NZXD 2,328 Posted September 16, 2018 you can still use the block and stroke itYeah that’s probably what I’ll do, unless a good 289 crank turns up... The block is JG35, rods C8OE, crank is 2M...so yeah all 302. Are you running EFI in this little beauty? Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 16, 2018 it came with all the efi stuff but i only bought it for a rebuild to keep me busy and a learning curve cause im looking for a 351w engine a late model one to do up for myself,and there aint too much out there ,but not impossible,i intend to sell this one then use the cash and go again on the bigger one or even stroker ,one thing thats been bugging me lately is is there any point building a factory 351w cause ya can get a cheap 5.0 block and buy a 347 kit and almost same cubes ???? but we will see i will keep looking for one. Share this post Link to post Share on other sites
gerg 10,871 Posted September 16, 2018 Yeah the rule of thumb on a few 5.0 forums is the block we’re good for 500hp at the crank....but in saying that a Australian tuning place on Facebook get 550hp at the wheels with no issues out of the 302 block with boost...also depends on the tune and revs. The other point was that they didn’t like high rpm, I take mine to 6500 a bit once to 7000 and no issues. The later 351 roller blocks made in the 1990s split the cam tunnels really bad too. Maybe it’s just luck of the draw with them. Turns out that the 289 I scored is a 302, much disappointment. Sent from my iPhone using TapatalkNot 100% but I gather that HP figure that everyone bounces around is for an atmo engine, meaning to make that figure, you need to spin it to X rpm, which is what would kill the block (ie: harmonics, balancing stresses, etc.) Boosting makes horsepower without the rpm so actual HP wouldn't be so much of a factor. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 16, 2018 Not 100% but I gather that HP figure that everyone bounces around is for an atmo engine, meaning to make that figure, you need to spin it to X rpm, which is what would kill the block (ie: harmonics, balancing stresses, etc.) Boosting makes horsepower without the rpm so actual HP wouldn't be so much of a factor. Sent from my CPH1607 using TapatalkYeah you would be right, I have read a few articles where the blocks are ok NA with internal balancing (aftermarket steel cranks etc) and spinning them over 7 grand with no issues, so yeah the harmonics must be the main issues. Sent from my iPhone using Tapatalk 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,273 Posted September 16, 2018 XR GT's revved to 7,000rpm 50 years ago, with 1967 technology. Should definitely be doable today. 1 NZXD reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted September 16, 2018 XR GT's revved to 7,000rpm 50 years ago, with 1967 technology. Should definitely be doable today.The problem with the roller blocks is they are a lighter casting with a higher nickel content, also its mainly strokers that have the problem, with a stock stroke the seem to be able to handle 7500+ for a while but they are a bit of a time bomb more or less Not my photos but some examples of broken 5.0 blocks 4 gerg, bear351c, NZXD and 1 other reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 16, 2018 I think with my current 302 I might just keep leaning on it and see what happens, if it grenades then it’s a good excuse to build it better. I wanted the 289 for old school high rpm with big alloy heads and the go fast bits. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted September 16, 2018 ignore " most " of the ancillaries ,, could/should be a lot neater ,, 3 CHESTNUTXE, NZXD and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 17, 2018 My new pack of 4 roller lifters came as 3 or 4 of the old ones are a bit sus but the others seem good ignore " most " of the ancillaries ,, could/should be a lot neater ,,Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Thom 6,654 Posted September 17, 2018 Make sure when you install the dog bones the dot faces up otherwise the lifters can rotate destroying the cam in the process 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 17, 2018 Make sure when you install the dog bones the dot faces up otherwise the lifters can rotate destroying the cam in the process Thom what about which way the lifter goes in as 1 side has a metering hole ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Thom 6,654 Posted September 17, 2018 Face towards the oil gallery that runs along the lifter bores, but they will work either way around 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 18, 2018 i cant decide which timing cover to buy ? as i intend on selling this engine,maybe let the buyer decide depending on what car i suppose,but i would say the early one with a fuel pump hole. Share this post Link to post Share on other sites
NZXD 2,328 Posted September 18, 2018 i cant decide which timing cover to buy ? as i intend on selling this engine,maybe let the buyer decide depending on what car i suppose,but i would say the early one with a fuel pump hole.Unless you put the pump cam on the timing chain there isn’t much point in the old style. You would also need to change the pin on the camshaft to extend out so it can connect with the fuel pump cam. Sent from my iPhone using Tapatalk 1 Thom reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 18, 2018 Good point nzxd the cam came with no pin so i put one on it to line the timing gear up but i never new it had one for the pump gear ?Unless you put the pump cam on the timing chain there isn’t much point in the old style. You would also need to change the pin on the camshaft to extend out so it can connect with the fuel pump cam. Sent from my iPhone using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 18, 2018 Whats bugging me is this reverse rotation 8 mean 90 % of buyers would stick the engine in an older car so you would want the normal std rotation yeah ?Good point nzxd the cam came with no pin so i put one on it to line the timing gear up but i never new it had one for the pump gear ?Sent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 18, 2018 If someone could explain the later efi cover will only work with a reverse pump or can a normal pump be bolted to it say for a xw 302wWhats bugging me is this reverse rotation 8 mean 90 % of buyers would stick the engine in an older car so you would want the normal std rotation yeah ?Sent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,347 Posted September 19, 2018 as for mechanical pump, you can still run an older case and run an electric pump. the serpentine belt wrap is the reason for the reverse rotation ? (betting a normal pump wont fit) what makes you think someone with an older car would want a windsor over a clevo? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 19, 2018 hot rodders love windsors,also up to xy had a smallblock,roller cam very popular. Share this post Link to post Share on other sites
NZXD 2,328 Posted September 19, 2018 You can buy about 6 different front covers for Windsor’s, ones to suit reverse rotation but has the fuel pump hole, standard with or without fuel pump, ones with the crank angle sensor....mix in match...My one is standard rotation, with the crank angle sensor and fuel pump boss. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 19, 2018 I spoke to another m8 doing a eb v8 and he tryd a 289 cam gear to fit the 5.o and it dont fit for the fuel cam so he had to modify the factory one You can buy about 6 different front covers for Windsor’s, ones to suit reverse rotation but has the fuel pump hole, standard with or without fuel pump, ones with the crank angle sensor....mix in match...My one is standard rotation, with the crank angle sensor and fuel pump boss. Sent from my iPhone using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted September 19, 2018 I spoke to another m8 doing a eb v8 and he tryd a 289 cam gear to fit the 5.o and it dont fit for the fuel cam so he had to modify the factory one Sent from my SM-G570Y using TapatalkA few cams come with two different length pins to suit the fuel pump eccentric, most flat tappet and retro fit rollers. You can buy specific timing chain and gears to suit efi/roller cams and fuel pump eccentrics. Summit and eBay have all the bits. I learnt all this buy converting mine...brought a few bits twice in my learning...Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 20, 2018 Finally the felpro gasket set came just wondering what half of it is used for like 2 sets of intake ,these big funny circles which look like carby spacers and all sorts of stuffA few cams come with two different length pins to suit the fuel pump eccentric, most flat tappet and retro fit rollers. You can buy specific timing chain and gears to suit efi/roller cams and fuel pump eccentrics. Summit and eBay have all the bits. I learnt all this buy converting mine...brought a few bits twice in my learning...Sent from my iPhone using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 20, 2018 The inlet manifold gaskets will differ for the water ports , some early 289 are small and some 302 and 351 are different. There will be 2 sets of seals for the block to middle of the inlet manifold. Most importantly, make sure the head gaskets are around the right way! 1 bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,363 Posted September 21, 2018 The inlet manifold gaskets will differ for the water ports , some early 289 are small and some 302 and 351 are different. There will be 2 sets of seals for the block to middle of the inlet manifold. Most importantly, make sure the head gaskets are around the right way!Yes vb thats probly why i have the spider n lifters in place i think its right seems to only bolt on 1 waySent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
