CHESTNUTXE 7,694 Posted August 19, 2018 Latley heaps of us are chatting about 302ws ect,,so i will start this thread with the 302w started showing up around 1968 in us and aust market and finished early 2000s,all sorts of names like mexican block or boss 302 block inc,there was many variants and roller blocks too. 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
gerg 10,875 Posted August 19, 2018 Reading about Mexican blocks: despite what some have said of them, they're no stronger in construction than US ones, probably stemming from their use in a lot of trucks... and the assumption made that they're somehow a heavy-duty casting. The iron is apparently not as wear-resistant, meaning bores wear out more quickly. Re: Boss blocks. They were essentially a tunnel-port block with 4V Clevo heads. Forged crank, 3/8" big-end bolts, The tunnel-port was a sad episode in engine failures. The ports were so extreme, that the motor had to scream upwards of 8500 rpm to make the numbers. The port runners were circular and so big that the corresponding pushrod had to go down the centre of it, running through a tube pressed into the head. Sort of like like the port entry from a red motor, albeit round, not rectangular. Sent from my CPH1607 using Tapatalk 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 19, 2018 Here are some specs taken all from Ford workshop manuals First are eb-edNext are ed xr8 sprintThese are xy Xw gtho supplement 3 Thom, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 baahhahaaaaaaaa it says max ignition advance is 9 deg on 351 cleveland lol.nothing more is permissable 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 i want this v8efi five litre down at the wreckers so we can strip it and sus it out,i think thom said they might have forged pistons from factory. 1 gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,433 Posted August 19, 2018 ..........and they sound a bit like this. 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 i bought the 302 efi engine from a nc fairlane im gunna get it tomorrow or later in the week it should be a roller block,does the sump vary from eb to xd/f ect ? 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 hey here is a good question if im gunna change this engine back to carby can i use the timing current efi timing chain cover or do i need to buy the earlyer one ,also do i need to change the balancer and flywheel back to 28once or just keep the 50 ounce ones ? Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted August 19, 2018 Try and play Gary Myers with a 302efi, and this is prolly what would happen - 2 matt_lamb_160 and gerg reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 19, 2018 hey here is a good question if im gunna change this engine back to carby can i use the timing current efi timing chain cover or do i need to buy the earlyer one ,also do i need to change the balancer and flywheel back to 28once or just keep the 50 ounce ones ? @NZXD Share this post Link to post Share on other sites
Thom 6,710 Posted August 19, 2018 i bought the 302 efi engine from a nc fairlane im gunna get it tomorrow or later in the week it should be a roller block,does the sump vary from eb to xd/f ect ? hey here is a good question if im gunna change this engine back to carby can i use the timing current efi timing chain cover or do i need to buy the earlyer one ,also do i need to change the balancer and flywheel back to 28once or just keep the 50 ounce ones ? The sump will be fine, you have to keep the 58oz balancer and flex or you will have horrendous vibrations (possibly even break the crank) efi timing cover only suits the reverse rotation water pump 3 gerg, NZXD and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted August 19, 2018 Reverse rotation, but coolant still flows the conventional way? ie, out through the top hose? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 Im woofing all this sushi but all i can think about is that 02 roller Reverse rotation, but coolant still flows the conventional way? ie, out through the top hose?Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted August 19, 2018 Here's what the Windsor will most likely sound like - 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted August 19, 2018 Reverse rotation, but coolant still flows the conventional way? ie, out through the top hose?Correct 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,694 Posted August 19, 2018 thom do our 302s have forged pistons ? Share this post Link to post Share on other sites
Thom 6,710 Posted August 19, 2018 Twin exhaust on my wagon, el short motor, gt40p's, au intake, stock manifolds and cats, twin 2 1/4 inch exhaust with x pipe 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted August 19, 2018 thom do our 302s have forged pistons ?Eb to 97 el are supposed to, late el and au have a dish top hyperutectic piston 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted August 20, 2018 12 hours ago, Thom said: 12 hours ago, CHESTNUTXE said: thom do our 302s have forged pistons ? Eb to 97 el are supposed to, late el and au have a dish top hyperutectic piston What about that other vid of it driving up the street, under load? Btw, is it really your birthday today? Share this post Link to post Share on other sites
Thom 6,710 Posted August 20, 2018 What about that other vid of it driving up the street, under load? Btw, is it really your birthday today?Yes it is, I'm 29 today, I'll dig up that video tomorrow Share this post Link to post Share on other sites
SPArKy_Dave 9,344 Posted August 20, 2018 13 hours ago, Thom said: 14 hours ago, SPArKy_Dave said: What about that other vid of it driving up the street, under load? Btw, is it really your birthday today? Yes it is, I'm 29 today, I'll dig up that video tomorrow Happy Birthday dude! Share this post Link to post Share on other sites
bear351c 10,433 Posted August 20, 2018 Way to go, old dude....another year gone by. Share this post Link to post Share on other sites
gerg 10,875 Posted August 20, 2018 Say what you like about the wheezor, but they always sound tits with a good set of pipesTwin exhaust on my wagon, el short motor, gt40p's, au intake, stock manifolds and cats, twin 2 1/4 inch exhaust with x pipe Sent from my CPH1607 using Tapatalk 1 NZXD reacted to this Share this post Link to post Share on other sites
Thom 6,710 Posted August 20, 2018 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
