CHESTNUTXE 7,310 Posted November 5, 2017 That optional part is a holley part i found out thru there catolouge,big sender with extra buttons ect,sounds all mumbo jumbo to me,i will just hook it up to the positive coil i think. Share this post Link to post Share on other sites
Slow250XC 1,513 Posted November 5, 2017 Just fyi incase you haven't taken the flange out of the headers yet, it tapers down another 1/4 to 1/2 in on the prewelded pipe 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 5, 2017 3 minutes ago, Slow250XC said: Just fyi incase you haven't taken the flange out of the headers yet, it tapers down another 1/4 to 1/2 in on the prewelded pipe im not sure what you mean by that XC can you explain a bit more thanks m8. Share this post Link to post Share on other sites
Slow250XC 1,513 Posted November 5, 2017 im not sure what you mean by that XC can you explain a bit more thanks m8.If you undo those three flange bolts and pull out the flange, there is smaller pipe welded to the flange.Currently sitting inside your collector lolNothing a saw can't fix 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted November 5, 2017 Took me by suprise last week when it fell out of my new set as i put them in the shed. 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 5, 2017 bahahahaaaaaaaaaaa i thawt you where talking about the header flange not the outlet ok. Share this post Link to post Share on other sites
Slow250XC 1,513 Posted November 5, 2017 Hahaha 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 6, 2017 with the gasket flipped over the fit looks much better and plugs are accessable,than the way i first put it on. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 6, 2017 I think it fits the OHC donk as well, as the port spacing is the sameSent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted November 6, 2017 That gasket is weird. I’d peg it, it would give me the shits trying to change plugs- which you will need to do often with this engine. 3 CHESTNUTXE, matt_lamb_160 and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 6, 2017 speaking of plugs i was just gunna go for the std ngk or similar 6 range heat or should i go for a 5 Share this post Link to post Share on other sites
deankxf 20,288 Posted November 6, 2017 i'd be shaping that gasket to the extractor flange.. maybe clamping it to a sheet of wood and cutting the excess with an angle grinder(or binning it for one that fits) 2 CHESTNUTXE and slydog reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 6, 2017 i do have the 3 and 3 one here Share this post Link to post Share on other sites
broken-wheel 659 Posted November 19, 2017 On 28/07/2017 at 7:44 AM, CHESTNUTXE said: he is old school and built a million of these over 40 years and reckons something to do with delivering more oil to the rear as the hole is tiny for oil compard to the front hole if that makes sense i think he means the size of the hole which gives oil to the bearings,i will ask him again this afo ,when i bought the block in thats the first thing he was intending on doing,could be similar to the clevo thing where it doesnt get enough oil ,but in a daily drive or mild performance engine i doubt its worth it,will post more info when i ask him about it,as others say its totaly unessecary and could be right,i just went with what he reckonds,didnt want to rock the boat as he gets cranky very quickly,i can always just unscrew it and plug the hole with a plug,i was actualy against it but he chucked a spastic when i doubted his work lol. normally you would run a drill through the oil gallery all he way to the back of it, most machine shops have this stupid long drill bit thing, they do it when they do a line bore this will ensure the oil gallery is the same size from front to back but I guess he is old school and you NEVER want to argue with grumpy old men or tell them EFI or programable ignition is better build seems to be coming along nicely! what guide plates did you end up using? cut down clevo ones? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted November 19, 2017 he did do something like that,secret old mens buisness,but i got rid of ol.m8's oil mod and just blocked it off because the factory est dizzy cover is in the way and im over it,later down the track if i amp the motor up even more which i will,i will re wire the dizzy so the oil mod can be used,i just want to get it up and running atm with the factory igniton,then add the juicy msd and coil,the guide plates yes were cut down clevo and quite tricky to set up 1 by 1 as i had never done a solid before ,all seems good i put the engine in my xf today if you go to action mans 92 ute build. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted November 19, 2017 oil pressure sensor is right at the back so you know if the PSI per 1k rpm is not enough .... but never seen issues with oiling in crossflows 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted February 11, 2020 oil pressure sensor is right at the back so you know if the PSI per 1k rpm is not enough .... but never seen issues with oiling in crossflowsWell the engine is creating a bit of interest as its for sale and comes with heaps of parts ,i reckon dean should put this in his geminiSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,288 Posted February 11, 2020 42 minutes ago, CHESTNUTXE said: Well the engine is creating a bit of interest as its for sale and comes with heaps of parts ,i reckon dean should put this in his gemini Sent from my SM-G570Y using Tapatalk it's been done, i like the 1UZ turbo for gemini though wheres the turbo... 2 CHESTNUTXE and Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted February 11, 2020 man thats a pipe dream 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 12, 2020 Fuck they really stuffed that in thereSent from my CPH1903 using Tapatalk 2 CHESTNUTXE and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted February 13, 2020 SOLD $3200 ggrrrrrrrrrrrrrr i lost a lot of money but cant win em all. 1 gerg reacted to this Share this post Link to post Share on other sites
2redrovers 21,400 Posted February 14, 2020 Maybe they won't show and you'll get a second chance 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted February 14, 2020 i have had quite a few ask mate have you still got it after i did a deal with a bloke who is gunna pick it up soon. Share this post Link to post Share on other sites
broken-wheel 659 Posted February 14, 2020 Typo 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted February 15, 2020 TypoThe new owner paid half and another half when pick up its really weird how all the most expensive things i have ever sold the buyer has dep the cash even without seeing it ,cars included my xe chestnut sold for $22500 and he put it straight in my acc i love it when a plan comes together Sent from my SM-G570Y using Tapatalk 2 gerg and 2redrovers reacted to this Share this post Link to post Share on other sites
