ando76 4,354 Posted March 5, 2019 So I thought I might start a topic on OGUN the clevo. Probably a little out of order but here he is being born. Hope you enjoy. 6 CHESTNUTXE, deankxf, bear351c and 3 others reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted March 5, 2019 is that for the next mad max film 1 ando76 reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted March 6, 2019 that's SNAPPY! love it! i saw it on your facebook feed and you had a headphone warning up.. i read that as..don't watch it on the phone, get the headphones! Share this post Link to post Share on other sites
ando76 4,354 Posted March 6, 2019 Yeah it's pretty lively and somewhat loud in person. Nah chestnut. It belongs to a good customer of mine. He is a big Ford man and this is his dig at the chev boys. Ford motor in a chev. 3 gerg, deankxf and bear351c reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted April 5, 2019 Put the inner springs in after camshaft run in. OGUN has had a bit of an update in the ignition department and a 1 gauge and o2 sensor and gauge. Couldn't get on the dyno for a bit so put a base line tune into it and gave it a quick test hit to monitor systems and see if any issues arose. Happy to report all went well, although the shifter needs a position indicator. Thank god for rev limiters and isky valve springs. Enjoy the vid. Dyno soon. 6 scottly, deankxf, Free.51 and 3 others reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted April 5, 2019 woo! getting a dyno video? be some sweet music under load 1 Free.51 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 6, 2019 Or some on-road shenanigans; just as good Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
ando76 4,354 Posted April 10, 2019 I drove it on the road on Saturday. It has old McCreary Dirt (flat track) bias ply tyres on the back. Cool as f..k but it gets seriously squirrelly when the stall hits. Dyno is happening next week. It feels strong, the big stall should rob some numbers on the dyno but I'm keen to see what it rolls up. 3 Thom, deankxf and gerg reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted April 22, 2019 OGUN did hit the dyno on Saturday, but sadly it appears the convertor is junk. Was fine in the shed skid but as soon as real load was put on it, it went south. Praying we can get a convetor in time for Northern Nats on the 3rd, 4th & 5th May. The tune is close enough and with the in-car afr gauge running the same as the dyno gauge - I'm happy to run it and log everything and tune at the track. I love modified cars....... 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted April 22, 2019 bugger, too much power. hoping it can get done in time, sounds like it Share this post Link to post Share on other sites
gerg 10,871 Posted April 23, 2019 It will have to be a well-built converter to handle pushing that big lump of iron quickly... Hope he's running a decent coolerSent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
ando76 4,354 Posted April 24, 2019 Sadly I have to admit defeat. The convertor/flexplate in the truck is the old ball c6/c10 - 11.5 bolt circle. No one has a convertor on the shelf to suit the application. I could change to the 10.5 bolt circle and get an off the shelf convertor to do the job but then the new flexplate will have to be balanced, it could cause starter issues, and I'm still not convinced that the box isn't damaged. I've since found out the current convertor is a re-use after the box had an issue and it wasn't cleaned out. I suspect that there could be crap thru the the rebuilt box, new trans cooler etc etc. The call has been made. I'm going to park it until I can confirm the gear box condition, get a suitable convertor built and re-dyno him. Too much risk in just sending it. Others would, but not me. Too much time and money at risk, for zero reward. There is another show a month later. We will aim for that. 3 deankxf, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted April 24, 2019 On a positive note I got it to actually steer. Have a look at the before and after alignment figures. Many neglect this most basic of things, but every car needs to have the alignment correct for the application. Sent from my iPad using Tapatalk 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted April 24, 2019 how did the king pin angle change to get better castor? can see the toe out for doing the burnies, and the neg camber i wouldn't have thought possible on king pins? what suspension is under it? Share this post Link to post Share on other sites
deankxf 20,288 Posted April 24, 2019 good call on not sending it till it's right also 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 24, 2019 how did the king pin angle change to get better castor? can see the toe out for doing the burnies, and the neg camber i wouldn't have thought possible on king pins? what suspension is under it? If it's a beam axle, they can induce a bit of neg camber by bending the axle in a giant press. Castor is done via wedges shoved in between the leaf springs and the axle. Sort of like a tapered lowering block. This is how all heavy vehicles are aligned. KPI is changed in proportion to the amount of camber change, seeing as the whole lot moves when you bend the axle. Castor is not affected by KPI or camber changes on a beam axle, but does somewhat affect the steering self-centering as would a castor adjustment. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted April 25, 2019 It has a Mitsubishi l300 front end welded on. Cortina rack with lengthened rack ends. Ken did it all in the bush with a tape and a welder. She definitely steers way way better now. 3 deankxf, gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted April 25, 2019 OGUN OR SHOGUN Share this post Link to post Share on other sites
ando76 4,354 Posted April 25, 2019 CLEVOLET 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 25, 2019 It has a Mitsubishi l300 front end welded on. Cortina rack with lengthened rack ends. Ken did it all in the bush with a tape and a welder. She definitely steers way way better now. I understand that the L300 chassis is often used in hotrod builds. Is that because it's a compact front end and can cope with a low ride height?Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
ando76 4,354 Posted April 26, 2019 Yeah. Compact, pretty robust and FORD stud pattern. 1 gerg reacted to this Share this post Link to post Share on other sites
