SPArKy_Dave 8,881 Posted July 9, 2018 If the bearings are stock, they will have a tiny FORD oval embossed on the back of each bearing shell, along with a date code and the size. The head gasket will also have a FORD wording embossed on it, plus a date code. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 9, 2018 yep they have the oval dave,maybe a bit hard to see in pictures,im looking on e bay now for an item i have bought before its a factory replacement timing chain by endurotec cause the one thats on the engine is very sloppy,they are about $38.00 but i cant find em . Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 he even e mailed the docket for the engine in 93 ,was $500 back then. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 he even e mailed the docket for the engine in 93 ,was $500 back then.Im haveing a bad time getting the last 3 pistons out and autobarn sold me this stuff cause i couldnt find penatrineSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,292 Posted July 10, 2018 might work, spray enough of it on the back of the pistion and the cold might shrink it and break the rust seal? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 Yep got 1 more out might work, spray enough of it on the back of the pistion and the cold might shrink it and break the rust seal?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,292 Posted July 10, 2018 email back a pic... Fire it up... drop it in... 3 Outback Jack, CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 Its all fun n games i didnt pay much for it Share this post Link to post Share on other sites
deankxf 20,292 Posted July 10, 2018 11 hours ago, CHESTNUTXE said: Its all fun n games i didnt pay much for it i've learned a fair bit buying the $100 gemini engine too(ohc, similar to a smaller E eseries engine) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 it just so has it that i have another matching std size piston and rod combo identical to this one out of ryans blue xe engine ,if the pistons are too far gone. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 it just so has it that i have another matching std size piston and rod combo identical to this one out of ryans blue xe engine ,if the pistons are too far gone.Only 1 to get out now,here is the replacement chain but they are outta stockSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted July 10, 2018 If all else fails i have seen several siezed engines freed up by pouring coke into the cylinders. Works a treat. 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 Im still interested how that broken bit of metal got into the lifter gallery section and there is no broken lifters 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted July 10, 2018 'There is currently no broken lifters', definately had one at some stage lol 2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 10, 2018 Yeah weird could be the head wasnt taken off and couldnt fish some of the broken lifter out cause the head bolts were like new never touched Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 11, 2018 All pistons are out and 1st clean is looking ok,im gunna go after lunch to borrow a hone to clean the bores a bit and grab a can of black engine paint Yeah weird could be the head wasnt taken off and couldnt fish some of the broken lifter out cause the head bolts were like new never touchedSent from my SM-G570Y using Tapatalk 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 11, 2018 All pistons are out and 1st clean is looking ok,im gunna go after lunch to borrow a hone to clean the bores a bit and grab a can of black engine paintSent from my SM-G570Y using TapatalkA star is bornSent from my SM-G570Y using Tapatalk 4 matt_lamb_160, Valvebouncer, 77xcfalcon and 1 other reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted July 14, 2018 check https://www.precisionintl.com/ for engine parts like the timing chain it's $44.44 Part No. TC364B I've used them a bunch of times for engine parts, 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 14, 2018 hey thanks for that but i found 1 on friday yep 44 bucks Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 15, 2018 hey thanks for that but i found 1 on friday yep 44 bucksInteresting note see how on the xf piston and rod there is a arrow and also ring slots are different height but same rings suit both Sent from my SM-G570Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted July 15, 2018 Did you get the block hot bathed or what? It came up pretty clean by the looks of it. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 15, 2018 Nah just my usual degrease and scrub all it needs for a basic kero rebuild if i start farming work out the end profit of about 300 dollars is gone and not even worth doing i spend about 600 on parts and sell em for 990 re ringed new bearings timing chain ect and all parts cleaned and very affordable at 990 3 Valvebouncer, Outback Jack and 351XD_Fairmont reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 16, 2018 I spent most of the day cleaning up this E1 head almost there just another hour or so and its pretty good Nah just my usual degrease and scrub all it needs for a basic kero rebuild if i start farming work out the end profit of about 300 dollars is gone and not even worth doing i spend about 600 on parts and sell em for 990 re ringed new bearings timing chain ect and all parts cleaned and very affordable at 990Sent from my SM-G570Y using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted July 16, 2018 Do you take the valve springs off and lap the valves? 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted July 16, 2018 By the end of the day it looks heaps better but i will take it down to the machine shop and get ol m8 to check it over also fit new valve stem rubber things 1 Outback Jack reacted to this Share this post Link to post Share on other sites
