gerg 10,871 Posted December 27, 2015 Hi-volume is for shitty gear pumps (ie Chev and Holden)... The gerotor as found standard on Fords has more than enough capability to deliver the goods. 4 Outback Jack, Thom, slydog and 1 other reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted December 27, 2015 high volume and anti-pump up lifters Share this post Link to post Share on other sites
CHESTNUTXE 7,374 Posted December 27, 2015 can someone explain the anti pump lifter,does it act more like a solid ? i see on some cam company selections use 900 0r 900r lifter. Share this post Link to post Share on other sites
gerg 10,871 Posted December 28, 2015 A hydraulic lifter has a constant pressure going into it from the oil gallery, but the disc valve inside only allows oil in when the tiny cylinder inside it sees a clearance in the valve train. As soon as the clearance is taken up, oil is prevented from entering. Normal lifters have a bleed-down rate that might be say 10 seconds to a couple of minutes, so the disc valve admits small amounts of oil in to take up slack again. This happens constantly whenever the engine runs. You might hear a bit of clicking when your oil level is low... That's the lifters running out of oil more quickly than the oil system can supply. Conversely, you can have a spike in oil pressure and over-pump your lifters due to the little disc valve being overcome by oil pressure (I had this happen with a faulty relief valve on my oil pump). Lifter pump-up is caused by a combination of higher oil pressure at high rpm and the lifter losing pressure on the back of the cam lobe at higher rpm, which in turn causes the lifter to over-fill with oil and hold the valve open. It's often heard as a temporary misfire (mostly so at idle) after driving hard for a bit. Anti pump-ups have a high leak-down rate and a slower, more controlled pump up rate to try and prevent over-filling of the lifter. They are a high-tolerance, specialty item with lower production numbers so are more expensive. 1 ando76 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,374 Posted December 28, 2015 on the bigger cams it says use a 900r antipump up but on smaller to stock cams just use the normal lifter. Share this post Link to post Share on other sites
ando76 4,354 Posted December 28, 2015 Yes the bigger cam probably has a higher rev range - therefor the recommendation for anti pump ups. if you are getting that far up in the range - just go solid and be done with it in my opinion. more maintenance but seriously who doesn't like grabbing a beer and checking tappets during a routine oil change? 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted December 28, 2015 seriously who doesn't like grabbing a beer and checking tappets during a routine oil change? Lol...Except if it's on a Jap car... Instead of a beer in your hand, it's a bottle of dettol and a roll of elastoplast for all the cuts from the sharp and nasty bits 3 Outback Jack, Ando81 and ando76 reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 28, 2015 Good point. I have many cuts from that B18c7 in the mini, but that's mostly because there is zero room and lots of sharp nasties ready to attack. 1 gerg reacted to this Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 I checked the oil pressure today at work. At idle 25psi hot, 2k 45psi 3k 50psi and alittle over that was max oil pressure. Still not entirely sold on this cam. The power has definately moved up the rpm and pulls more revs. I still need to put the 3.7s back in the car as instructed by camtech. The cam before had more midrange/ torquer feel. I did feel a couple of times at wot what felt and sounded like the rev limiter(msd streetfire) at around 5k then cleans up. Need to look into it maybe the dizzy is on its way out Share this post Link to post Share on other sites
broken-wheel 659 Posted December 29, 2015 3.7 gears are huge, the 3.45 are good Share this post Link to post Share on other sites
slydog 7,873 Posted December 29, 2015 I checked the oil pressure today at work. At idle 25psi hot, 2k 45psi 3k 50psi and alittle over that was max oil pressure. Still not entirely sold on this cam. The power has definately moved up the rpm and pulls more revs. I still need to put the 3.7s back in the car as instructed by camtech. The cam before had more midrange/ torquer feel. I did feel a couple of times at wot what felt and sounded like the rev limiter(msd streetfire) at around 5k then cleans up. Need to look into it maybe the dizzy is on its way out Manual or auto and what dizzy ? Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 I previously had them in it and didn't mind them for around town. I think it will love it. The new cam pulls hardest up top so the the 3.7 will bring it down abit but 1st will be short. I need to sort the miss/ rev limiter problem first Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 4 speed, tfi with module in a te cortina Share this post Link to post Share on other sites
slydog 7,873 Posted December 29, 2015 3.7's will help it for sure but maybe a V8 rail would be better as they have a longer first gear. I'd check the plugs and do a AFR reading to make sure you havn't got a lean or rich spot. Share this post Link to post Share on other sites
ando76 4,354 Posted December 29, 2015 Those oil pressures readings sound like just a standard pump with standard relief. You will not see more than that 50psi with that pump. Did you dial this camshaft in? If not perhaps that is the issue - although camtech are pretty good and usually go in dot to dot anyway - but they all need checking. 3.7's would be fun, but in reality the torque these things generate usually means you can pull less teeth. Depends what you want from the car. Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 I dialed it in using TDC it went in dot to dot. Share this post Link to post Share on other sites
ando76 4,354 Posted December 29, 2015 Good stuff, well that rules that out. Perhaps it's just in the tune or a faulty dizzy. Sort of explains the limiter. Hard to diagnose ove the net Share this post Link to post Share on other sites
slydog 7,873 Posted December 29, 2015 Camtech ALWAYS go dot to dot on his grinds. Mal actually cares about that unlike a certain QLD grinder. 2 matt_lamb_160 and ando76 reacted to this Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 I still have to sort out the tune as I fitted an aussiespeed inlet at the same time as the cam swap. il wait till its tuned better but the old cam pulled the 3.45 better. The 510 seems to have a smooth broad power where the old cam cam on strong a pulled harder but not as broad Share this post Link to post Share on other sites
slydog 7,873 Posted December 29, 2015 Did you convert it to East West? That does make a very good differnce to a 6 banger. When I tried the 750DP and 4 barrel manifold on the ute it had a instant AFR change from n/s to e/w. Can't recommend this mod enough,it does make good difference. 2 wagoon and ando76 reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted December 29, 2015 Did you convert it to East West? That does make a very good differnce to a 6 banger. When I tried the 750DP and 4 barrel manifold on the ute it had a instant AFR change from n/s to e/w. Can't recommend this mod enough,it does make good difference. I would love to do this to mine but just not enough room.Would have to raise the carby so that means hole in the bonnet. 1 slydog reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted December 29, 2015 Spare bonnet for race day. Just saying.... 3 Outback Jack, slydog and wagoon reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted December 29, 2015 Spare bonnet for race day. Just saying.... And when the bonnet comes off after race day the carby spacer and the conversion will have to be changed back as well. Then its a retune because the east west conversion makes such a difference I couldn't run the same tune...just saying 1 slydog reacted to this Share this post Link to post Share on other sites
LJDB 103 Posted December 29, 2015 Could the east west be substituted for a carb spacer. I got bugger all room too under the bonnet. 1 slydog reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted December 29, 2015 no it can't, i made a 5mm spacer from alloy with counter sunk screws for the aussie speed manifold, the only issue is with those fancy throttle brackets, they foul the shock tower so you have to use the small one and I suggest a steel unit as the alloy can bend with 2 return springs you can also get the plates from Mark now Share this post Link to post Share on other sites
