Raymond Daley 4 Posted July 27, 2015 Ok I need to know some of the machine shops that people have been using and do good work?? I'm thinking of P.E.A.C.H performance.. Share this post Link to post Share on other sites
judgetread 758 Posted July 27, 2015 Ive been using http://umrengines.com.au/ No complaints, work has always been what I asked for 2 Menice and slydog reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted July 27, 2015 Engine Engineering... 2 Menice and ando76 reacted to this Share this post Link to post Share on other sites
ghia35one 12 Posted July 27, 2015 slydog is right, these guys do nice work 2 ando76 and slydog reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted July 27, 2015 Engine engineering. Full stop. Been using them for 9 years now and never ever had a problem. Cam is an absolute guru on all engines and will give your x-flow the attention it deserves. Other shops will pay attention to the more common motors but give them a x-flow and they treat it as a taxi motor - no matter how much you try to convince them. That is the biggest problem with 'Name' shops. Engine Engineering and Cam in particular will look after your engine as if it were their own. Cam has done a great job on a lot of forum members engines - not just mine and my customer engines. Can not recommend them enough. If you decide to go with them, let me know as I will get Cam to look after you. 5 wagoon, XTREME KARTS XF, slydog and 2 others reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted July 27, 2015 Engine Engineering... +11ty million and 1 I can't speak highly enough of this shop, they did my engine and the work is outstanding. Their prices are very reasonable and the shop foreman Cam is an absolute bloody legend. He always keeps your budget in mind and will always consult with you if something needs changing. Plus Cam is a genius with hand porting and gets stuff spot on, look at my roller cam build thread for port results of my head. The results of my head porting show how good Cam is (and this ties in with what I said about him always considering your requirements) he ported the head to suit my camshaft specs, my budget,my type of driving and my engine setup. Most people struggle to get 2 of those requirements and he nailed all 4 without a drama. 3 Raymond Daley, ando76 and slydog reacted to this Share this post Link to post Share on other sites
Raymond Daley 4 Posted July 27, 2015 well i guess i will be calling them in the morning.. thanks guys Share this post Link to post Share on other sites
gerg 10,871 Posted July 27, 2015 Yeah I dunno not sure.... ;-) 1 wagoon reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted July 27, 2015 make sure you tell them ando, Rob and Ryan sent ya. Cam is on the shop floor so you will probably speak to Debbie in the office first. ask to speak with Cam - otherwise you will get the bosses 3 Raymond Daley, wagoon and slydog reacted to this Share this post Link to post Share on other sites
Menice 331 Posted July 27, 2015 been to engine engineering a couple times, always been looked after 1 slydog reacted to this Share this post Link to post Share on other sites
broken-wheel 659 Posted July 31, 2015 I'm in QLD and would NOT use UMR ever again. 3 Motors they have bodged up. I specifically gave them dimensions and they botched every time. Have used Engine Engineering once was within spec and quick turnaround. I now use Medham Engineering and cannot fault them. They are not cheap but they are very very very good. I guess if they do V8 Supercar stuff they know what they're doing. Share this post Link to post Share on other sites
slydog 7,873 Posted July 31, 2015 Cam did FPR/Prodrive cyl heads engines for a while. Share this post Link to post Share on other sites
broken-wheel 659 Posted July 31, 2015 they probably did but I was there picking up the clevo engine beginning of this year and there were two v8 supercar engines being assembled at Medham, they also did a xflow for me a few years back and they had some subi rally motors being built I got another xflow and clevo motors ready for machining and i'll probably use Cam as they are closer to me now. They do everything in house which is important to me and there are no 3 toothed fully tatted crack heads doing machining like 90% of the machining shops in Brisbane .... I think for heads you can't get past TK if it's a 2 valve head then i can bet my left nut that TK will beat anyone in Australia, he has proven it time and time again, i'm surprised nobody here mentioned him Share this post Link to post Share on other sites
ando76 4,354 Posted July 31, 2015 No. Cam actually did do their work, as well as all Bill Mann's (performance wholesale) stuff. Sprintcars, Drag motors the works. Me I'm glad he has left there and is back at Engine Engineering. The best hand porter in the business with the best seat cutters and valve treatments. When you can hand port a x-flow head and get 238cfm inlet flow on EVERY intake runner, have each intake runner volume CC identical and each chamber CC identical - all through hand porting - you are a fu.kn guru in my opinion. That's CNC machine accuracy - and he does it time and time again. Each to their own but when someone can show me someone that can beat that I'd be very interested to meet them. Oh and do it on a decent budget. Oh and he just did a quad cam, blown V8 ford motor and pumped 775rwhp with just a 2.3l roots style blower. how is that for versatility?? Share this post Link to post Share on other sites
broken-wheel 659 Posted July 31, 2015 so has that x-flow run a 10 yet? Share this post Link to post Share on other sites
ando76 4,354 Posted August 2, 2015 nah - mine's still on the bench - need more time and less work coming through the door so I can do my own stuff. Share this post Link to post Share on other sites
broken-wheel 659 Posted August 2, 2015 never complain about paid work! I been struggling to find time to zip up a bottom end for about 3 months now and haven't been fishing in 6 weeks! Share this post Link to post Share on other sites
ando76 4,354 Posted August 3, 2015 Yeah it just shits me when I don't get time for my own stuff. Had the v6 motor that I built for a customer on the dyno on Friday (made 214.7rwhp) arvo instead of my ute and then the bloody thing nearly beats me on Saturday night. That's not happening again. 1 wagoon reacted to this Share this post Link to post Share on other sites
