CHESTNUTXE 7,332 Posted August 6, 2017 thanks mate,i suppose thats the one,i will go to supercheap and get some,cheer's,i wonder would it be wise to use on all the head bolts ? or only the number 13 bolt as described. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 6, 2017 we got it $2 cheaper in store than online order Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 The solid lifters are in with a nice wipe of assembly lube. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 tourqing the head down now in 3 steps 55,65,75ft/lbs and 55lbs on the number 13 bolt Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 starting to look a bit more like it Share this post Link to post Share on other sites
Mustardxf2 310 Posted August 7, 2017 No head studs? Sent from my Pixel XL using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 nope,will get em next time the head comes off,i already jumped in months ago and started ordering stuff, didnt think about that so just using what i have first time around . Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 just doing a quick look at the rocker aseembly Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 wear mark look pretty spot on ,on the. tips 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 i couldnt work out how to screw the studs in while trying to get the right angles on the cut-guide plates so i rang ol.m8 and gave me some advice,i spent an hour dummy assembling the studs and rocker gear then marking in pen within a couple of thou where they should go b4 putting 45lbs on the studs,then if nesscercary use a tiny punch to adjust so the pushrod isnt hitting the guide plate wall,well something like that. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 i also put the cover on just for a look ,i think the breather should be at the front yeah ? 1 dex reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 and just for the hell of it loosly bolted the intake farkn looks mean.i will probly mount the carby east/west like mustardxf was saying. 2 Banno and dex reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted August 7, 2017 You might find it hard to close the bonnet with the breather at the front. 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 7, 2017 i will buy some lock tite today for the rocker studs and have a crack at the top end. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 8, 2017 roller rockers are done ,020 on inlet and 022 on exhaust,i took my time ,about 1 1/2 hours to put studs in and lash rockers. Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 8, 2017 also placed cover on. Share this post Link to post Share on other sites
dex 2,065 Posted August 8, 2017 No lube ,,? First fire up will be dry run for a bit ,, wear those new bits away 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 8, 2017 you love shit stirring. Share this post Link to post Share on other sites
Banno 479 Posted August 8, 2017 What MSD ignition box are you hooking up to engine?Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 9, 2017 i havent bought that gear yet but probly the blue msd epoxy coil and the red msd 6 as described in the tfi thread the streetfire is about $250 cheaper but what the hell another 2 or 300 bucks buys the good gear,all up the ignition is gunna be about a grand 1 Mustardxf2 reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted August 9, 2017 The blue alloy body HVC coil is the pick for street use over the plastic cased unit. The plastic unit is for short burst use as stated by MSD and I have to say I have burn out a blue and red phenolic HVC body coil's but not a alloy unit yet. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 9, 2017 thanks for that info I will get it Share this post Link to post Share on other sites
CHESTNUTXE 7,332 Posted August 10, 2017 if your going to use the aussie speed heat soaker plate approx 8mm you will need longer intake bolts,and for some reason the first bolt hole is a but tight for a normal type bolt head,so i will use a allen key one with a very small spacer.Normal bolts will be fine if only using a gasket. Share this post Link to post Share on other sites
ando76 4,354 Posted August 10, 2017 Yep studs with a 12 point nut or socket head cap screws. The runner casting gets in the way of that bolt and it's worse the further you step the manifold off the head. You can safely grind away a bit of material and fit a normal bolt head, but who doesn't like socket head caps screws or studs with 12 point nuts. Only one bolt sexier than a socket head cap screw and that's a button head cap screw. Oh they just do it for me those button heads. Yes I know I'm weird. 3 Slow250XC, CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
