Mr Polson 10,214 Posted August 12, 2013 As the title implies, I'm considering putting a BTR behind the xflow in my wagon, I feel a 4 speed would be much better than the BW40. From what I've heard I can use a standalone trans comp from early e series. Biggest issue I think I'll face will be bell housing and or xmember. Anyone done this before or seen it done? Also - are there any differences between the BTR boxes? I know ELs don't have dipsticks, does that apply to all BTRs or just later ones? Any other things to be aware of/lookout for? Share this post Link to post Share on other sites
mcfly94 169 Posted August 12, 2013 The cost of bellhousing mod blows the idea out the window, I looked at it once and only found one bloke that did it, why not just get a rebuilt c4 way better than thr junk bw40 Share this post Link to post Share on other sites
gerg 10,871 Posted August 12, 2013 Or source an AOD from the states. As the name implies, it has an overdrive gear and lockup converter. Can be made tough and shift points/line pressure adjustable through valve body mods. Just an option anyway. Share this post Link to post Share on other sites
Thom 6,654 Posted August 12, 2013 Aod still has the same bellhousing issue Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 12, 2013 Its not gearbox strength I'm after - I believe BW autos to be fine. I know a stock one that sits reliably behind a mild Windsor, has done for years. Anyway, reason I'm considering a BTR is for the overdrive gear, rather than having top being 1:1 ratio. I'd rather a BTR than AOD simply for ease of parts if need be. Share this post Link to post Share on other sites
Gaz 1,085 Posted August 12, 2013 http://fordsix.com/forum/viewtopic.php?f=3&t=61132 He was a member on xfal....... but haven't seen him around lately 1 Mr Polson reacted to this Share this post Link to post Share on other sites
mcfly94 169 Posted August 12, 2013 Its not gearbox strength I'm after - I believe BW autos to be fine. I know a stock one that sits reliably behind a mild Windsor, has done for years. Anyway, reason I'm considering a BTR is for the overdrive gear, rather than having top being 1:1 ratio. I'd rather a BTR than AOD simply for ease of parts if need be. then go manual if you want overdrive, the amount of work involved on that bell is ridiculous, it would be easier doing a 4l conversion Share this post Link to post Share on other sites
gromet88 3,042 Posted August 12, 2013 yeah id go 4L convert 2 78xcgxl and mcfly94 reacted to this Share this post Link to post Share on other sites
GspecZL 979 Posted August 12, 2013 lol im keeping the BW40 for my 4L. Not for ever though of course. Now that you have bought all those nice shiny parts i assume you aint going 4L. 1 Mr Polson reacted to this Share this post Link to post Share on other sites
deankxf 20,317 Posted August 12, 2013 Its not gearbox strength I'm after - I believe BW autos to be fine. I know a stock one that sits reliably behind a mild Windsor, has done for years. Anyway, reason I'm considering a BTR is for the overdrive gear, rather than having top being 1:1 ratio. I'd rather a BTR than AOD simply for ease of parts if need be. if you fit a 4 speed auto you will need to change the diff ratio, the 2.77s wont like the BTR gear ratios anyway.,. with 2.77s in the diff and 3 speed auto it will get pretty much about as good economy its going to get anyway. if you wanted it to take off quicker by fitting 3.23 diff.. then you would benefit from an overdrive.. (theres a turbo 700 4 speed auto been fitted to a ford 6 in a transit van.. but once again.. cost of doing all the mods will outweigh any economy benefit.) Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 12, 2013 I will NOT be doing a 4L conversion, I like my tractor motor. Plus, a key reason of buying the wagon was it has recently (less than 10,00km) rebuilt motor. And I recently spent a decent amount of coin on polished EFI gear. 1 mcfly94 reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 12, 2013 http://fordsix.com/forum/viewtopic.php?f=3&t=61132 He was a member on xfal....... but haven't seen him around lately This is the kind of info I was after, cheers Gaz. Share this post Link to post Share on other sites
mcfly94 169 Posted August 12, 2013 oh so you bought the polished gear of nova! get that shit on asap 1 Mr Polson reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted August 12, 2013 5 speed 2 mcfly94 and 78xcgxl reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 12, 2013 Don't want a manual, I'm enjoying the laziness of automatic. Yeah, I did get the polished stuff. Hopefully putting it on this weekend! Share this post Link to post Share on other sites
mcfly94 169 Posted August 12, 2013 Don't want a manual, I'm enjoying the laziness of automatic. Yeah, I did get the polished stuff. Hopefully putting it on this weekend! Sweet as, I just picked up an efi rocker cover, and just had it polished, but I cant put mine on yet, need braded lines, polished pcv valve, manifold spacer, polished cover bolts etc.. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 12, 2013 I need to rebuild the throttle body and put in my PCV before I put the cover on, as well as remember to buy a christmas tree (vacuum branch thing) for the plenum chamber... I also eventually want braided lines. You should've grinded the cover before having it polished man, would've been easier than the spacer! Share this post Link to post Share on other sites
mcfly94 169 Posted August 12, 2013 Thats exactly what I didnt want to do, bit dogey, and dont plan on running standard intake forever Share this post Link to post Share on other sites
