LJDB 103 Posted May 31, 2018 With my o2 sensor in closed loop my cruise driveabilty is poor. The ecu is constantly altering the a/f and varies quite abit depending on temps. I also have low comp and mildish na camshaft which doesnt help. Before my current setup i changed from a redline 4bbl manifold to aussiespeed and they are definitely a better manifold. I agree that its the way to go but it can be made to work for now. 1 Undefeated reacted to this Share this post Link to post Share on other sites
Undefeated 76 Posted May 31, 2018 On 30/05/2018 at 0:27 PM, gerg said: You running a return line/reg or a dead-end system? I don't really like the latter because the pump is always cycling on/off. I reckon it would burn out pretty quickly doing that. Sent from my CPH1607 using Tapatalk It’s a Return line system.. same as normal EFI..the return line runs back to the tank. It runs a reg inside the Carb so no reg required to run it NA. there is many instal vids on YouTube, as I do each part will link a video on that subject. 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
Undefeated 76 Posted May 31, 2018 On 31/05/2018 at 9:36 AM, gerg said: I think he means the filler tube, which I can't see a problem with. The breather should come off a tree of lines that screw into the top of the tank via a small manifold, off to the charcoal canister. Sent from my CPH1607 using Tapatalk Exactly, the big filler hose gets a simple plumb into it ,and the return squirts in there. (nothing to do with the tank venting /charcoal system) the complex part for me atm is working out what air cleaner system to run, and how I’d like this motor to look, I like the idea of a blow thru style carb hat connected to a k&N pod or cold air box, but a nice air filter looks good too...and to be making sure I’ve got the right dizzy and Holley connector with plugs and leads to run programable ingnition.. it’s recomended to just do the 4 wire hook up first.. so a lot of guys don’t run the ignition side of Sniper EFi I noticed..( if not controlling timing, that’s a simple 4 wire hook up) and whats up with everybody bagging REDLINE??! This is a good little Aussie company success story.. who has supported the crossflow motor and others, and I’m happy to have there products on my old car..changing to any manifold is not going to net much on a street motor, the efi should atomise better than a 40yo old carb. .https://www.redlineauto.com.au/t-about.aspx 4 Outback Jack, NZXD, Slow250XC and 1 other reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted June 3, 2018 I wont bag on redline... noone else makes ironhead stuff lol Would love a 2bbl sniper setup but saving for jenveys, might be a wedding present to myself lol Been driving this thing yet? Share this post Link to post Share on other sites
Undefeated 76 Posted June 4, 2018 That sounds like a cool way to go.. I havnt fitted it in yet, still waiting on the fuel pump Share this post Link to post Share on other sites
Undefeated 76 Posted June 5, 2018 Well finally that Walbro fuel pump arrived today with the mounting kit, so now it’s time to start working on the car. 3 deankxf, Slow250XC and Outback Jack reacted to this Share this post Link to post Share on other sites
Undefeated 76 Posted June 5, 2018 On 31/05/2018 at 6:24 AM, ando76 said: What ignition inputs does it need. Cylinder position and a home like most - and what type of signal (magnetic - magnetic, hall - magnetic or Hall - hall). Cylinder poisition is easy enough using Hall. home could be a little difficult. Clarko and I have just finished the crossflow specific crank trigger kits. Uses msd magnets and sensors. I’m trying to figure all that atm.. which dissy to run. (Side note: yes I’m aware of a std Barra that recently run 350hp with just a carb and cams here in QLD ..but im no drag racer, it’s intresting to see what may be out there for the future.) Back on topic: for ignition control , it’s going to have to come latter. here’s the video of the Holley tech rep showing Phasing and dwell.. atm I’m scratching my head TBH as to what Distributor to run.. EST , TFI. I’m checking on Holley Sniper forums and seeing what USA Ford guys are doing, I will probably contact Holley directly and put it to them. In years to come people can look at this...hindsight makes a expert. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Undefeated 76 Posted June 6, 2018 I’m going to put this link in here for future reference. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted July 6, 2018 And then? 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Undefeated 76 Posted July 12, 2018 Still playing with other aspects of the car before installing. in this video theres Some intresting aspects, it’s a Blo Thru Turbo 6cyl..video shows some set up including the return line dumping into the filler hose. Share this post Link to post Share on other sites
Undefeated 76 Posted August 14, 2018 So here’s another cool feature that can plug into with the Holley sniper EFI.. its obvious holleys new roll out has been well thought out. Share this post Link to post Share on other sites
deankxf 20,288 Posted August 14, 2018 don't let BGDAV see it, he's already lost weight on the "car parts diet" (where you prioritise car parts over food) 3 Undefeated, gerg and ando76 reacted to this Share this post Link to post Share on other sites
Slow250XC 1,513 Posted December 26, 2019 So did you get it all sorted?Sent from my SM-J330G using Tapatalk Share this post Link to post Share on other sites
matt_lamb_160 252 Posted January 14, 2020 I am also keen to see updates on this... Share this post Link to post Share on other sites
