Free.51 2,740 Posted March 6, 2014 What type of motor oils would u guys suggest for a 302 clevo 15w-40 20w-50 etc. It's not hi performance or anything cheers-Chris Share this post Link to post Share on other sites
BigCav 464 Posted March 6, 2014 depending on oil pressures etc i would use HPR15 pr HPR30 by Penrite, they have more expensive oils like there 10tenths stuff but a plain old 302 HPR is more then enough 2 XTREME KARTS XF and bear351c reacted to this Share this post Link to post Share on other sites
agentkiwi 110 Posted March 6, 2014 Main thing is to settle on a good 1 & stick with it to get the benefits of that particular brand. I use valvoline engine armour 15-40 in summer & 10-30 in winter. Bit colder in NZ!! My Ford shop manual lists 20-40 for a 302. 1 smiddo reacted to this Share this post Link to post Share on other sites
Free.51 2,740 Posted March 6, 2014 Thanks for the info agentkiwi Share this post Link to post Share on other sites
bear351c 10,273 Posted March 6, 2014 If it's done a million miles, then a thicker oil would be better. 40W-70 or similar. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted March 6, 2014 I'm using Penrite 20W60 in my Clevo and it holds good pressure when hot. Mine is only 20,000 k's old though. Share this post Link to post Share on other sites
ronny 204 Posted March 7, 2014 Good comments above Also keep in mind engine temps If your motor runs hotter or works hard, go for a bit thicker oil And if you do use a thicker oil, make sure you are gentle with the revs when cold until the oil pressure starts dropping off Share this post Link to post Share on other sites
Trev Vaa 1,185 Posted March 7, 2014 penrite hpr30 is a safe bet if you don't wanna spend squillions. clevos from factory ran 20w50 i think, either way, the bearing tolerences are huge. so 20w60 is fine for what you're lookin at, again unless its done a million miles, then there's heaps 25w70 or 30w70 i would hold off on 40w70 unless you are certain you need it. Share this post Link to post Share on other sites
Boss351 4 Posted March 19, 2014 Can't go wrong with Penrite HPR30 and just a Ryco Z9 filter for a pretty standard 302. Id change every 4 months or if it's a daily then every 5k kms Share this post Link to post Share on other sites
Boss351 4 Posted March 19, 2014 Can't go wrong with Penrite HPR30 and just a Ryco Z9 filter for a pretty standard 302. Id change every 4 months or if it's a daily then every 5k kms 1 Boss351 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted March 19, 2014 Make sure it's got "extra zinc" noted on the label. Flat-tappet motors need it. Share this post Link to post Share on other sites
