dex 2,065 Posted November 4, 2017 Is there a kit or something that shuts the lights off like on modern cars , to suit our ,,,,ahem ,, older vehicles,,? Just the lights on when walking to the back door at night would be a handy feature,,,,, not as if some dickhead had left his lights on today , only to come back to a " click click tick " moment ,, not pointing fingers at anyone .. 2 Outback Jack and SirkWhyXF reacted to this Share this post Link to post Share on other sites
hendrixhc 10,920 Posted November 4, 2017 https://www.ebay.com.au/itm/NEW-Headlight-Reminder-KC5317-Assembly-Required/253220386876?epid=1663784571&hash=item3af51c783c:g:g1EAAOSw7qdZ7BcW Share this post Link to post Share on other sites
deankxf 20,290 Posted November 4, 2017 i fit a $5.95?(jaycar)12V buzzer to all My cars now, just pick a 12v light feed(+) and another wire that is 12V ign on and goes to earth when ign is off... only catch, is if you have the lights on with ign off for a reason the buzzer makes an annoying noise.. i used to fit this one which jaycar don't stock(think dick smith electronics used to stock it) the beeper fades out after 10 seconds so you can keep the lights on if wanted http://www.ebay.com.au/itm/Flashing-Headlight-Headlamp-Light-Warning-Alarm-Alert-Reminder-Buzzer-Beeper-Car/380502293676?epid=1105509746&hash=item5897b43cac:g:qnIAAOxy3zNShNgz Share this post Link to post Share on other sites
dex 2,065 Posted November 4, 2017 Not the types ,, intentionally leave lights on , to allow getting to the house ,, then after a time ,, they turn off to save battery . As modern equivalent 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,290 Posted November 4, 2017 hadn't seen one, but couldn't be hard to do.. get a turbo timer and hook it to headlights 2 dex and Ando81 reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted November 4, 2017 Theres an idea ,, spot on . Share this post Link to post Share on other sites
Crazy2287 1,886 Posted November 4, 2017 Could be done with about 1dollarydoo worth of electronic components if you were really keen. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted November 5, 2017 Could be done with about 1dollarydoo worth of electronic components if you were really keen. I’m listening. Share this post Link to post Share on other sites
thorne 1,078 Posted November 5, 2017 13 hours ago, dex said: Not the types ,, intentionally leave lights on , to allow getting to the house ,, then after a time ,, they turn off to save battery . As modern equivalent You mean "Follow Me Home" headlights, the BA onwards had that function. Leave your headlights on when you left the car, and the headlights would stay on for a set amount of time (between 2-5min) before turning off automatically, or the owner could trigger it themselves by hitting the lock button on their fob. My FGX has it: despite my not actually having a driveway it's still handy. Unsure of they are any conversion kits for older vehicles, as many older cars tend to complain (ie: play an audible alarm) if you intentionally turn off the engine with the headlights still on (or could be upgraded to do so, providing on of those Jaycar kits); a conversion kit would have to bypass all that and then still power the headlights off the battery on a timer before killing them. An autosparky might know more, but there's the danger of letting the headlights drain your battery if something doesn't work right.... Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 5, 2017 You mean "Follow Me Home" headlights, the BA onwards had that function. Leave your headlights on when you left the car, and the headlights would stay on for a set amount of time (between 2-5min) before turning off automatically, or the owner could trigger it themselves by hitting the lock button on their fob. My FGX has it: despite my not actually having a driveway it's still handy.Look your door with the key manually, and then the car will be locked and lights stay on for their pre-determined time. Took me a while to realise that in my FG.Sent from my Pixel using Tapatalk 1 thorne reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted November 5, 2017 6 hours ago, Valvebouncer said: I’m listening. Well first we need to find out operating requirements for the circuit. So you want to turn off the car. Shut off the headlights switch but have them on a delay, get out of the car, and lock it, and have the headlights stay on for a predetermined time before shutting off automatically. You only want this to happen when the vehicle is NOT running. and you only want it to happen at night. I would recommend the easiest way to do this would be have a parallel circuit controlling the headlight relay, that operates off a momentary switch. So, all the cars systems operate normally. You turn off the headlights, and they turn off. Before you get out of the car, you push the momentary switch which activates the delay circuit, turning the headlights on for the predetermined time. Alternatively, if you push the switch before you turn the headlights turn off, the headlights will remain on, as the parallel circuit keeps the relay energized regardless of the position of the headlight switch. Ill just regurgitate something out of randomly chosen components. This would need to be bread boarded (prototyped) to ensure it works before building it and fitting to the car. You'll need to switch the relay to be negative triggered. Or use a separate relay in parallel with the factory headlight relay. A 10kohm potientiometer and a 1kohm 1/4w resister in series, and both paralleled with a 10uf electrolytic capacitor, this makes the delay circuit, varying the pot will vary the delay. One end is hooked to ground. the other is hooked to both the base of a bc555 NPN transistor, and a momentary switch. The other end of the momentary switch is to VCC (12v) to trigger the circuit. The collector is connected to the relay negative, via a diode (may be omitted depending on the final circuit) and the emitter is connected to earth. here is some more info. i just did a google search. https://www.homemade-circuits.com/simple-delay-timer-circuits-explained/ 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted November 5, 2017 Ill fess up ,,, i left the bastards on ,, no fun in an auto ,, click clik tic ,,, but it would be handy . Share this post Link to post Share on other sites
