SPArKy_Dave 8,881 Posted September 22, 2017 Does anyone know what the standard length is, for stock pushrods in an Alloy Head Crossflow? I've got lengths of 9.682, and 9.652... which one is correct? Also, what performance options are out there for pushrods, and are they worth it? (knowing that pushrods are kind of a safety mechanism for Crossy's) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 22, 2017 9.652 is std i have trend 9.8 in mine 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 22, 2017 Howcome you have 9.8? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 22, 2017 because the pushrods go deeper into the cup of the roller rockers ,the stamped steel stockers are different. Share this post Link to post Share on other sites
slydog 7,873 Posted September 22, 2017 Unless it's got real springs in it stock pushrods are fine. Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 22, 2017 1 hour ago, slydog said: Unless it's got real springs in it stock pushrods are fine. x3 of them are banana shaped.... I don't think I can leave them, LOL! Do you know, what the stock length is? Share this post Link to post Share on other sites
slydog 7,873 Posted September 22, 2017 Find more stock ones. No don't know don't use. Â Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 22, 2017 every crossy i pulled apart had bent pushrods from people over reving da fook Share this post Link to post Share on other sites
slydog 7,873 Posted September 23, 2017 Mine are 9.5 long 3/8th 120th wall Trend units. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,881 Posted September 23, 2017 Where do you get these Trend pushrods from? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 23, 2017 i have a set here exactly like that sly they are thick as your finger,but they didnt fit thru the guide plates ,as i went for the next size down,the ones i used must be placed with the 210 ball end towards the rocker,also milling of surfaces ,and converting to screw in studs and roller rockers will change length ,also head gasket size,thats why they make a adjustable pushrod to get your correct length,but if your putting a set of bolt on hyd roller rockers 5/16th on a running engine,std length pushrods are a good place to start or at least measure the ones that came out of it and replace with hardend or crome moly if you can afford it. Share this post Link to post Share on other sites
deankxf 20,292 Posted September 23, 2017 13 hours ago, SPArKy_Dave said: x3 of them are banana shaped.... I don't think I can leave them, LOL! Do you know, what the stock length is? mark might have spares, he's wrecked a few crossflows stick 3 more in, she'll be right 2 CHESTNUTXE and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted September 25, 2017 Bore the block to take an rsj. However, its best to cut a standard pushy, thread it, and use that to measure your length as your deck height, lifters, head skimming, and rockers will affect it. Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 25, 2017 i took apart a crossy today for the head and cam to go to usa and it had caps on top of the valve stems and also weird taperd pushrods i have never seen b4 or are these older iron head gear ? 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 25, 2017 i took apart a crossy today for the head and cam to go to usa and it had caps on top of the valve stems and also weird taperd pushrods i have never seen b4 or are these older iron head gear ? I told you they were crazy for them How much did you sell them for? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,312 Posted September 25, 2017 $200 for cam head and r/cover and iron exhaust manifold,e bay price was $50 for complete engine 2 Valvebouncer and Slow250XC reacted to this Share this post Link to post Share on other sites
XTREME KARTS XF 1,212 Posted September 26, 2017 On 23/09/2017 at 11:13 PM, deankdx said: mark might have spares, he's wrecked a few crossflows stick 3 more in, she'll be right Yep, got a couple of sets in the shed from 3 engines i pulled down, 2 were 200 xflows (just for the conrods) I bought new pushrods for my crossy back in 2011 from Crow Cams, just standed replacement ones of course Share this post Link to post Share on other sites
