Mr Polson 10,214 Posted August 7, 2013 So my wagon was running fine last night (stock EFI 250), then this morning when I went to start it it required a lot of cranking before it started, and upon start up was running really rough, needed throttle to prevent stalling. After it warmed it it became better (not as rough) but still not as smooth as it was yesterday. Checked most of the vac lines they seem alright, noticed a tick sound coming from around the dizzy area? Not sure if it may be related. To give an understanding of how rough it was, when I put it in reverse the motor shook the gear selector into 'N' Share this post Link to post Share on other sites
Thom 6,653 Posted August 7, 2013 You said you checked vac lines, but is the oil filler cap tight and the dipstick pushed all the way in? Share this post Link to post Share on other sites
ando76 4,354 Posted August 7, 2013 Dizzy cap and rotor okay? Check dizzy shaft for play. Maybe it's allowing the rotor to hit the contacts??? 1 Thom reacted to this Share this post Link to post Share on other sites
'Nova 997 Posted August 7, 2013 The Air flow metre Chris, do you have a spare one you can swap out and see if thats the issue? Had them cause similar issues previously! Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 7, 2013 Filler cap is tight and dipstick is pushed all the way in. Checked them along with the vac lines. Will check the dizzy tomorrow just in case. Don't have a spare airflow meter. Can you use the black lid ones or only the blue lid ones? Share this post Link to post Share on other sites
'Nova 997 Posted August 7, 2013 Blue lid is what I'd recommend! No idea if you'd have issues using black lid but may be worth trying? Share this post Link to post Share on other sites
bear351c 10,272 Posted August 7, 2013 Cracked dizzy cap ?? Igniton lead arcing ?? Did ya drive through deep puddles on the way home?? Share this post Link to post Share on other sites
LTD083 278 Posted August 7, 2013 Filler cap is tight and dipstick is pushed all the way in. Checked them along with the vac lines. Will check the dizzy tomorrow just in case. Don't have a spare airflow meter. Can you use the black lid ones or only the blue lid ones? You know where theres a spare! Black lid is for Bosch XE system. Wont work properly on XF. Share this post Link to post Share on other sites
Wes 214 Posted August 7, 2013 If you heard a tick near the dizzy and it's idling rough, I'd bet my balls it's a loose lead or a split boot/frayed lead arcing out. The tick makes me think it is loose, sitting on top of the socket arcing a connection. Happened to me a few times. Check the cap also isn't cracked. basically go over everything ignition. Share this post Link to post Share on other sites
deankxf 20,302 Posted August 7, 2013 mine did that a few weeks back from moisture on the dizzy cap.. could hear the spark jumping (if it was night, might have seen it) sprayed it with WD 40 and fixed.. my other ute was a classic.. think a rat chewed a chunk of the lead out.. was missing a bit anyway. Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 7, 2013 Well it's now running fine... No miss or tick. 1 'Nova reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted August 7, 2013 ahh the 'fix it fairies' have been at work again - lucky you - they don't come out that often - especially in these parts.... 1 Mr Polson reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 7, 2013 Well as long as the gremlins stay away I'll be happy... Should be alright, I don't feed the car after midnight. Share this post Link to post Share on other sites
slydog 7,873 Posted August 8, 2013 Hyd lifter issue... 1 Clevo120Y reacted to this Share this post Link to post Share on other sites
Thom 6,653 Posted August 8, 2013 Could have been a lifter that didn't bleed up at the time, what oil are you running? Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 8, 2013 Using Penrite HPR 15 (15W-60). Motor is still fairly new, under 10,000km on it. Share this post Link to post Share on other sites
bear351c 10,272 Posted August 8, 2013 I've had no issues with Penrite, ( others will disagree ), but when was it last changed? 10,000kays and it will be shot..... 1 slydog reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 8, 2013 Oh the oil was changed only 600 odd kms ago. Share this post Link to post Share on other sites
slydog 7,873 Posted August 8, 2013 Ute use to do it after a big rev or if left sitting for a while...like a few days.After some gentle kms it would be all good again. Share this post Link to post Share on other sites
