Panko 2,482 Posted August 16, 2015 Has anyone converted an X series crossflow running a T5 to hydraulic clutch? Im getting ready to replace my T5, which means a new clutch, but whilst I'm at it, I have often wondered about converting it to hydraulic clutch if its possible. Cheers Share this post Link to post Share on other sites
RAWDEAL 222 Posted August 16, 2015 Ill try to find the company that makes kits for them. its an american mob thats what i was going to dohttp://americanpowertrain.com/ Share this post Link to post Share on other sites
PRO250 1,506 Posted August 16, 2015 Or get a older 250 hydo bellhouseing and just run a clutch master like all v8 x cars run and presto hydro clutch conversion. I do these for cortys as cooking a clutch cable is always a issue with those things 5 xSMOKEx, SirkWhyXF, wagoon and 2 others reacted to this Share this post Link to post Share on other sites
SirkWhyXF 1,533 Posted August 16, 2015 Mal Woods should be able to help you out, he did with my windsor to t5 in the xf. 1 Panko reacted to this Share this post Link to post Share on other sites
deankxf 20,319 Posted August 18, 2015 i had an Alloy CRS T5 bell housing for crossflow that was set up for LEADED(drivers side clutch cable) AND also Passenger side Hydraulic mounts. when i was converting My XE to hydraulic setup, Sunbury brakes said they do a vertical mount(as apposed to Falcon ofset mounted) clutch master which may be better suited to making it fit the XF firewall? i think it was an XY and or prior master cyl. but as PRO250 said, you could probably set up a a concentric clutch slave if you are handy with all the measurements etc or know which parts fit without hassle. 2 XTREME KARTS XF and wagoon reacted to this Share this post Link to post Share on other sites
xwagon 168 Posted August 18, 2015 I have done this. when i fitted the T5 behind the x-flow i had in my xw wagon, i used a cross flow bell housing and the pivot and fork off a three speed bell housing and welded a pad onto the bell housing to suit the slave cylinder, are you a member of x-falcon as it should all still be on there. still have the bell housing if you need to see pictures 4 XTREME KARTS XF, PRO250, gerg and 1 other reacted to this Share this post Link to post Share on other sites
