bear351c 10,271 Posted January 31, 2020 Check the bearing in the extension housing while you have it out, slip the yoke in, and check for clearance. Can be a source of driveline vibrations. 3 gerg, CHESTNUTXE and gregaust reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted January 31, 2020 its already back together bear but how do i work out what speedo drive cog ? its confusing Share this post Link to post Share on other sites
gregaust 319 Posted January 31, 2020 10 hours ago, CHESTNUTXE said: So what is the go when trying to find the correct Speedo gear for say 2.92 ? The black spiral thing is the big gear i guess ? I also managed to get the navy seal out Sent from my SM-G570Y using Tapatalk No that black rubber seal is for the yoke . Depends on the yoke you use it's likely not needed . The speedo runs further forward . Speedo gear is same as what a C4 would be 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted January 31, 2020 thanks greg but what colour gear a 20 orange ? will more likley be 2.92 gear with 225 60 15 Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted January 31, 2020 i am pretty sure last time i did a fmx to normal falcon tailshaft say a eb one,i used a 1310 or 1320 yolk and it fitted perfect in the fmx Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 1, 2020 i am pretty sure last time i did a fmx to normal falcon tailshaft say a eb one,i used a 1310 or 1320 yolk and it fitted perfect in the fmxCleaned up the air cleaner and just gave it a small coat of paint but not the darker blue im waiting for from bc paints also had a clean up and found exactly what i needed its actually out of a box of crap from ryans place when i bought all his stuff also found correct bolts for sandwich plate and starter motorSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 2, 2020 Cleaned up the air cleaner and just gave it a small coat of paint but not the darker blue im waiting for from bc paints also had a clean up and found exactly what i needed its actually out of a box of crap from ryans place when i bought all his stuff also found correct bolts for sandwich plate and starter motorSent from my SM-G570Y using TapatalkCleaned up the alt and gave a light coat of paintSent from my SM-G570Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,271 Posted February 2, 2020 http://mustangpartstech.com/SpeedometerGears.html See if this link works..... Do you know how many teeth are on the drive gear.? 7 or 8? I'd say 19 tooth would be about right, but you may need to check the drive cog in the trans. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Boingk 865 Posted February 2, 2020 That's a schmick looking cleaner my good man. I should probably try and get stuck into the one that came off my old 302C. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 2, 2020 i want to go and inspect the block today and see how progress is going ,he is also gunna measure the shaft so i can buy a dizzy gear.i also want him to machine the decks just to clean them up a bit,and also check on those 72cc opens. Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 i want to go and inspect the block today and see how progress is going ,he is also gunna measure the shaft so i can buy a dizzy gear.i also want him to machine the decks just to clean them up a bit,and also check on those 72cc opens.Block is still in the tank so no looks for a while but in the meantime i got the new seal in plus a crossy rod smashes it in perfectSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Banno 479 Posted February 3, 2020 Is the 400 still going in the xf?Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 yeah,in 1 week i have fully rebuilt it ,talk about action.also ben from global trim gave me some original salt n pepper squid to fix my drivers seat. Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 also got some bolts for the talk konverta Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 check how good i shonked the rocker cover keeping the og sticker . 1 Fingers reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 now this ford light blue is not the colour i am painting everything just a base coat of 2 coats and the darker ford 1972 clevo blue is going over the top as a final coat. Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 all bolts were in pretty good order as well Share this post Link to post Share on other sites
Banno 479 Posted February 3, 2020 Up to you but I be going over all the spot welds and even welding up and plating engine cross member before putting such large engine in a xf ute.Late model xf are not built the same as a xd or early xe in steel quality. Even xg were ordinary. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 good question banno i didnt realy think about anything like that,cause once an alloy manifold and waterpump are added it brings it back to even lighter than a std 351c and fmx,or very similar,it wont have air con but i orderd the correct 400 saginaw pump bracket from the states and im hoping the std crossflow line will bolt in ,cause im using a saginaw pump ? Share this post Link to post Share on other sites
Thom 6,651 Posted February 3, 2020 I think banno was more concerned about the amount of instant torque that 400 will make, it might start stressing things a lot quicker than your old xflow would have 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Banno 479 Posted February 3, 2020 I think banno was more concerned about the amount of instant torque that 400 will make, it might start stressing things a lot quicker than your old xflow would have Yep seen these start cracking all the place and do have quite amount of flex later models. Torque and weight and underrated suspension is a great mix. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 so what do you recomend ? strip the engine bay or blast it back to metal and get a welder to do some stuff to it,or just some spots without stripping the whole engine bay. Share this post Link to post Share on other sites
Banno 479 Posted February 3, 2020 http://www.ozfalcon.com.au/index.php?/topic/8290-tips-on-welding-cracked-strut-tower-in-xg-ute/Have a read of this if your concerned.Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,317 Posted February 3, 2020 i pumped 80cc into this chamber so thats mega low comp. Share this post Link to post Share on other sites
Boingk 865 Posted February 3, 2020 Tuuuuuuuuuuuurboooooooooooooooooo.... 1 1 CHESTNUTXE and Fingers reacted to this Share this post Link to post Share on other sites
