CHESTNUTXE 7,311 Posted July 23, 2017 also bought the a/c type fan fitting cause i was gunna use the xf plastic clutch fan but deans video convinced me to go a large single thermo or EL set up.i still should be able to use this waterpump as there is no fan going on it at all. Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 23, 2017 it will get close to the el fan shroud if you mount it on a standard flow rad. The thread that holds the fan gets close to the el shroud. I cut a notch out on my fan shroud to make fit, if was doing again would put the water pump in the lathe or mill and cut the end off. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 23, 2017 Thanks for that advice,what about with just a single thermo,i guess i wont no until its in position,or just order the normal non air con one ? Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 24, 2017 the engine is on the stand and just my luck da cookin dodo internet is down so I'm using the phone will post pics on wed hopefully when they fix it 1 deankxf reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted July 24, 2017 Tease ,,!!! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 24, 2017 also noticed the water pump pulley bolts are a different thread to the ones I have here ? Xe and xf don't fit why would they do that ? Share this post Link to post Share on other sites
deankxf 20,288 Posted July 24, 2017 2 hours ago, CHESTNUTXE said: also noticed the water pump pulley bolts are a different thread to the ones I have here ? Xe and xf don't fit why would they do that ? probably saved 4 cents per car using metric bolts Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 24, 2017 same as last clevo the water pump bolts I had to get,its freezing here I couldn't help myself I fitted the oil pump and pick up to the crossy . Share this post Link to post Share on other sites
dex 2,065 Posted July 24, 2017 Sorry for the hijack ,, but is there a thread on the full hook up/how to bung el thermos on say an xf with air/p's ,? From go to whoooh 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 26, 2017 my internet is fixed so when I get home from work I will post a few pics from basic bottom end to what I've done in the last few days 3 tpak addict, deankxf and dex reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 26, 2017 ok this is how i picked it up,assembled short motor,balanced,ol.m8's oil mod. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 26, 2017 Then i gave it a coat of paint,fitted the oil pump and pick-up,just loosely put the std sump on for the moment until i get it modded by asr or ando's one,fitted water pump today,put some brackets on just for a look ,also pulley,i ended up finding some correct bolts in wagoon's boxes of parts,pistons are 20.5 cc dish and deck is 0.005,i will be using a mls .040 gasket for a comp ratio of 9.7 ish,arp main stud kit,arp rod bolts,king race bearings,tighe solid cam and fluted lifters,9.800 hardend pushrods,7/16 ford clevo/big block roller rockers,arp studs ect,,,,stainless 2v clevo intakes and chev exhausts turned down to ol.m8's spec's,reckon it took him 5 hours of work to turn the valves down. 1 Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 26, 2017 The fat heavy alt bracket,and powerbond street/strip balancer. Share this post Link to post Share on other sites
deankxf 20,288 Posted July 26, 2017 its time to change to imgur.com now.. imgbox no longer works. photobucket.. its a conspiracy 2 Slow250XC and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 26, 2017 today i will buy some more gear,belts.oil filter,ect...maybe even a car to put it in 2 deankxf and Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 27, 2017 the first snag is the est plastic cover is hitting the oil mod,so i guess i can remove that and wire it directly to the 3 pins,problem solved,snag 2 is the oil filter is hitting the oil mod and wont line up with the thread,might need a small extension on the filter ???? snag 3 now the oil filter is hitting the power steering bracket,solution =fuk the oil mod off lol.i was just looking at some remote oil fittings might solve the clearance or i will talk to him about fixing the problem with a taller fitting to clear the filter in the normal position. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted July 27, 2017 thought you were going manual steering? would be easier to mod the power steering bracket wouldnt it? Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 27, 2017 if i can non p/s,but just fitted the bracket to see,i mean if i extend the filter somehow it will stick out quite far and hit the bottom of the pump thats on the bracket i think but havent tested that yet might just give it a go tomorrow and see. Share this post Link to post Share on other sites
Ando81 2,949 Posted July 27, 2017 Sorry if this is a stupid question but what is ol m8's oil mod designed to do? I'm not knocking it, just haven't seen it before. 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
ando76 4,354 Posted July 27, 2017 It looks very similar to the mod that you do on a clevo. Why you would do it on a crossy has me beat. I have never had an issue with the way the bearings are fed in these engines. 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 27, 2017 he is old school and built a million of these over 40 years and reckons something to do with delivering more oil to the rear as the hole is tiny for oil compard to the front hole if that makes sense i think he means the size of the hole which gives oil to the bearings,i will ask him again this afo ,when i bought the block in thats the first thing he was intending on doing,could be similar to the clevo thing where it doesnt get enough oil ,but in a daily drive or mild performance engine i doubt its worth it,will post more info when i ask him about it,as others say its totaly unessecary and could be right,i just went with what he reckonds,didnt want to rock the boat as he gets cranky very quickly,i can always just unscrew it and plug the hole with a plug,i was actualy against it but he chucked a spastic when i doubted his work lol. Share this post Link to post Share on other sites
Ando81 2,949 Posted July 27, 2017 Yeah righto, sounds like he's pretty fussy then. That's what you want 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 28, 2017 just hitting the oil filter i rang him and he is gunna come around and put a different fitting on it. 1 deankxf reacted to this Share this post Link to post Share on other sites
Lord_fahrquhar 2,580 Posted July 28, 2017 Chestnut, power steering. you got yo have it but fuck do an Astra ps conversion. It gives you a shittin of more room on the inlet. reminds me to get my arse into gear and get my head finished. anyone know a good head guy in Adelaide ? or Perth I'm there too often enough for work. Share this post Link to post Share on other sites
