Crustydog 46 Posted April 4, 2018 I know its been covered in part on the net and on here but i still haven't found a definite answer. Has anyone in N.S.W gotten a 84 xe regod with a 351c. Some info i read states that you can because the v8 was a option for xe's, then some say that because the 84 models didnt come with a 8 option you can't. Is it just a matter of getting it engineered? Cheers Share this post Link to post Share on other sites
deankxf 20,290 Posted April 4, 2018 i did it with Mine, and BGDAV's is also a 1984, no engineers required in Vic going back over 5 yrs.. just needed a mechanical report saying all V8 components were used in conversion. (aka , springs and brakes) no idea on the current rules, but i'd be guessing it would be simple with engineers if you needed one(should also be simple for XF really) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Banno 479 Posted April 4, 2018 It’s to do with adr27c 1983 revised cause 1982 follow version adr27b.Emissions from what I gather. I have heard and read that in NSW require engineers but yet Victoria don’t. Even in EPA Victoria states that a v8 can be put into any XE cause it was a option. Best bet would be call a engineer or RMS NSW. To me it makes no sense when all states are meant to follow federal rules on vehicles. Sent from my iPhone using Tapatalk 3 CHESTNUTXE, Crustydog and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted April 4, 2018 I have done several in QLD its xf's they dont like. 1 Crustydog reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted April 4, 2018 It's basically the same in SA. If it came with a V8 option, it's just an engine swap. Dan @slo247 has just done the paperwork, they haven't even seen his car. As i said, that's here in Adelaide. There's a couple of guys here with Clevo XF's, just need to hit the firewall with a hammer. LOL..! 2 Outback Jack and Crustydog reacted to this Share this post Link to post Share on other sites
Crustydog 46 Posted April 6, 2018 What emission control are you guys using on these later model petrol v8 xe's? Just a cat converter and egr from the rocker? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted April 6, 2018 all mine were totally ileagil no cats ,holleys,no emissions,they were not even interested in any of that,i guess i got lucky,they were only interested in the shiny polished weiand rocker covers. 1 Crustydog reacted to this Share this post Link to post Share on other sites
SLO247 1,713 Posted April 6, 2018 They never had cats so you wont need one. To be legal and "correct" you would need to just run all the emissions gear as factory. EGR, charcoal canister plumbed up etc. 1 Crustydog reacted to this Share this post Link to post Share on other sites
deankxf 20,290 Posted April 7, 2018 i think the mechanic i dealt with was only looking for electronic ignition, pollution spec carb(would have been happy with a quadrajet off a commodore V8) but i had a thermoquad still, and egr fitted.. as soon as it was registered a holley and egr block happened anyway, so it makes me wonder what the difference was at the tailpipe from that? 1 Crustydog reacted to this Share this post Link to post Share on other sites
Crustydog 46 Posted April 7, 2018 yeah sweet. Due to my remote location lpg is not an option so it seems pretty simple to make it comply with unleaded. Share this post Link to post Share on other sites
bear351c 10,270 Posted April 7, 2018 Shove ball bearings down all the emissions hoses...... jobs done, looks stock. 2 CHESTNUTXE and Crustydog reacted to this Share this post Link to post Share on other sites
Crustydog 46 Posted April 7, 2018 I like the idea of the ball bearings. How are you letting blow-by escape without an obvious vent visible? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted April 7, 2018 All this worrying about the traffic authorities is not worth it , i have found that all they check is the new engine number to the engineers report its the guys writing the blue slip or roadworthy to get sweet with. 1 Crustydog reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted April 7, 2018 You MUST have a vent. PCV to base of carby usually. Can use K&N style filter caps on the rocker covers. I used to block all the emission hoses to charcoal canister, EGR and such..... Share this post Link to post Share on other sites
broken-wheel 659 Posted May 5, 2018 On 04/04/2018 at 11:05 PM, CHESTNUTXE said: I have done several in QLD its xf's they dont like. what did you have to go through to get the clevo in? I have two clevo blocks seating here ready to be put in the XE if it's relatively easy, one has the 4MAB crank just needs rods pistons and heads Share this post Link to post Share on other sites
bear351c 10,270 Posted May 5, 2018 Should only be an engine swap paperwork exercise. XE was available with 351 from factory. Not 100% sure, in Canetoad country. Share this post Link to post Share on other sites
gerg 10,871 Posted May 10, 2018 In NSW, reading between the lines, a post-82 XE would need an engineer's ticket due to the ADRs that came out that year effectively killing the V8. 1982 had ADR 27B, and they quickly ramped it up to 27C on Jan 1 1983, which had a stricter emissions requirement for passenger cars. You'd have to (at your own expense) prove that it complies with the later emissions standard of the vehicle it's going into.That's if the person doing the compliance check is doing their job. If not, disregard everything I just said.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
