gerg 10,871 Posted February 4, 2018 I haven't seen anything yet to say that it's out of a Cortina. The engine mounts definitely aren't, the sump is a Falcon one, haven't seen the dipstick hole or main bolts on #5 cap either so I reckon this bloke's just made the assumption based on not recognising the odd parts on it. It can't have been fitted to a Cortina correctly if it's an 84DA, as they don't have the rear dipstick drilling. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 4, 2018 i have never seen a 84da with a 3 bolt balancer could be a very late 84 xe falcon engine ? Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2018 i have never seen a 84da with a 3 bolt balancer could be a very late 84 xe falcon engine ?Could just be a slapper engine assembled with whatever bits were lying around.Sent from my CPH1607 using Tapatalk 2 ando76 and matt_lamb_160 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 4, 2018 its a august 85 block JG23FG with 3 bolt balancer and 1 piece rear main i think will take off soon. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 4, 2018 its a august 85 block JG23FG with 3 bolt balancer and 1 piece rear main i think will take off soon.Ok the crank is 10 under and 1 piece rear main seal and here is another shot of that line all 6 are identical on every chamber its in the casting like a millionth lay overSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 5, 2018 after cleaning the block i found this Share this post Link to post Share on other sites
ESPSIX 143 Posted February 5, 2018 For warranty, if the center is melted out, it been cooked. from memory. 3 FOMOCOHO, CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 5, 2018 For warranty, if the center is melted out, it been cooked. from memory.....Sent from my CPH1607 using Tapatalk 2 CHESTNUTXE and FOMOCOHO reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 5, 2018 For warranty, if the center is melted out, it been cooked. from memory.Coming along nicely Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 5, 2018 i cleaned up the head,id say springs have been replaced as well,they dont look like the factory ones with yellow paint on them ect,,,anyway the c2 came up nice,with a couple of hours work,i will start to order bearings now 10/10 and 020 rings. 1 FOMOCOHO reacted to this Share this post Link to post Share on other sites
rocklord 6 Posted February 6, 2018 Have you cc'd the head yet? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 6, 2018 nah might do it soon,still cleaning parts Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 6, 2018 OK THE HEAD is just about spot on 42cc c2,also the dizzy drive was sought of jamed in the 82da dizzy,note the ware,are these 2 parts not compatible ? xe and xf dizzy oil drive combo's,the jewel in the engine is this large water pump pulley as i can use it on my ute engine to slow it down a bit,the large alloy ones that speedway guys use are about $170,the number on the pulley is D1OE 8A 328 A be interesting what the clevo single pulley number is if thats what it is or a genuine older style large pulley ? Share this post Link to post Share on other sites
ando76 4,354 Posted February 6, 2018 Clevo water pump offset is incorrect, so it will be early non crossflow. Looking at the dizzy gear wear and the wear on the oil pump drive I'd be saying high volume oil pump 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 6, 2018 nah she's the ford std pump,but are xf dizzy and drive different ? Share this post Link to post Share on other sites
ando76 4,354 Posted February 6, 2018 Sorry water pump pulley I meant. Share this post Link to post Share on other sites
ando76 4,354 Posted February 6, 2018 Dizzy/oil pump drives are all the same hex size but there is variance in length 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 6, 2018 ok so xf ones are longer or shorter Share this post Link to post Share on other sites
ando76 4,354 Posted February 6, 2018 Well if the dizzy sat down properly on the block, then I'd say it was the correct length. HV oil pump or std? Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 9, 2018 Well if the dizzy sat down properly on the block, then I'd say it was the correct length. HV oil pump or std? I have most parts cleaned and painted also put new 4.1 sticker on r/cover im tossing up weather to put new cam bearings in it as the first one looks a bit chewd out ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 9, 2018 If crossys have the same diameter cam bearings all along (not like bloody clevos, c'mon seriously?) you could get a dolly machined up for not much. That way, you have one forever, especially since you do a few of these up.Sent from my CPH1607 using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 9, 2018 I can already see the machine shop charging 100 to put em in Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 13, 2018 I can already see the machine shop charging 100 to put em inBlock is ready for new plugs all parts are cleaned and painted just waiting for deliverysSent from my SM-G570Y using Tapatalk 2 Outback Jack and FOMOCOHO reacted to this Share this post Link to post Share on other sites
deankxf 20,292 Posted February 13, 2018 what was the ruling with the cam bearings? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted February 13, 2018 Hmmmm i havent taken it down to the machine shop yet upon thismornings inspection just the first one is cactus but i will get em replaced so far the engine owes me $150 with mega hours of cleaning ect,but still about $400/500 of parts to go on it,and cam bearings are gunna blo the budget out but they are necessary item 2 deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
