deankxf 20,313 Posted August 20, 2017 i used a 1/2 inch socket from in the inner guard from memory. only ever did it the wrong way(with a spanner) once... 2 CHESTNUTXE and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 20, 2017 Ratchet spanners work well Sent from my Pixel using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted August 20, 2017 im finding myself buying a new socket or tool every few weeks for the correct job ,last week i needed a deep socket for the screw in studs on the crossflow head. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
Free.51 2,727 Posted August 21, 2017 Yep thats how you aquire tools over time haha, i think ill just do the unbolt the hinges from the door trick & support it on something while i smack out the old pins, thanx for the tips fellas👍👍 Share this post Link to post Share on other sites
Free.51 2,727 Posted September 7, 2017 Put new pins & bushes in yesterday & a much better striker today now the door is sitting too high & there is a gap where air is getting through near the b pillar. Is is just a matter of loosening off the 4 bolts again to adjust the door?Sent from my SM-A520F using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted September 7, 2017 it should be like new but good question 1 Free.51 reacted to this Share this post Link to post Share on other sites
deankxf 20,313 Posted September 7, 2017 when you shut the door without the striker, how do the body lines line up? if they are inline front to back door and the gaps are ok then it should be pretty close. the striker is adjustable in and out, also the 4 hinge bolts in wards and out.and up and down. (plus up and down on any angle on the 3 bolt part of the hinge 3 CHESTNUTXE, Valvebouncer and Free.51 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,331 Posted September 7, 2017 when I fit my new door on the ute I'm gunna try something new like shut the door to the car then line up and tighten bolts while the guard is off 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,313 Posted September 7, 2017 39 minutes ago, CHESTNUTXE said: when I fit my new door on the ute I'm gunna try something new like shut the door to the car then line up and tighten bolts while the guard is off is much much easier to do them with the guards off Share this post Link to post Share on other sites
Free.51 2,727 Posted September 7, 2017 1 hour ago, deankdx said: when you shut the door without the striker, how do the body lines line up? if they are inline front to back door and the gaps are ok then it should be pretty close. the striker is adjustable in and out, also the 4 hinge bolts in wards and out.and up and down. (plus up and down on any angle on the 3 bolt part of the hinge Havent tried shutting the door without the striker yet Dean but tomorrow after work ill have a play around & see if i can get it spot on, thanks for yor help👍 1 deankxf reacted to this Share this post Link to post Share on other sites
RoughXE 6 Posted May 24, 2021 On 7/11/2017 at 5:49 PM, deankdx said: i had an awesome thread with pics of how i fixed it.. pics wont work now. basically remove hinge, make a plate to sit between the door and hinge and bolt it back together.. welding it would be the best way, but temporary fix lasts longer than a good door.. check the hinge roller actually rolls, otherwise it may have cracked by people opening the door too wide(or wind catching it) ford's idea of a check strap only took about 20 yrs or so to be improved. Hi deankdx, I know this is a 4 yr old thread, but can you give me anymore info on this repair? I'm doing some work on my old rusty xe sedan project and noticed my passenger side door has dropped, at first I thought it was hinge bushes, but upon inspection I notice the door is broken around the bottom hinge mounting area. It's a budget build and just need to get the door sitting straight again..... Cheers Share this post Link to post Share on other sites
deankxf 20,313 Posted May 24, 2021 4 minutes ago, RoughXE said: Hi deankdx, I know this is a 4 yr old thread, but can you give me anymore info on this repair? I'm doing some work on my old rusty xe sedan project and noticed my passenger side door has dropped, at first I thought it was hinge bushes, but upon inspection I notice the door is broken around the bottom hinge mounting area. It's a budget build and just need to get the door sitting straight again..... Cheers i do have a photo of the first one i did, this i drilled a heap of holes in for plug welding, but it worked so well, i didn't bother plug welding it from memory. Share this post Link to post Share on other sites
RoughXE 6 Posted May 24, 2021 Awesome thanks mate, do u remember how thick the plate was? Can you leave the door on, unbolt that hinge and slip it in there? Share this post Link to post Share on other sites
deankxf 20,313 Posted May 24, 2021 1 hour ago, RoughXE said: Awesome thanks mate, do u remember how thick the plate was? Can you leave the door on, unbolt that hinge and slip it in there? sorry for slow reply, yes, you can leave the door on if you can get the bolts out.. some are nightmares to undo, especially if they are the later torx bit ones.. i've had to drill the heads off and then replace the bolts. access is easier through the mudgaurd, remove the dust cover by bending 2 tabs straight and yanking it forward.. (wash the dirt out of the sill area and check for rust) removing the guard is sometimes easier also. the plate would be better if it was thick. you could use 2 LARGE washers with small(bolt sized) holes.. it would do the job.(2 x 50c coins with a hole in them would work even) you will likely need to loosen and adjust the 3 bolts on the hinge at the A pillar to compensate for the spacer/washers. depends how the hinge bushes are also Share this post Link to post Share on other sites
RoughXE 6 Posted May 24, 2021 To easy I might try have a look at what's there today, are all the models torx bits or do some models have bolts? The bushes feel ok from memory, just the door dropped the other day while I was working on it. I should have some of those penny washers kicking around, I'll see if I've got any thick ones there if not I'll grab some and give that a try first before looking at making a plate, cheers mate . 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,313 Posted May 25, 2021 if it works, take some photos and document the process a bit for others, i am going by stuff i did well over 10yrs ago. Share this post Link to post Share on other sites
deankxf 20,313 Posted May 25, 2021 3 hours ago, RoughXE said: are all the models torx bits or do some models have bolts? torx came in around 1988 in the XF ute/van i expect(not sure) but i've had an XE that had been retrofitted with them(suspect the hinges were worn and they got used hinges from the wreckers) the A pillar nuts are 13mm, can't remember what size the door ones are, suspect also 13mm. if you accidently dislodge the 3 bolt thing from the A pillar it's not too hard to put back in, just need to remove the kick panel, check for redbacks and hook it back in. Share this post Link to post Share on other sites
dvfalcon 352 Posted May 25, 2021 When lining up the doors take the striker off, I use 2 x 10mm window packers placed on the sill, sit the door on top in position and do up. It puts you in the ball park and adjust from there. A plate like dean made will last for years, if you can make one for inside the door as well so it sandwich the door between. Guard off is the best but just the inner guard will do. Window packers below but at the end of the day anything 10mm thickSent from my iPad using Tapatalk Share this post Link to post Share on other sites
RoughXE 6 Posted May 25, 2021 Awesome cheers lads, I'm going to remove the front guards anyway to attack some rust so that'll work well. I've got those packers at work so even better! I'll keep yous updated on how it goes, I've got the door trims already off so might look at sandwiching it to, its a bit of a slow project at the moment with life, kids and work in the middle, but will keep yous in the loop. Share this post Link to post Share on other sites
deankxf 20,313 Posted May 25, 2021 14 minutes ago, RoughXE said: I've got the door trims already off so might look at sandwiching it to, i can't remember what's inside the door but i think it's a plate with captive nuts hung over a hook. so you might be able to also make the plate wider in there as dvfalcon said above. i've never done that. few people have cut it out and welded the door section back together, but if you don't have a welder this plate works well enough Share this post Link to post Share on other sites
dvfalcon 352 Posted May 25, 2021 i can't remember what's inside the door but i think it's a plate with captive nuts hung over a hook. so you might be able to also make the plate wider in there as dvfalcon said above. i've never done that. few people have cut it out and welded the door section back together, but if you don't have a welder this plate works well enoughIn side the door is like a dog bone type plate capsulated in some retainers with captive nuts to allow the door to move in and out I did remove that.Sent from my iPhone using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
