats not a 9inch Share this post Link to post Share on other sites
P100_Ute 460 Posted June 20, 2013 Cool photos of the wedding dress. Most chicks will hang onto them for years and years, never wear them again.......... Yeh hence why we did it. It did cost me a trip to tiffanys in new york tho. so 25k for new york trip + trip to tiffanys = pricey way to destroy wedding dress. Wats the plan for the front upgrade? May speak to a PRO.. Dave? msg me your price. Share this post Link to post Share on other sites
SLO247 1,713 Posted June 20, 2013 Good to see you here, I enjoy your posts on Xfalcon. Sweet car too! Share this post Link to post Share on other sites
P100_Ute 460 Posted July 19, 2013 3 Ants, SLO247 and PH351 reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted July 19, 2013 Haha cool! Very creative. Congratulations to you both. Share this post Link to post Share on other sites
P100_Ute 460 Posted July 23, 2013 First present arrived already. Went and picked them up today. CRS 5 Stud Brake upgrade off another forum member for a absolute bargain so i had to take it. Share this post Link to post Share on other sites
Tyler06 266 Posted July 30, 2013 Loving it tim! Get her new donk in an next month its on :-) Share this post Link to post Share on other sites
P100_Ute 460 Posted May 10, 2014 picked up a set of extractors for the car and fitted them over the last 2 days. engine mount off completly and lift engine up to fit them.. other than that and a quick buff of bellhousing with grinder. they slipped in no worries... 2 nos2 and slydog reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted May 10, 2014 Annnnnd it sounds how much better??? 1 P100_Ute reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted May 11, 2014 Truckloads. Neighbours loved it last night straight off extractors. We got a test n tune street down the road here in Kwinana that I might test its powerskid capabilitys on. Then Wednesday night might take to Woop Ass Wednesday at Kwinana Motorplex and see its 1/4 mile time 2 slydog and nos2 reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted May 11, 2014 Video of The beast running. Click link to watch via facebook https://www.facebook.com/photo.php?v=10152459854838738&l=8582760546896795074 Share this post Link to post Share on other sites
bear351c 10,273 Posted May 11, 2014 Oooooooh, sounds cool.!! How do the ignition leads cope with the extractors up high like that? Any issues? Share this post Link to post Share on other sites
slydog 7,873 Posted May 12, 2014 Hell yeah bro...Good luck with the skids... P.S Is that the same flanno you wore to the Nats? Share this post Link to post Share on other sites
P100_Ute 460 Posted May 12, 2014 Havent failed leads yet. Only driven it twice tho. It could be. I wore a few flannos at nats so possibly as its one of my favs Share this post Link to post Share on other sites
P100_Ute 460 Posted September 8, 2014 Making the old girl Fast n Loud 3 Mixalis, Outback Jack and dougie77 reacted to this Share this post Link to post Share on other sites
P100_Ute 460 Posted September 8, 2014 These blokes didnt notice anything loud lol. 4 Mixalis, dougie77, slydog and 1 other reacted to this Share this post Link to post Share on other sites
