CHESTNUTXE 7,363 Posted April 24, 2016 I have a leak at the flange fitting at the front of the 750 vac,rear is ok,i have tried normal thread tape,and also a white paste sealer,nope that didnt work,is there a correct tape used for gasoline as i am finding the white tape getting eaten by the fuel. Share this post Link to post Share on other sites
Jestr75 41 Posted April 24, 2016 I have used Ultra Black sealant on fuel fittings before but it was only on a minor weep. Share this post Link to post Share on other sites
hendrixhc 10,922 Posted April 24, 2016 I used the aeroflow sealant on mine. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted April 24, 2016 i checked the front bowl thread it looks ok,so i suppose its the rail,i actualy cut a d/p rail and re-joined it but thats not the problem,the join is fine,but i have orderd the correct one for a 750 vac and it should get deliverd next week,i reckon its the thread on the old rail. Share this post Link to post Share on other sites
FOMOCOHO 882 Posted April 24, 2016 I have a leak at the flange fitting at the front of the 750 vac,rear is ok,i have tried normal thread tape,and also a white paste sealer,nope that didnt work,is there a correct tape used for gasoline as i am finding the white tape getting eaten by the fuel. Â Any of these should do it but yellow one has chlorine resistance too. Â Share this post Link to post Share on other sites
gregaust 319 Posted April 24, 2016 Thread tape is only for use on your home plumbing . It has no place on a carburetor   If you have a leak at a flare fitting it is dodgy. Assuming it is a chrome fuel rail?? Some don't seal  4 sleepisforthedead, judgetread, bear351c and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted April 24, 2016 yeah its an old one i had from my last 750 d-p,i orderd a new one to suit the vac,i just want to be shore when i install it,its funny the first time i installed it with the tape it didnt leak ?,but now i no what type to get cheers guys. Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted May 4, 2016 yep the new fuel fitting worked 1st time,no tape,no leaks. 2 bear351c and gregaust reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted May 5, 2016 FYI, plumbers tape should be made of PTFE. Well, pretty sure ALL the standard plumbers tape are PTFE, the only difference between the white and yellow is the thickness. PTFE does not react with mogas, or alcohol, so it's all fuel safe. The reason tehy list different thickness for different jobs is simply so you don't have to wrap so many turns when applying the tape. 1 XES reacted to this Share this post Link to post Share on other sites
