mcfly94 169 Posted May 18, 2013 Hey guys, picked up a new coil, msd blaster 3. just reading the info and it says to fit a 0.8ohm ballast resistor to points style ignition or stock dizzy? so do i need the resistor? Share this post Link to post Share on other sites
revhead 1,392 Posted May 18, 2013 if your running points with the msd ,and no resistor youl weld your points together after about 50ks if it recommends a resistor ,do it. i ignored instructions to fit one once ,and i tell you i hate walking, let me tell you it was a long dark walk Share this post Link to post Share on other sites
mcfly94 169 Posted May 18, 2013 Im running the two wire xf vac advanced dizzy Share this post Link to post Share on other sites
revhead 1,392 Posted May 18, 2013 like the EST dizzy Share this post Link to post Share on other sites
mcfly94 169 Posted May 18, 2013 Not sure, do you need the ballast for them ignitions? Share this post Link to post Share on other sites
revhead 1,392 Posted May 18, 2013 if the car had electronic igintion you shouldnt need a resisitor to drop the voltage 1 slydog reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted May 18, 2013 Only for points ignition. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Grabber 9 Posted October 10, 2014 Any xw xy clevo electronic ignition wiring diagrams Share this post Link to post Share on other sites
revhead 1,392 Posted October 12, 2014 pink with blue tracer ,goes to neg coil an is tacho feed ,red wire with green tracer is positve coil 1 NZXD reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted October 13, 2014 Take your dizzy cap, rotor button and black plastic cover off your dizzy. in that order. Does it look like this? http://i147.photobucket.com/albums/r301/David58Bug/New%20Stuff/3Points.jpg No? then you don't need a ballast resister. Share this post Link to post Share on other sites
