gerg 10,871 Posted August 20, 2018 Reverse rotation, but coolant still flows the conventional way? ie, out through the top hose? The only reverse-flow setup (I think) I know of was some Corvettes in the 90s (with the LT1 engine) sent water through the heads first and pushed it down through the block. Supposedly allowed more compression, timing, less emissions, blah. It was obviously a dead-end because LS motors went back to conventional in that area. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 im going down the wreckers now to get him to drop the 02 at my house,its funny when you flash the cash the boys down there get excited and eager to get it out from where its been hiding a few years,should have it on the stand by lunchtime. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 im going down the wreckers now to get him to drop the 02 at my house,its funny when you flash the cash the boys down there get excited and eager to get it out from where its been hiding a few years,should have it on the stand by lunchtime.The o2Sent from my SM-G570Y using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 The o2Sent from my SM-G570Y using TapatalkIts here ! The whezerSent from my SM-G570Y using Tapatalk 1 Free.51 reacted to this Share this post Link to post Share on other sites
deankxf 20,314 Posted August 20, 2018 bolt 2 gemini heads to it for better manifolds 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 So far stripped it down a bit it turns over very nice n smooth bolt 2 gemini heads to it for better manifoldsSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,273 Posted August 20, 2018 Man, those exhausts look sooooo restrictive. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted August 20, 2018 Man, those exhausts look sooooo restrictive. They are a set of extractors is worth over 20rwkw 4 CHESTNUTXE, deankxf, bear351c and 1 other reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted August 20, 2018 Wow.......... what about if you changed to a thermo fan, and added a salad bowl intake.? 3 Valvebouncer, CHESTNUTXE and deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted August 20, 2018 Never got my 289 running...... was gunna put it in my XP coop, but, swapped all the engine parts for Clevo stuff. Did a bit of research on the baby Windsor, had a XR Falcon block, crank, ported heads with screw in studs, etc.. wish I made it all happen, now. Dude at my work had a powder blue XM sedan with a 302 in it, made me drool everytime he started it. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted August 20, 2018 Its here ! The whezerSent from my SM-G570Y using TapatalkWow look at the size those exhaust ports... You could almost get your pinky in oneSent from my CPH1607 using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted August 20, 2018 13 hours ago, Thom said: 13 hours ago, bear351c said: Man, those exhausts look sooooo restrictive. They are a set of extractors is worth over 20rwkw What about low end torque though? Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 What about low end torque though? Im glad i didnt just start this up eweee but shes a roller and my first snag the 2 side waterpump bolts are om so tight that im gunna have to grind em off i think ,it will probly root the alloy housing but thats seen better days apart from that all plugs were ok and seems never really touched.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 20, 2018 Watch this video then just snap the bastards off 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 Watch this video then just snap the bastards offGot the dizzy out plus vb what is the best way to take the spider off do you 1st take out lifters n pushrods? Also it has these wicked steel shims or something for the rocker covers but fkn seal i have ever seen as this is my first 5.0LSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 20, 2018 Dunno mate, never dealt with the spider thingy. That shim is the rocker cover gasket. If they are ok you can clean them up and reuse them. They stick like shit to a blanket on the head though! 2 NZXD and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 the dogbones hold the roller lifters Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted August 20, 2018 Looks like your homo rainbow distributor, was built on 17th June 1991, Action Man. Did you see the crossflow for sale thread I tagged you in? Quite low km's! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 20, 2018 new predator comes out in sep,what do you mean dave ? Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted August 20, 2018 11 hours ago, CHESTNUTXE said: new predator comes out in sep,what do you mean dave ? About the Dizzy, or the Crossy? Share this post Link to post Share on other sites
Thom 6,654 Posted August 20, 2018 What about low end torque though? +25-30 ftlbs on a stock engine 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted August 20, 2018 11 hours ago, CHESTNUTXE said: the crossy 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,890 Posted August 20, 2018 11 hours ago, Thom said: 14 hours ago, SPArKy_Dave said: What about low end torque though? +25-30 ftlbs on a stock engine Does it move it up in the rev range though, I'd be interested to know. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted August 20, 2018 Does it move it up in the rev range though, I'd be interested to know. Nope just gains everywhere, this stock headers flow worse than cast iron manifolds 3 bear351c, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
