revhead 1,392 Posted May 12, 2020 Hey guys. I've done the engine n gearbox swap from eb back to ea using 1988 EA engine harness, I've changed it from auto to manual. Using factory manual harness,I don't have spark or a signal from ignition to starter.Fuel pump is working, it's a 4.0 into a 88 ea, it should plug in an runI've fitted new dizzy n coil. New leadsNow being a mechanic, I'm over looking something.This car DOES NOT HAVE SMART LOCK. Sent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 12, 2020 was it single point inj before Share this post Link to post Share on other sites
deankxf 20,292 Posted May 12, 2020 i've seen quite a few instances of the ignition switch failing in these 25yr old cars, any chance it's just failed now? @SPArKy_Dave @Thomare good with the wiring of these, might have a fusible link issue for eg, 3 revhead, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 12, 2020 I had an EA but never messed with the wiring. You say that the fuel pump is priming key "on", is there another relay for ignition as well? Are you getting injector signal? Is your computer earthed?Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 12, 2020 was it single point inj beforeMpSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 12, 2020 I had an EA but never messed with the wiring. You say that the fuel pump is priming key "on", is there another relay for ignition as well? Are you getting injector signal? Is your computer earthed?Sent from my CPH1903 using TapatalkGetting no spark no injector pulse even when I x the starter But nothing when I turn the key.Batteries fully charged, its all the original wiring an was working fineSent from my ATU-L22 using Tapatalk 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 12, 2020 Getting no spark no injector pulse even when I x the starter But nothing when I turn the key.Batteries fully charged, its all the original wiring an was working fineSent from my ATU-L22 using TapatalkIt has dash lights an everything works normal up to this point, starter relay clicks. But that's itSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 12, 2020 thom will chime in soon with an answer ,but what about the computer maybe the 88 only works with auto,did you swap them. Share this post Link to post Share on other sites
wok 206 Posted May 12, 2020 just a thought but did you bridge/join the inhibitor switch wires ? this used to be a trap when doing auto to manual on the older falcons, not sure if computer controlled or what in the EA....and maybe you wouldnt hear the relays go if they weren't joined ...i'm not sure on these "modern" cars.... 1 gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted May 13, 2020 6 hours ago, wok said: ...i'm not sure on these "modern" cars.... Me, neither........ 1 revhead reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted May 13, 2020 If the dizzy isn't getting power, then the ECU won't fire the injectors. I'd be checking some powers and grounds in the engine bay personally. You may have accidently blown a main fuse? 2 revhead and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 13, 2020 thom will chime in soon with an answer ,but what about the computer maybe the 88 only works with auto,did you swap them.Ea ecu cannot recognise auto or manual Sent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 13, 2020 just a thought but did you bridge/join the inhibitor switch wires ? this used to be a trap when doing auto to manual on the older falcons, not sure if computer controlled or what in the EA....and maybe you wouldnt hear the relays go if they weren't joined ...i'm not sure on these "modern" cars....Ea ecu doesn't recognise auto or manual, plus I've used oem manual wiringSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 13, 2020 If the dizzy isn't getting power, then the ECU won't fire the injectors. I'd be checking some powers and grounds in the engine bay personally. You may have accidently blown a main fuse? I'll have a look. I've added a few extra earth's to help.My tacho freaks put when I turn the key as well. I might pull the dash out as it's split an check behind there as wellSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 13, 2020 I'll have a look. I've added a few extra earth's to help.My tacho freaks put when I turn the key as well. I might pull the dash out as it's split an check behind there as wellSent from my ATU-L22 using TapatalkThe pip an tacho wire are getting power an the coil is getting power in an out, what I don't have is a signal from starter relay to starter.If I use a test light I get a signal. Once connected to starter nothing. However if I bridge starter it turns over fineSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted May 14, 2020 18 hours ago, revhead said: The pip an tacho wire are getting power an the coil is getting power in an out, what I don't have is a signal from starter relay to starter. If I use a test light I get a signal. Once connected to starter nothing. However if I bridge starter it turns over fine Sent from my ATU-L22 using Tapatalk High resistance connection somewhere in that circuit. It will support a low load - ie test light, but not high current - ie, starter solenoid. 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 14, 2020 High resistance connection somewhere in that circuit. It will support a low load - ie test light, but not high current - ie, starter solenoid.Starter solinod is fine,As I connect a starter switch to the solinod an the other to positive n press button starter works fine Sent from my ATU-L22 using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted May 14, 2020 Maybe run a temp relay to the starter so you can eliminate so much current going through the ignition switch. The starter solenoid takes about 8 amps to pull it in, a relay takes about 20 milliamps. Sent from my CPH1903 using Tapatalk 1 revhead reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted May 14, 2020 1 hour ago, revhead said: Starter solinod is fine, As I connect a starter switch to the solinod an the other to positive n press button starter works fine Sent from my ATU-L22 using Tapatalk Yes I agree - not the solenoid, look further back into the circuit - Dodgy relay, dodgy ignition switch, partially blown fuse, loose connection, etc. 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 16, 2020 Yes I agree - not the solenoid, look further back into the circuit - Dodgy relay, dodgy ignition switch, partially blown fuse, loose connection, etc.I pulled the dash out, this car is a very early 88 model an I found a bcm, it has 13 wires only, it must be dead blocking the starter circuit, in eb an later it has 2 wires for starter bue with a red tracer in an out, mine has purple in an blue with red tracer out. Il join these, then hopefully itl startSent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 16, 2020 i pulled the dash out,going the distance,go revhead 1 revhead reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 16, 2020 i pulled the dash out,going the distance,go revheadWell it is badly cracked n I do have another perfect dash here I'm just swapping wiring an Lower plasticsSent from my ATU-L22 using Tapatalk 1 1 CHESTNUTXE and deankxf reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 17, 2020 Well it is badly cracked n I do have another perfect dash here I'm just swapping wiring an Lower plasticsSent from my ATU-L22 using TapatalkIt's back together an still the same Sent from my ATU-L22 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted May 17, 2020 49 minutes ago, revhead said: 14 hours ago, revhead said: It's back together an still the same same ignition switch? 2 revhead and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted May 17, 2020 lets all go there and help him clutch start it,or tow it with the 400 or jacks outback rescue xg. 3 Outback Jack, revhead and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
