Squid 55 Posted June 8, 2015 I've had water leaking onto my feet when it rains heavily, or when I clean it with the high pressure sprayer! Any tips on where it could be coming from? Share this post Link to post Share on other sites
adrianphu123 73 Posted June 8, 2015 Most likely front plenum, just in front of the windscreen. Either that or the windscreen itself 2 bear351c and Outback Jack reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted June 8, 2015 Pull out the plastic gaurd on the inside wheel well and poke the end of the hose in the cowl drain to make sure it's not blocked, remove cowl cover & look in side for likes of dirt, leaves or a rust holes 2 revhead and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted June 8, 2015 Plenum or A pillars. Share this post Link to post Share on other sites
wagoon 2,429 Posted June 8, 2015 lift the grate where the windscreen wipers are and check down in the corners down near the guards. Use the tip Fordman said about flushing the channel that is at the end of the area under the grate as the are generally the reason for the rust. The other way to check for leak location is put a hose in the grate area and turn on the water slowly the check inside the car to see if you have leaks. If yes then that is a plenum leak (under grate area). 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,294 Posted June 8, 2015 windscreen seal leak it common, usually they leak from the top though and you can see it. (easy fix if they dont break the screen on removal about $60)rust in the plenum is also common, due to not being cleaned ever and being full of rotting leaves(also behind frond mudguards).. to even see it some times you need to remove the dash entirely..(you'd need to do this to fix it anyway)i scrapped a few cars in the past due to this rust, in hindsight i should have payed the *(at the time $500 odd) cost to repair them.. it might cost $1000 ish these days.. it might just be blocked drains too.. but at 30years old, rust is likely Share this post Link to post Share on other sites
Squid 55 Posted June 9, 2015 So after cleaning it out with the air compressor I found some lovely rust holes Water was still dripping through, even though it seems pretty solid with only surface rust on the drivers side Share this post Link to post Share on other sites
Squid 55 Posted June 9, 2015 I found this in my under dash travels I'm guessing a Bluetooth speaker of some sort, that I didn't put there Share this post Link to post Share on other sites
RAWDEAL 222 Posted June 9, 2015 lift the grate where the windscreen wipers are and check down in the corners down near the guards. Use the tip Fordman said about flushing the channel that is at the end of the area under the grate as the are generally the reason for the rust. The other way to check for leak location is put a hose in the grate area and turn on the water slowly the check inside the car to see if you have leaks. If yes then that is a plenum leak (under grate area). Â Â Dont do that . you wont like what you find 99% of the time haha 1 wagoon reacted to this Share this post Link to post Share on other sites
Free.51 2,721 Posted June 9, 2015 I did mine in the Zl recently vacuumed it wasn't bad as I did it probably a year ago then sprayed fish oil every ehere. 1 Squid reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted June 9, 2015 on the right hand side around the vent just above your feet  itl be rotten full of rust an ford in the wisdom put the only planuim drain on that side ,i hope for your sake its only got mud n shit built up in there ,but ill go with rust and rott 1 Squid reacted to this Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 9, 2015 I found this in my under dash travels   Flux capacitor 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted June 9, 2015 Dont take that out! Â You'll never be able to save ya father at the under the sea dance .... or get to see chuck berry live.... The damage you cause to the space/ time continuem may never be able to be repaired. Â Jack. 2 steve mcqueen and dougie77 reacted to this Share this post Link to post Share on other sites
wagoon 2,429 Posted June 10, 2015 could the leak be from the heater core? can tell by wet carpet on firewall and under feet in foot well Share this post Link to post Share on other sites
revhead 1,392 Posted June 11, 2015 if your running coolant red or green then the carpet ,would be green or red ,lol oh if your getting wet on the right side on ya feet you got rust.. Share this post Link to post Share on other sites
