CHESTNUTXE 7,311 Posted June 26, 2017 With the door hinge kits that are available with new pins,do you have to take the door off ,or can they be replaced doing 1 at a time while still on the car ? Share this post Link to post Share on other sites
deankxf 20,288 Posted June 26, 2017 one at a time should be fine, access from behind the mud trap in the inner guard plastic would be how i'd do it..(kill the redbacks before sticking your hand in there) 2 CHESTNUTXE and XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted June 26, 2017 ok the xg i just bought needs both doors done,or would it be better to just take the fookin doors off ? i could use the hinges off the wagon i just bought are xf the same,they look the same at the front,i remember once doing a xe and it was a bastard off a job,ended up cutting the bottom one off with a thin wheel,but the xg ones look like they had improved the pins. 1 Defective reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted June 26, 2017 are the hinges worn? usually the bottom hinge mount on the door is broken.. hinges can be swapped if you can get the torx screws out.. .. you should be able to just remove the pins if it has that style. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted June 26, 2017 well the doors have huge play and drop when opened i looked at the actual hinge it seems fine just the pin bushing has failed i hope.i think the xg ones have a clip you just remove to tap the old pin and bush out. Share this post Link to post Share on other sites
deankxf 20,288 Posted June 26, 2017 my 1991 XF had that type with the clip and removable pin.. i've never done the crimped type, i'd wrecked enough cars to just have good hinges to swap over.. simples. Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted June 26, 2017 yep the xe had the crimped,but once fixed its all good times Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted June 26, 2017 definatly a open and shut case 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 11, 2017 passenger side has torx head bolts ? wtf so i just punched the pin out and fitted the bushes,i will put da door back on after my coffee break Share this post Link to post Share on other sites
deankxf 20,288 Posted July 11, 2017 i've done that.. if you can get one bolt undone, you can turn the hinge which takes the bolt with it a bit of a turn(looser) and will often undo. i've had to undo them due to the door being buggered, i've only changed one hinge bush set ever.. 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 11, 2017 all done now and didnt change anything the fkn door is broken stupid me i should av checked Share this post Link to post Share on other sites
deankxf 20,288 Posted July 11, 2017 i had an awesome thread with pics of how i fixed it.. pics wont work now. basically remove hinge, make a plate to sit between the door and hinge and bolt it back together.. welding it would be the best way, but temporary fix lasts longer than a good door.. check the hinge roller actually rolls, otherwise it may have cracked by people opening the door too wide(or wind catching it) ford's idea of a check strap only took about 20 yrs or so to be improved. 1 XTREME KARTS XF reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted July 11, 2017 why the fk did ford put torx nuts on the passenger xg door's ?drivers are normal bolts,same as my other ute ? Share this post Link to post Share on other sites
deankxf 20,288 Posted July 11, 2017 1 minute ago, CHESTNUTXE said: why the fk did ford put torx nuts on the passenger xg door's ?drivers are normal bolts,same as my other ute ? someone has changed the drivers bolts/hinges.. My 1991 XF had torx bolts. one hinge had XF bolts by the time i was done, because i drilled the torx heads off to remove the hinge(to fit my plate in between hinge and broken door) Share this post Link to post Share on other sites
Free.51 2,717 Posted August 20, 2017 Ive got new pins & bushes for my drivers door on my FD to put in but im not too sure how to get the old pins out so i thought id ask u guys b4 just whacking away with a hammer & centre punch Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 thats how you do it exactly 1 Free.51 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 or an old big nail Share this post Link to post Share on other sites
Free.51 2,717 Posted August 20, 2017 The top pin is gonna be tricky theres not really any room to line the punch up with the pin, but ill figure something out, cheers for the reply👍👍 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 yup you unbolt da fooka and pop the door off then bash the old pin out because you now have room,all up 10 mins work 1 Free.51 reacted to this Share this post Link to post Share on other sites
Free.51 2,717 Posted August 20, 2017 Ok thanks mate thats how im gonna do it, ill get my bro to hold the door cos i cant completely take the door away cos of the elctrics loom 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 20, 2017 Just a thought, could you pull the guard off and change the pins and bushes with the door shut?It might be easier than trying to readjust the door. 2 XTREME KARTS XF and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 yeah you could do that,or just slide a milk crate under the door when you take it off just for support and 2 people to put back on really helps as by yurself is not impossible but temper testing Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 yes the pin will come out but in the kit you get new bushes which can only be fitted when the door is totaly taken off see picture in begining of thread 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
deankxf 20,288 Posted August 20, 2017 2 hours ago, Free.51 said: Ok thanks mate thats how im gonna do it, ill get my bro to hold the door cos i cant completely take the door away cos of the elctrics loom if you take the plastic dirt trap out of the mudguard, and fly spray the redbacks in there and wash the dirt out.. you can remove the hinges one by one without taking the guard or the door off.. aligning the door would be far easier with the guard off depending how much a pain in the ass they are to remove(lower bolts break off etc) scratches from bumper and so on 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,311 Posted August 20, 2017 you need a 13 mm spanner and 48,859,687 small turns to get the door bolts off,either way you do it just support the door from the start ,i shimmed cardboard on top of the milk crate or some type of stool and rest the door in the middle to avoid dropping and scratching,then just move door away from car on the crate wack out your pin and fit new bushes with a flat hammer of some type,the new pins are so easy to fit and then push on your clips to hold the pin ,bolt door back on and thats it,i have done a few and never needed to re alighn the door. Share this post Link to post Share on other sites
